Body
Revision as of 10:34, 15 September 2018; view current revision
Category: Body
The Datsun 1200 has a unibody design made out of high-strength steel. It does not use Body-on-Frame construction. The result is a lighter, stronger and stiffer chassis.
Front Panels
Core Support & Apron
The main front body panel is the Core Support, so named because it supports the radiator core. To this is fastened the Front Apron (valence) finishing panel.
See Main Article: Core Support and Apron
Minor differences are with the Coupe and Sedan panels, and with the late ute panel.
Front Fender Panel
For fender/guard/wing, see main article: Front Fender and Front End
Hood Ledge & Hood Panel
See main articles:
Hood (bonnet)
Cowl Panels (Firewall & Dash)
See Main Article: Cowl
Roof Panel
See main article: Roof
Floor Panels
See main article: Floor
Side Panels
See Main Article: Body Side Panels
Door Panels
See Main Article: Doors
Rear Side Panels
See main article: Body Side Panels
* Dash side
* Hood Ledge Reinforcement
* Rear Wheel House
* Roof Rail
* Shock Bracket Panel
* Sills
* Quarter Panels (rear fender)
  15733.jpgAlbum click to view
* Tray Sides
  23216.jpgAlbum click to view 3326.jpgAlbum click to view
* Pillars
Rear Panels
Also See:
* Trunk Lid
* Rear Body Part Numbers
23212.jpgAlbum 23212
119 76613-H1000   PANEL-rear pillar (L.H.) 4 door [HAS BEEN CUT]
26247.jpgAlbum 26247
Rear Panel
Sometimes called a beaver panel, however the 1200 rear panel is one piece:
79100-H1000 ASS'Y PANEL-rear Sedan
79100-H1800 ASS'Y PANEL-rear Coupe
79100-H1400 ASS'Y PANEL-rear Van
Coupe
174_56eb1be7c8e27.jpgUpload click to view 2633.jpgAlbum 2633
Sedan
79100-H1000.jpg 79100-H1000_.jpg 79100-H1000-.jpg 20121.jpgAlbum 20121
Rear Panel Fitting - Coupe
1970-1971 Coupe GX and all 1972 coupe (DX,GL,GL) came with a rear panel finisher.
early GX Coupe black-out rear panel | 1972
22562.jpgAlbum 22562 21081.jpgAlbum 21081
  GX
  79801-H4200 1972 FINISHER-rear panel, center
  79202-H4025 1972 ORNAMENT SET-rear panel
  79801-H2400 1970 FINISHER-rear panel, center
  79202-H1826 1970 SET-ORNAMENT, REAR PANEL COUPE
  79802-H2400 FINISHER-rear panel side, upper RH
  79803-H2400 FINISHER-rear panel side, upper LH
  79804-H2400 FINISHER-rear panel side, lower RH
  79805-H2400 FINISHER-rear panel side, lower LH
  1972 DX,GL
  79801-H4000 FINISHER-rear panel, center
  79802-H4000 FINISHER-rear panel side, upper RH
  79803-H4000 FINISHER-rear panel side, upper LH
  79804-H4000 FINISHER-rear panel side, lower RH
  79805-H4000 FINISHER-rear panel side, lower LH
GL 1972 - gray finisher?
GX 1972
174_5a19cc20e08b8.jpgPost click for topic 174_4dcc8ff61d576.jpgPost 487016 174_5a19cc2e6f703.jpgPost 486798 174_5a19cc3a8e51a.jpgPost 486798
174_5b9cd7b5a6854.jpgPost 489450
Ute
Back Panel
23214.jpgAlbum 23214
  • 79110-G1001 PANEL-REAR, LOWER
Rear Floor
Rear Floor Panel
See Truck Rear Floor Panel
Rear Gate Panel
See Tailgate
Exterior Fitting
See main articles:
Badges emblems, marks, IDs
Colors
Radiator Grille
Misc
  • 78130-H1000 Lid-gas Filler SEDAN $18.83
Roof Drip Moulding
Rain gutters for USA & JAPAN are the same.
23902.jpgAlbum 23902
  • The rear piece differs 2dr, 4dr, Van
  • Truck doesn't have a rear piece
  • Coupe front & rear pieces are unique
Coupe
73800-H1800 SET-MOULDING ROOF DRIP RH
 73810-H1800 MOULDING-ROOF DRIP FRONT RH
 73812-H1800 MOULDING-ROOF DRIP REAR RH
73801-H1800 SET-MOULDING ROOF DRIP LH
 73811-H1800 MOULDING-ROOF DRIP FRONT LH
 73813-H1800 MOULDING-ROOF DRIP REAR LH
73800-H1801 SET-MOULDING ROOF DRIP RH (from '70-May)
 73810-H1801 MOULDING-ROOF DRIP FRONT RH
 73812-H1801 MOULDING-ROOF DRIP REAR RH
73801-H1801 SET-MOULDING ROOF DRIP LH (from '70-May)
 73811-H1801 MOULDING-ROOF DRIP FRONT LH
 73813-H1801 MOULDING-ROOF DRIP REAR LH
73815-H1100 CLIP-MOULDING ROOF DRIP [center clip]
Sedan & Van
STD models had no drip rails.
73800-H1100 SET-MOULDING-drip roof 4S
73800-H1300 SET-MOULDING ROOF DRIP 2S
73800-H1300 SET-MOULDING ROOF DRIP V-DX,VP
Sets include
 73810-H1100 MOULDING-ROOF DRIP FRONT RH
 73811-H1100 MOULDING-ROOF DRIP FRONT LH
 2-dr
  73812-H1300 MOULDING-ROOF DRIP REAR RH
  73813-H1300 MOULDING-ROOF DRIP REAR LH
 4-dr
  73812-H1100 MOULDING-drip roof, rear (R.H.)
  73813-H1100 MOULDING-drip roof, rear (L.H.)
 Van
  73812-H1500 MOULDING-drip roof, rear (R.H.)
  73813-H1500 MOULDING-drip roof, rear (L.H.)
Truck
73810
73812-G1000 MOULDING-ROOF DRIP, FRONT RH
73811
73813-G1000 MOULDING-ROOF DRIP, FRONT LH
23901.jpgAlbum 23901
Interior Fitting
See main article: Interior
Scuff Plate
See Kicking Plate
Aftermarket Suppliers
Most of these body panel manufacturers have a minimum sale of a full cargo container or 100 units. So look for a local distributor.
CHUNG FU CHING - Taiwan
* DS057112AL Left Door (4-dr, van, truck)
  26212.jpgAlbum 26212
Auto Parts Industrial (API)
http://www.autostone.com/contactus.asp
* We sell Auto Crash Parts to distributors on container base.
* DT20-013-0 DATSUN 1200 -73 FRT APRON LOWER
* DT20-015-0 DATSUN 1200 BONNET (Sedan / Ute)
* DT20-016-1 DATSUN 1200 FR GUARD RH (Sedan / Ute)
* DT20-016-2 DATSUN 1200 FR GUARD LH (Sedan / Ute)
* DT20-077-0 DATSUN 1200 TAILGATE
eBay seller: Pedromxi
