A strut tower bar is a cool-looking piece of hardware that ties the two strut towers together. Also known as strut bar, dampener, damper bar, strut brace, or Monte Carlo bar. The performance theory is that it reduces chassis deformation on hard cornering.
Album 25378
B110 strut-top bolt circle is the same as other Nissans: 122mm diameter
Track 1200s will crack at the back of the strut towers. Not needed on a street car.
The brace can be as simple as a single piece of tubing
Album 650
Low and high versions
* Flat bar
* Round bar
* Round with taper ends
* Square section tube
jeffroj taper-end bars
Album 17946
Upload click to view
high mounts point for extra clearance
Album 17177
Album 16855
high-bend bar for extra clearance
Album 4700
square tube
Album 12329
Album 15854
Album 2443
Post 358288
Vendors
Bprojects
Bprojects
Album 14223
Titan
Album 15878
eeeCustoms
Album 22268
Nissan Prince Sporty Kit
99930-7110P
Album 2825
boofhead
Album 13790
Album 12888
Album 10977
Album 10978
Album 10957
Album 10364
Album click to view
Album 10369
Album 10079
Strut Top bar ends
Album 10100
Album 10182
Album 10183
Album 10184
Album 11586
Nismo
Nismo
Cusco
Cusco Type ST steel shaft クスコ タワーバー (part number 204 510 A) - clears A14/A15 engine
Album 25575
Album 4053
Mad Dat
Maddat Strut Brace
Maddat Tri-bar Strut Brace
Post 432419
Fumiya
Fumiya
Album 16531
Album 16532
Album 18839
Album 19397
Album 19398
Album 19399
Album 20008
low-rise
Album 19126
Album 19127
hi-rise for clearance
Album 19946
Album 19947
Toyota
Album 1609
Dimensions
1200 strut-top bolt circle: 122mm diameter
Album 17945
B110/B120 strut width center-to-center: 936 mm (36.85 inch)
Album 22877
Album 10017
Adjustable
Post 332487
Post 380888
Post 258967
Post 258967
Post 288413
Stiffening Bars
engine damper
Album 15859
Crossmember bar
Album 25646
Coupe rear body stiffener
Album 25645
Rear shock tower bar
Album 25647
Album 25648
More Photos
Album 1653
Album 1936
Album 2000
Pantel B310
Album 2400
Album click to view
Album click to view
V8
Album 2672
Album 2812
510
Album 4064
sticks
Album 6718
modified Nismo bar
Album 4011
Album 9430
Album 10987
Album 12909
Laney
Album 13492
frankthedolphintrainer - extra clearance for CA18DE
Album 16510
Album 16511
Album 16512
Album 16854
Album 16855
Spreader bar
Album 19090
Strut tower-to-firewall
Album 20810
levey
Album 21121
Album 21861
Album 21862
Album 25373
strut brace, tower bar,strut bar,dampener,damper bar,brace,Monte Carlo bar not steering
