Custom Dash Faces
Revision as of 11:57, 4 October 2019; view current revision
Take the face plate and scan it on the flatbad scanner, then modify it. Finally, print a new one out with the photo printer. You can modify the font, colors, etc. You might think you can simply bolt it to the speedo using the standard screws, but it will not lay flat. Adhesive paper (sticker paper) will work. Or, bolt it to the speedo using the standard screws AND secure the perimeter with some kind of contact cement so that in heat or cold the label doesn't warp and stop the indicator needle.
Also see:
* Speedometer
* Tachometer
* Clock
* Dash
Print them yourself on a photo printer using sticker paper.
When you installed the decals just peel them off the backing and stick them on. But it's better if you peel them off, then dip in soapy water so can move it into position better. The only thing is you have to wait for it to dry
Raw Scans
Scans of original 1971-1973 B110 components:
Speedometer | Clock
13742.jpgAlbum 13742 13743.jpgAlbum 13743
Custom Files
Here is a multi-layer PNG file, which you can print out in a photo printer. You could also modify it first (it is calibrated for 4.11 diff). Perhaps reverse the colors to black numerals on white face?
14098.jpgAlbum 14098
ask for high-res version
Metric-Imperial Conversion
trimmer
From stichesandsounds
POST Datsun 1200 Dash Face Gauges Vinyl Overlays
27734.jpgAlbum 27734 27735.jpgAlbum 27735 27736.jpgAlbum 27736 27737.jpgAlbum 27737
lisasdecals
late 1200 in red| early 1200 in grey
8226_4d9ba6a7e611b.jpgPost 362676 8226_4d9ba6c2b572f.jpgPost 362676
carbon fiber-look
1617_4dc50ec619382.jpgPost 367045 22950.jpgAlbum 22950
8226_4db07262c398e.jpgPost 364896 8226_4db0726b24d53.jpgPost 364896
white gauge faces with red LED bulbs
22939.jpgAlbum 22939 22947.jpgAlbum 22947
POST White / Carbon Fiber face gauges, anyone? More Colors added
white vinyl overlays
22951.jpgAlbum 22951 22981.jpgAlbum 22981 22982.jpgAlbum 22982
