PB110 Sunny Excellent 1400
Tail Lights
Coupe
KPB110 looks like B110 sedan lights, but protruding
Sedan
Looks similar to the facelift B110 coupe lights - but are longer.
26556-H2800 Lens center segment
26526-H2800 Lens outside segment
License Lights
KPB110 Coupe License Light
PB110 Coupe lamp assembly is same as KB110.
Datsun 1400 Coupe (KPB110) has dual license plate lights, tucked up under the bumper -- exactly the same as regular KB110 Datsun 1200 Coupe.
26510-H1800 includes all parts here
Side Lights
Datsun Sunny Excellent 1400 (PB110) サイド マーカー ランプ
H25 SIDE LAMP [corner lamp]
K01 lights look similar (from Nissan 710 Violet) 26166-K0100
Fog Lights
Datsun Sunny 1400 had the Fog Lamps built into the grille.
FOG LAMP Note: H25 = KPB110 (1971) Note: 265 = KP510 (1969) 30 26150-H2525 LAMP KIT-fog (op.) DX,GL 2 26150-H2500 LAMP ASS'Y-fog GX, (op.) DX,GL <-O-> 26150-H2501 2 26150-H2501 LAMP ASS'Y-fog (from '71-5) GX, (op.) DX,GL 2 31 26151-26501 * LENS (白熱) [incandescent] 2 32 26152-26500 * RIM 2 33 26153-26500 * PACKING 2 <-O-> 26155-H2501 26155-H2501 * PACKING (from '71-5) 2 34 26718-26500 * BULB 2 35 08911-30810 * NUT M8 2 36 08915-13810 * WASHER M8 2 *37 62320-H2500 * BRACKET-fog lamp (R.H.) 61321-H2500 * BRACKET-fog lamp (L.H.) fixing bracket 38 08513-51012 * SCREW, pan head M5x10 4 39 08915-13510 * WASHER, spring lock M5 4 40 25160-H1110 * SWITCH COMP.-lighting & fog Reference: C-213 Parts Catalog Page 112-5MASK (fog lamp delete plates) comes with the DX/GL
Fog lamps have grille brackets. See Grille#PB110.
510
The PB110 fog lights are based on the Datsun 510. The 510 has two versions:
- grille mounted, with two-bolt housing that attaches directly the special grille. This version uses expensive iodine lamps
- bumper mounted, like the PB110, with a post that bolts to a bumper bracket. Available in premium iodine or budget incandescent
The housing has a gold-colored reflector, which makes the lamps appear yellow
ラヂエターグリル取付用 [for Radiator Grille mounting] 26150-26510 ASS'Y-LAMP, fog R.H. (沃素) [iodine] ¥3500 26155-26510 ASS'Y-LAMP, fog L.H. (沃素) [iodine] ¥3500 26151-26500 LENS-fog lamp [iodine] 26153-26500 PACKING-lens 26719-26500 BULB-fog lamp 26996-26510 SEAT-fog lamp A 26997-26510 SEAT-fog lamp B
本部品フォグランプはオプション用ラヂェターグリルに組込出来?????のむのです。
・ 市光工業直送取?い部品 [ Ichikoh Industries direct]
バンパー取付用 [for Bumper Mounting] 26150-26500 ASS'Y-LAMP, fog R.H. (沃素) [iodine] ¥3500 26150-26501 ASS'Y-LAMP, fog R.H. (白熱) [incandescent] ¥920 26151-26500 LENS-foglamp (沃素) [iodine] 26151-26501 LENS-foglamp (白熱) [incandescent] 26153-26500 PACKING-lens 26719-26500 BULB-fog lamp (沃素) [iodine] 26718-26500 BULB-fog lamp (白熱) [incandescent] 26996-26500 SEAT-bracket
本部品フォグランプはバンパーに取付けられ沃素??と白熱??が?ります。 (スイッチ 25919-89905)
尚、?のセダン缶?車にも取付出来ます。
・ 市光工業直送取?い部品 [ Ichikoh Industries]
Front Turn Signal Lamp
.Unlike the 1200's Front Combination Lamp, the 1400 lamp only has a single element for the Turn Signals.
Lamp assy has single wire for the single-contact bulb 26717-89900
