<-- Back to Grille
Datsun 1200 Sedans were originally fitted with a stainless metal grille. Early 1200 Pickups (1971-1977) use this too. The 1972 JDM facelift introduced a new grille, but it too was different from the plastic Coupe grille.
Original Grille
1970-1971 Sedan Grille. Early 1200 truck used this through March 1978. Export 1200s used this into 1978.
Head Lamp Rim
Headlamps surrounds aka eyebrow trim aka finisher
ASSY-RIM,HEAD LAMP, RH ASSY-RIM,HEAD LAMP, LH
SURROUND moulding-RADIATOR GRILLE, SIDE, RH SURROUND moulding-RADIATOR GRILLE, SIDE, LH
Emblems
For grille trim badges and part numbers, see Badges
Sedan grille "D" and "S" emblems (marks, badges):
- Japan market 1200s used "S" mark
- Export market 1200s used "D" mark
Stainless grille with Facelift Grille emblem
Fitting
Click for full size pictures of the grille mount points:
And the eyebrow trim mount points:
Fitting to Others
Fitting Sedan grille is done in Japan to many Datsun 1200 trucks (change from Coupe-type grille to Sedan grille). Also you can fit the Sedan grille to a Coupe.
- Fit one L-shaped bracket to center top of front body. The top of bracket should be 1/8" from top of ledge.
- Fit two thin brackets to back of sedan grille
- Drill four holes in radiator support to correspond to the holes in the sheet bracket
- Drill them 20mm to the side of the headlight rim screw holes
- Screw sheet loops to front of car
- Screw grille to sheet loop ends
Also see: POST demacoz changeover photos
Installing Round Headlights in Late Truck
Fit the headlight Rims (easiest to do with grille off car)
- coupe and late ute are missing the outer bracket:
- All core supports have the inner two eyebrow mount holes, though you may need to add the little square screw hole wedgies:
(1-3) ASS'Y-grille, radiator 62302-H1003 Sedan (exc. GX), Van, Truck DX -7803 $169.65 USD 62302-H2300 Sedan GX 62302-G1000 Truck STD [painted]
(14-19) ASS'Y-RIM, head lamp (Eyebrow Trim\head lamp Rim)
62320-G1000 STD SUNNY TRUCK RH 1971-1975 [NON-CHROME]
62321-G1000 STD SUNNY TRUCK LH 1971-1975 [NON-CHROME]
62320-H1002 chrome (R.H) $39.17 USD
62321-H1002 chrome (L.H) $39.17 USD
(20-25) Surround Trim Coupe, Sedan and Van, Truck 62322-H1001 SURROUND-radiator grille, upper $40.27 USD 62323-H1001 SURROUND-radiator grille, lower $27.13 USD 62324-H1051 SURROUND-radiator grille, side with rubber (R.H) $29.50 USD 62326-H1001 RUBBER-SURROUND,RADIATOR GRILLE (1 per side) 62325-H1051 SURROUND-radiator grille, side with rubber (L.H) $29.50 USD
Core Support Panels
1972 Minor Facelift
The 1972 Japan-market facelift introduced a new grille for sedans and vans. It featured a wire mesh insert. This was also used for South Africa production, while the rest of world continued with the original (stainless) grille.
62302-H7200 black GX with square mesh
62302-H3100 STD, DX and GL grille [Argent] with square mesh
67829 62302-H3100 Grille with honeycomb mesh
South Africa GX version with 'D' badge
1972 Sedan grille fitted to a coupe:
Emblems
Parts List
62380-H3215 inserts (2 needed)
cast marked "62380-H3100"
Customized
Grille with mesh headlight covers
