Datsun model series B210 was marketed in various countries as Datsun Sunny (Japan), Datsun B210 (North America) or Datsun 120Y/140Y/160Y (worldwide). For the Japan market, the minor update to the Sedan & Coupe was numbered B211 (DEC 1975).
Index
badge photo searchᴵ | auction searchᴳ | closed searchᴳ
Main Forum discussion: POST B210/120Y badges
post your photos!
Early is 1973-1975 Late is 1976-1977
#JDM Early Sedan![]()
#JDM Early Coupe![]()
#JDM Van![]()
#JDM Late Sedan (B211)![]()
#JDM Late Coupe (KB211)![]()
Early Sedan
#Radiator Grille #C-Pillar #Rear
Radiator Grille
back to #Early Sedan
The early sedan grille used 'S' mark, chrome with color-painted inlay. Approximately 6cm wide. Early Japan 'S' Badge DX, GL, GX all differ "S".
Similar: * (gold) #Late B210 sedan Radiator Grille badge * (various) Early B210 sedan Radiator Grille badge * (white) PB210 Radiator Grille badge
Japan ORNAMENT KIT-grille (Sedan, Van) [intertwined 'S' mark] #white 62312-H5025 Van STD #green 62312-H5026 S-DX, Van-DX (緑) #yellow 62312-H5125 S-GL, Van Super-DX (黄) #red 62312-H5225 S-GX (赤)
white
62312-H5025 ORNAMENT KIT-grille Van STD
green
62312-H5026 ORNAMENT KIT-grille S-DX, Van-DX (緑)
yellow
62312-H5125 ORNAMENT KIT-grille S-GL, Van Super-DX
yellow GL - Sedan S-mark (user-fitted to a coupe grille)
Red
62312-H5225 ORNAMENT KIT-grille S-GX
C-Pillar
back to #Early Sedan * One piece 'Sunny' + icon (Coupe uses two-piece emblems) Tie-clasp style
C-pillar 'Sunny'
Early catalog 76854-H5000 EMBLEM-body side (R.H.) 'Sunny' S-T 76855-H5000 EMBLEM-body side (L.H.) 'Sunny' S-T
Late catalog 76854-H5300 EMBLEM SIDE REAR RH 'Sunny' =STR 76855-H5300 EMBLEM SIDE REAR LH 'Sunny' =STR
EMBLEM SIDE REAR 76854-H5300 RH 'Sunny' 2S-STD
C-pillar 'Sunny Deluxe'
early catalog 76854-H5310 EMBLEM-body side (R.H.) 'Sunny DX' 2-DX 76855-H5310 EMBLEM-body side (L.H.) 'Sunny DX' 2-DX 76854-H5010 EMBLEM-body side (R.H.) 'Sunny DX' 4-DX 76855-H5010 EMBLEM-body side (L.H.) 'Sunny DX' 4-DX
late catalog 76854-H5010 RH 'Sunny DX' =T 76855-H5010 LH 'Sunny DX' =T 76854-H5310 RH 'Sunny Deluxe' =GT 76855-H5310 LH 'Sunny Deluxe' =GT
C-Pillar 'Sunny GL'
early catalog 76854-H5400 EMBLEM-body side (R.H.) 'Sunny GL' 2-GL 76855-H5400 EMBLEM-body side (L.H.) 'Sunny GL' 2-GL 76854-H5100 EMBLEM-body side (R.H.) 'Sunny GL' 4-GL 76855-H5100 EMBLEM-body side (L.H.) 'Sunny GL' 4-GL
late catalog 76854-H5100 RH 'Sunny GL' A12,A14.GL 76855-H5100 LH 'Sunny GL' A12,A14.GL
C-Pillar 'Sunny GX'
early catalog 76854-H5200 EMBLEM-body side (R.H.) 'Sunny GX' 76855-H5200 EMBLEM-body side (L.H.) 'Sunny GX'
late catalog 76854-H5200 RH 'Sunny GX' S.A14.GX 76855-H5200 LH 'Sunny GX' S.A14.GX 76854-H5400 RH 'Sunny GL' H=GT 76855-H5400 LH 'Sunny GL' H=GT
Rear
Left side trunk lid (Early only) #'NISSAN FULL AUTO MATIC' #'5 SPEED'
Center trim badges - also used by #late sedan #Rear 'SUNNY' SEMI-DX #Rear 'SUNNY deLuxe' #Rear 'SUNNY GL' #Rear 'SUNNY GX'
84811-H5020 EMBLEM-trunk lid 'NISSAN FULL AUTO MATIC'
Similar: * PB210_Badges#Sedan_Rear 84811-H5050 EMBLEM-trunk lid (NISSAN FULL AUTO MATIC) * Export_B210_badges#Rear 84811-H6220 EMBLEM-TRUNK LID 'NISSAN AUTOMATIC' 79855-N2200 MARK 'NISSAN AUTOMATIC' * Sedan_badges#Automatic 84821-U0300 'Nissan Matic' blue 79200-H2820 "Full Matic" 79200-H3200 79200-H1020 "Full Automatic"
'5 SPEED'
84811-H5210 EMBLEM-trunk lid '5 SPEED'
84811-H5210 (PB210 shown; badge is same as B210)
Rear Center Trim Badge
Center trim badges and finisher - also used by #late sedan
EMBLEM-rear panel 79805-H5000 #Rear 'SUNNY' SEMI-DX 79805-H5010 #Rear 'SUNNY deLuxe' 79805-H5100 #Rear 'SUNNY GL' 79805-H5200 #Rear 'SUNNY GX' 01352-00011 WASHER-sealing (2) 01221-00011 NUT-flange (2)
REAR PANEL FITTING 79801-H5100 FINISHER-rear GL,GX 79806-H5100 SPACER-rear finisher GL,GX (2) 1973-1975 26558-H5000 WASHER-PLAIN 1976-1977 01221-00011 NUT GL,GX (4) 1973-1975 01221-00071 NUT 1976-1977
Japan REAR PANEL FITTING (center of back panel finisher, between taillights)
Rear 'SUNNY'
79805-H5000 EMBLEM-REAR 'SUNNY' STR, SMDX
Rear 'SUNNY deLuxe'
79805-H5010 EMBLEM-REAR 'SUNNY deLuxe'
Rear 'SUNNY GL'
79805-H5100 EMBLEM-REAR 'SUNNY GL' * white background
Rear 'SUNNY GX'
79805-H5200 EMBLEM-REAR 'SUNNY GX' * approximately 105mm wide
Late Sedan
Early Coupe
Radiator Grille
ORNAMENT KIT-radiator grille
62312-H5525 JAPAN K-all ['S' shield-shaped mark]
62312-H5526 Export ['D' shield-shaped mark]
USA KIT-ORNAMENT RADIATOR GRILLE -0776
62312-H5525 JDM ORNAMENT KIT-radiator grille
Side
DX 'Sunny' + diamond badge GL 'Sunny' + 'GL' GX 'Sunny' + 'GX'
76855-H5500 EMBLEM-body side (L.H.) K-all 76854-H5500 EMBLEM-body side (R.H.) K-all
Rear
Japan Early Coupe rear center 79843-H5600 EMBLEM-rear finisher 'GL' 79843-H5700 EMBLEM-rear finisher 'GX' Early Coupe rear right side 79842-H5500 EMBLEM-rear finisher 'Sunny' Early Coupe left trunk lid 98042-H5700 BADGE '5 SPEED' 98042-H5600 MARK 'NISSAN FULL AUTO MATIC'
Late Coupe
Van
All vans in the Japan market were VB210 -- there was no VB211.
Late Van Badges (1976-1977 from October 1975)
Front
Van uses Sedan radiator grille emblems.
* Early![]()
* Late![]()
Side
Japan Early (to SEP 1975) 98811-H6500 EMBLEM-body side 'Sunny' (2)
Japan Late Van (from OCT 1975) Side EMBLEM SIDE REAR 98811-H6500 4V [same as early] 98811-H6700 *V-VA=T
Rear
JAPAN right side early/late van * Looks like early sedan badges but part numbers differ 98821-H6500 'Sunny' V.SMDX, V.STD 98821-H6501 'Sunny DELUXE' V.DX 98821-H6600 'Sunny SUPER DELUXE' V.SPDX
98821-H6600 (reverse side is marked '98821H6600')
left side lower 96905-18100 LABEL-loading capacity (400kg) Van
left side upper #84814-H7401 V.SMDX 'NISSAN' (84815) #84890-F2000 'NAPS' (84819)
Option
1973 B210 Options Catalog G8840-H5000 Badge (10 piece 1 set) 1,000 yen バッジ (10ケ1セット) B210, PB210 Option Parts C-203 page C3 G8840-H5000 Badge Star Mark バッジ スターマーク入
Please feel free to install it. Accent parts that add personality to your car.
Rear
Late B210 sedan & coupe shares some rear badges
Left side of trunk lid 84814-H7401 MARK-REAR 'NISSAN' Sedan,Coupe,Van 84890-F2000 MARK-REAR 'NAPS' Sedan,Coupe,Van![]()
Right side of trunk lid 84814-H7401 MARK-REAR '1400' Sedan, Coupe
エンブレム バッジ マーク
