PB110 lights
Revision as of 07:45, 12 March 2025; view current revision
Categories: PB110 | Body Electrical System
PB110 Sunny Excellent 1400
Tail Lights
Coupe
KPB110 looks like B110 sedan lights, but protruding
26405.jpgAlbum 26405 25854.jpgAlbum 25854 174_5b98f08d510ec.jpgPost 489434 174_5d586c4ba3cd9.jpgPost 492293 174_5d586c544b92b.jpgPost 492293 174_5d586ce668584.jpgPost 492293
SAE STIR 70 IKI 4042
25852.jpgAlbum 25852 25853.jpgAlbum 25853
174_5d587ebe00226.jpgPost 492294 174_5d587ed173781.jpgPost 492294 174_5d587eae70458.jpgPost 492294
174_5d587ed9c3fd6.jpgPost 492294 174_5d587ee374573.jpgPost 492294 174_5d587eec6ebd2.jpgPost 492294 174_5d587ef7bde46.jpgPost 492294
Sedan
Looks similar to the facelift B110 coupe lights - but are longer.
197106-2x.jpg 1535.jpgAlbum 1535
argent: 26650-H2801
20720.jpgAlbum 20720
dark: 26650-H3001
20721.jpgAlbum 20721
marked 'SAE STIR 70 IKI 4022L MADE IN JAPAN
25538.jpgAlbum 25538 25537.jpgAlbum 25537 25536.jpgAlbum 25536
26556-H2800 Lens center segment
26931.jpgAlbum 26931 26932.jpgAlbum 26932
26526-H2800 Lens outside segment
26930.jpgAlbum 26930
License Lights
KPB110 Coupe License Light
PB110 Coupe lamp assembly is same as KB110.
Datsun 1400 Coupe (KPB110) has dual license plate lights, tucked up under the bumper -- exactly the same as regular KB110 Datsun 1200 Coupe.
26510-H1800 includes all parts here
27800.pngAlbum 27800
Side Lights
Datsun Sunny Excellent 1400 (PB110) サイド マーカー ランプ
26929.jpgAlbum 26929 27070.jpgAlbum 27070
H25 SIDE LAMP [corner lamp]
H25 SIDE FLASHER LAMP
b74818330wansu_-img600x450-11744933.jpg b74818330wansu_-img600x450-11744-1.jpg b74818330wansu_-img600x450-11744934.jpg
h54938355wansu_-img600x450-11744-2.jpg h54938355wansu_-img600x450-11744-1.jpg h54938355wansu_-img600x450-11744894.jpg
K01 lights look similar (from Nissan 710 Violet) 26166-K0100
27066.jpgAlbum 27066 27069.jpgAlbum 27069 400px-Datsun_Violet_710_001.JPGWIKI go to Wikipedia 27067.jpgAlbum 27067 27068.jpgAlbum 27068
Fog Lights
Datsun Sunny 1400 had the Fog Lamps built into the grille.
174_5b98f05a2eb17.jpgPost 489434
28386.pngAlbum 28386
FOG LAMP
Note: H25 = KPB110 (1971)
Note: 265 = KP510 (1969)
30 26150-H2525 LAMP KIT-fog (op.) DX,GL 2
   26150-H2500 LAMP ASS'Y-fog GX, (op.) DX,GL <-O-> 26150-H2501 2
   26150-H2501 LAMP ASS'Y-fog (from '71-5) GX, (op.) DX,GL  2
31 26151-26501 * LENS (白熱) [incandescent] 2
32 26152-26500 * RIM 2
33 26153-26500 * PACKING 2 <-O-> 26155-H2501
   26155-H2501 * PACKING (from '71-5) 2
34 26718-26500 * BULB (incandescent) 2
35 08911-30810 * NUT M8 2
36 08915-13810 * WASHER M8 2
*37 62320-H2500 * BRACKET-fog lamp (R.H.)
    61321-H2500 * BRACKET-fog lamp (L.H.)
   fixing bracket
38   08513-51012 * SCREW, pan head M5x10 4
39   08915-13510 * WASHER, spring lock M5 4
40 25160-H1110 * SWITCH COMP.-lighting & fog
Reference: C-213 Parts Catalog Page 112-5
MASK (fog lamp delete plates) comes with the DX/GL174_61de5f6687837.jpg 174_61de82424a18a.jpg
Fog lamps have grille brackets. See Grille#PB110.
510
The PB110 fog lights are based on the Datsun 510. The 510 has two versions:
  1. grille mounted, with two-bolt housing that attaches directly the special grille. This version uses expensive quartz iodine lamps
  1. bumper mounted, like the PB110, with a post that bolts to a bumper bracket. Available in premium iodine or budget incandescent
62300-26505 510 OPTION grille
174_6132b17a0ec92.jpgPost 495802
510 Datsun Bluebird 1600 SSS
174_6132b5c825b36.jpgPost 495802
'Deluxe' fog lamp by Ichikoh
174_6132b18d15f3f.jpgPost 495802 174_6132b1a1c078a.jpgPost 495802 174_6132b1f0cb17f.jpgPost 495802 174_6132b17a0ec92.jpgPost 495802
The housing has a gold-colored reflector, which makes the clear lens appear yellow
174_6132b1b63dd05.jpgPost 495802
174_6132b210336f2.jpgPost 495802
ラヂエターグリル取付用 [for Radiator Grille mounting]
26150-26510 ASS'Y-LAMP, fog R.H. (沃素) [iodine] ¥3500
26155-26510 ASS'Y-LAMP, fog L.H. (沃素) [iodine] ¥3500
26151-26500   LENS-fog lamp [iodine]
26153-26500   PACKING-lens
26719-26500   BULB-fog lamp
26996-26510   SEAT-fog lamp A
26997-26510   SEAT-fog lamp B
本部品フォグランプはオプション用ラヂェターグリルに組込出来?????のむのです。
 ・ 市光工業直送取极い部品 [Ichikoh Industries direct delivery parts]
バンパー取付用 [for Bumper Mounting]
26150-26500 ASS'Y-LAMP, fog R.H. (沃素) [iodine] ¥3500
26150-26501 ASS'Y-LAMP, fog R.H. (白熱) [incandescent] ¥920
26151-26500   LENS-foglamp (沃素) [iodine]
26151-26501   LENS-foglamp (白熱) [incandescent]
26719-26500   BULB-fog lamp (沃素) [iodine]
26718-26500   BULB-fog lamp (白熱) [incandescent]
26996-26500   SEAT-bracket
本部品フォグランプはバンパーに取付けられ沃素??と白熱??が?ります。 (スイッチ 25919-89905) 尚、?のセダン缶?車にも取付出来ます。
Front Turn Signal Lamp
Unlike the 1200's Front Combination Lamp, the 1400 lamp only has a single element for the Turn Signals.
Type H25
26929.jpgAlbum 26929 26933.jpgAlbum 26933 26934.jpgAlbum 26934 26935.jpgAlbum 26935
Lamp assy has single wire for the single-contact bulb 26717-89900
26936.jpgAlbum 26936 26937.jpgAlbum 26937 26938.jpgAlbum 26938
