Jack
Revision as of 17:23, 31 August 2025; view current revision
Categories: Wheel And Tire | Maintenance And Daily Care
Datsun 1200s were equipped with an easy-to-use scissor-type jack. It shipped in the boot (sedan and coupe) or attached to the passenger's seat (truck and van).
See also: Changing tire
Sedan & Truck jacks differ only by the diagram (sticker) on the jack.
14997.jpgAlbum 14997 24944.jpgAlbum 24944
Cautions
27446.jpgAlbum 27446
CAUTIONS (Details: See owner's manual)
  1. Use this jack on this vehicle only.
  2. Set parking brake firmly and set automatic transmission in "P", manual transmission in First or Reverse.
  3. Use #wheel chocks or blocks to fix other wheels.
  4. Place jack at #jack-up points only.
  5. Never jack up more than necessary.
  6. Never get beneath vehicle when it i supported by jack.
  7. Never use blocks on or under jack.
  8. Park on hard level surface.
Jack-up Points
1972 USA Owners manual (Page 27 ... 27):
There are four jack-up points at the floor panel
1974 B120 Owner's Manual (Page 25 ... )
Jack-up Points
You can jack-up the 1200 at these points
Using OEM jack (see Owners Manual above):
Be sure to use a Nissan /Toyota/Subaru jack with a "slot" to fit over the rocker panel seam. Jack here, at the point of the the half-round indents:
22909.jpgAlbum 22909
Using other jacks:
  • Under lower A-arm (Transverse link), near tire
  • Middle of engine crossmember (lift entire front end)
  • center of Differential (lift entire rear of car)
  • Outboard ends of rear axle housing
CAUTION: Before sliding underneath the car, be sure to place jackstands under the suspension. In a pinch a tree stump or beefy timber can work. Make certain it is secure, and lower the weight of the car on the jackstands.
Also useful when removing/reinstalling transmission
19064.jpgAlbum 19064
Standard Equipment
  • Scissor Jack
  • S-shaped Jack Handle
  • Wheel Wrench in black 'Nissan' tool bag
  • Tire retaining clamp (sedan and coupe)
14996.jpgAlbum 14996 14999.jpgAlbum 14999
1976 Aussie Pick-up
13022_4e05ba78a6a52.jpgUpload click to view
Tools
1200 Factory Tool Kit was option and the contents vary by year and region.
See #Part Numbers section below
also see #Alternative Datsun Jacks
1976 AUS tool kit
13022_4e05ba6b42f35.jpgUpload click to view
#Wheel Stops
23615.jpgAlbum 23615
Jack Location
The Jack and its equipment is stored in special place.
  • For sedans and coupes, the jack is stored in the trunk. Sedan uses a hold-down clamp, while Coupe uses a fixed bracket (the opposite of usage for B10).
  • For vans and trucks, the jack is store under the passenger side seat
Coupe
The Jack and its equipment is stored in the Trunk (Boot) on the left side against the fender. It is usually covered by the coupe trunk trimming side panel.
20355.jpgAlbum 20355
30533.jpgAlbum 30533
Sedan
The Jack and its equipment is stored in the Trunk (Boot). Sedan uses a hold-down clamp in the spare tyre well, to the right of the tyre.
6277.jpgAlbum 6277 14995.jpgAlbum 14995
Truck
The ute Jack is stored POST under front of passenger's seat.
1974 B120 Owner's Manual (Page 24 ... 24)
The tools and jack components are stored in the storage compartment as shown. The tool bag is stowed under the assist seat.
25791.jpgAlbum 25791
Ute_floor_bracket
174_5162019f33c46.jpgPost 434087
Mounts similar to this VB310 jack:
Sunny_Truck jack handle features tabs going other way truck | sedan/coupe
174_5d2bec08e4e66.pngPost 491899 174_5d2bebefeede4.jpgPost 491899
13022_4e26dfc5c0586.jpgPost 376683 13022_4e26dfd098bab.jpgPost 376683
24945.jpgAlbum 24945 174_5d2bed6107585.jpgPost 491899
174_5d2bed69c5c65.jpgPost 491899
Wagon
Wagon jack fits in front of passenger seat.
27057.jpgAlbum 27057 27056.jpgAlbum 27056
120Y wagon VB210 jack mount in engine bay
Sunny van VB310 jack
174_5d2cbce791641.jpgPost 491905
運転席下の邪魔にならない場斫にセットされたジャッキ。いざというとき、すぐに取り出せます。 Jack set in place out the way under the driver's seat. When it is emergency, it can be taken out immediately.
Datsun B10
1000 Sedan
13868.jpgAlbum 13868
Upgrades
Roller Jack Handle
Nissan jack handle with built-in rollers (no more pinched hands!). Source one from a more luxurious Datsun or Nissan. I got mine from a 1985 S12.
23428.jpgAlbum 23428
Wheel Stops
From B310 and many other Datsuns:
  • 99595-H7400 TIRE STOPPER
23615.jpgAlbum 23615 23616.jpgAlbum 23616
Tool_Kit_Part_Numbers
ジヤッキ、パンタグラフ タイパ゚ ハンドル、ジヤッキ クランク
Part Codes: 99610, 99611
  • 99550-H1000 SET-JACK B110 $74.14
  • 99553-H1400 HANDLE-JACK CRANK VB110P, B120 [right-angle]
    • looks similar to 99552-D0100 U11
  • 99551-G1400 JACK-PANTOGRAPH TYPE B120
  • 99595-18000 BAG-TOOL $3.89
Others
  • 99504-50Y00 bag-tool $4.14
  • 99501-01A00 tool kit-complete with jack $118.12
  • 99552-01G00 rod-jack D22 [straight] $17.25
  • 99553-01W00 Handle Jack 280ZX [crank] $9.33
  • 02996-01100 handle-jack 310/810 [with plastic roll surfaces] $19.33
  • 99595-H7400 tire stopper 810 [non-folding]
  • 99595-U1400 tire stopper 280ZX [folding type] $24.30 [99595-F2700]
  • 99545-8B400 Wrench-wheel Nut & jack handle Frontier $32.88
99596 oil filter wrench bag
99547 oil filter wrench
99548 oil filter wrench handle
99540 spark plug wrench
99512-25660 HAMMER
 99509-Z0000
Datsun 910
99545 wrench
02995-45200 WRENCH-WHEEL NUT
99610 jack
02996-10421 JACK-PANTOGRAPH TYPE sedan [groove type a la B110]
02996-01631 JACK-PANTOGRAPH TYPE wagon [finger type]
99595 wheel stop
99595-H7400 sedan [fixed type] (2)
99595-U1400 wagon [folding type] (1)
* 99595-F2700
99596 Tool bag
02995-95300 BAG-TOOL
99614 jack handle
02996-01100 HANDLE-JACK LEVER 910 sedan
99613 jack handle, 2-piece
02996-03200 ROD-JACK HANDLE wagon
99612 jack crank
02996-02100 HANDLE-JACK HANDle wagon
99501-89903 TOOL SET-STANDARD
Includes:
* 99545 wrench
* 99596 tool bag
U11
995 TOOL KIT
99501 TOOL SET-STANDARD
 99596 bag
 99535 phillips driver
 99545 lug wrench
 99525 pliers
 99507 spanner
 99507 spanner
02995-07100 spanner 8x10
 99507-01A00
02995-07300 spanner 12x14
 99512-01A00
02995-25100 PLIER
 99525-01A00
02995-30300 SCREWDRIVER/DRIVER-PLUS & MINUS [phillips + regular]
 99530-50Y00 $6.12 USD
 * S13, R50 USA
Not recommended. Shocking
10192.jpgAlbum 10192
620 Pickup: rotary type for heavy loads
282757_10150322612682387_507737386_9967102_5395102_n.jpg 526210_860298009146_41507110_36291832_659386670_n.jpg
521 pickup handle
Long & Short handle (long one is for pickup)
1970-1976 S30 Tool Kit
1977-1978 S30 Tool Kit
280ZX Tool Kit
ジャッキ
