Datsun 1200 used two types of Propeller Shaft:
- Replaceable U-joints up to 0273
- Non-replaceable, from 0373
If your tailshaft has snap rings (C-shaped circlips) holding the U-joints in, they are replaceable.
Automatic driveshaft/tailshaft assembly differs from Manual Transmission. Automatic transmissions are 15mm shorter than a standard transmission, so the automatic shaft slip yoke is 15mm longer. The yoke is the part that is different. The shaft and flange are identical.
Interchange:
- B210 with H145 Differential uses the same tailshaft
- B210 with H150 diff use different shaft
- B120 with H165 differential (PB210) *may* be same as B310 two-piece shaft (?)
- Longbed Trucks use a 2-piece tailshaft
See Propeller Shaft Swaps for:
- Part Numbers
- Specifications, including length
- Swap information
Parts Numbers
B110
Shaft Assembly - Manual
- 37000-H1001, 37000-H1000 4-speed 56 to 0872
- 37000-H3100, 37000-H1011 4-speed 56 from 0973
- 37000-H3100 4-speed 56 from 0373, "Shell" type (non-replaceable U-joints). Same as B210 with H145 diff
Shaft Assembly - Automatic
- 37111-20300
U-joint Assembly
- 37125-H1025, 37125-18025
Slip Yoke
- 37111-18001 manual
- 37111-20300 automatic
Flange (that bolts to H145 differential)
- 37117-18000 (30mm from center of u-joint to end of flange)
B120
- 01111-00051 BOLT-FIX PROPELLER SHAFT (4)
GB
Long Box
- 37000-G1410 SHAFT ASS'Y-PROPELLER 7510-9204
- 37000-95W00 SHAFT ASS'Y-PROPELLER 9204-
- 37521-Y0125 BEARING KIT-CENTER 7510-9204
- Sunny, 610/710/810, 200SX
- 37521-W1025 BEARING KIT-CENTER 9204- $146.58
- 37525-P0101 CUSHION-CENTER BEARING [included in Bearing Kit] $12.63
- 37163-G1400 NUT 7510-7712 (1)
- 37163-G1401 NUT 7801- (1)
- 38215-61001 WASHER-LOCK (1)
- 37510-G1401 BRACKET-CENTER BEARING [lower clamp] 7510-8503
- 37510-G1402 BRACKET-CENTER BEARING 8504-
