Lamps, lights. Parking lights, running lights. Whatever you call them, Datsun 1200s have them.
Also see:
Headlights
Large round headlights from *any* car will fit. These are type 6012/6014 for a two-headlight system (a single large round headlight on each side of the car). These are "dual beam" lights (two-filament), encompassing both regular and high-beam in the same light.
Note that the original specification 6012 headlamp is only 50W/40W. You can substitute the brighter 6014 which is 60W/50W. Type 6015 is a longer-life bulb, but more expensive.
USA 1972 Owners manual (see page 36 for headlight specification):
Alternatively, and recommended, H6024 (65W/35W) is a halogen replacement. Halogen is a brighter light, and now available in shades of blue, gold, white. Street-legal in USA.
The brighter 6014 is as inexpensive as $3. See RockAuto headlights for Datsun 1200
| Type | Spec. | Comments |
| 6012 | 50/40 watt | Original spec. |
| 6014 | 60/50 watt | replaces 6012 |
| H6014 | 60/50 watt | Halogen |
| 6015 | 60/50 watt | long-life |
| H6024 | 65/35 watt | Halogen |
| H6024 XV | 65/55 watt | Extra-bright, long life |
- USA Koito
- 26705-89905 UNIT-SEALED BEAM (KOITO brand)
- 26060-H1611 ASSY-LAMP HEAD LH
- 26010-H1610 ASSY-LAMP HEAD RH
- USA Ichikoh
- 26705-89925 UNIT-SEALED BEAM (ICHIKO brand), formerly 26705-04201
- 26010-H1900 ASSY-LAMP HEAD RH(ICHIKHO) from 0570
- replaces 26010-H1600 ASSY-LAMP HEAD RH
- 26060-H1900 ASSY-LAMP HEAD LH(ICHIKHO) from 0570
- replaces 26060-H1600 ASSY-LAMP HEAD RH
Headlight Terminal boot
- 26029-A4601 COVER-TERMINAL from 0570
- replaces 26029-A4600 COVER-TERMINAL
- JDM Ichikoh (市光)
- 26705-H1000 UNIT-sealed beam
- 26010-H1000 ASS'Y-LAMP, head (R.H.)
- 26060-H1000 ASS'Y-LAMP, head (L.H.)
- Aduster Hardware Ichikoh (市光)
- 26022-H1000 SCREW-adjust (4)
- 26023-H1000 NUT (4)
- 26024-58000 SPRING (2)
- Or 26024-H1000 (from 0671)
- 26107-14801 RING-retaining
JDM Koito (小糸)
- 26705-08700 UNIT-sealed beam
- 26010-H1011 ASS'Y-LAMP, head (R.H.)
- 26060-H1010 ASS'Y-LAMP, head (L.H.)
- Aduster hardware Koito (小糸)
- 26022-H1010 SCREW-adjust (4)
- 26023-H1010 NUT (4)
- 26024-H1010 SPRING (2)
- Or 26024-H1011 (from 0671)
- 26107-18010 RING-retaining
High-power Headlamps
H4 euro-type, Halogen, etc that require upgraded wiring.
Side Lights
- Side lamps come in two sizes: small and large
Side lamps are larger on North American models, also the fenders come with a larger hole to match. Euro/Asia guards/wings can be used on America 1200s, if the hole is enlarged.
Other countries - Small running lights
Front Lights
- Front running light lenses are either all-orange or white + orange
Reportedly the lamp housing is different so that you cannot simply swap lenses.
Sedan:
Coupe and Sedan front lights are the same.
Coupe:
Rear Lights
Rear light lenses are either:
- orange-red-white, white-red-orange
or
- red-red-white, white-red-red
Orange & red: Australian market, while all-red in America, Japan and South Africa markets.
Coupe: long and thin. Sedan: short but tall:
Sedan (Europe) - orange blinkers
Later GLs used a different taillight:
Possibly it was the same as Coupe or PB110, but with a different trim surround:
Rear License Plate Lamp
For USA market, the rear number plate light changed in 1973 to meet higher government standards of illuminating the plate.
Early license plate lamp (on top of bumper):
Late license plate lamp (dual lamps on either side of plate):
Customized Lights
- Square headlights
- Quad headlights
- Clear lamp lenses
- All-red rears
- White-outside rears
- Coupe rear lights on Sedan
- Supra lights on Coupe:
Driving Lights
fog lights, etc
Operation
Headlight Switch
See: Instrument and Controls#Switches
Turn Signal Switch
T/S switch
Interior Lamps
The middle position operates from the door switches (if equipped).
USA 1972 Owners manual (see page 6 for Interior Lamp):
To switch the interior lamp "ON", and "OFF", turn the switch lever clockwise or counterclockwise.
alternative interior headliner light
Replacing Procedure
USA 1972 Owners manual (see pages 36-38 for replacing details):
headlights:front & rear:
license lamp & side lamps:
Lamp Specifications
| Spec. | SAE No. | Nissan^ | |
| Headlight unit | 12V-50/40W | 6012 | see above |
| Direction and Parking | 12V-23/8W | 1034 | 26717-89920 |
| Side marker | 12V-8W | 67 | 26715-89902 |
| License plate | 12V-7.5W | 89 | 26715-89901 |
| Rear combo. Light Taillight Stop (brake) Turn signal Back-up light | 12V-23/8W 12V-23/8W 12V-23W 12V-23W | 1034 1034 1073 1073 | 26717-89920 26717-89900 |
| Meter illumination | 12V-1.7W (round gauge) | 161 | 26711-89900 |
| Wiper Knob illumination (1973) | 12V-3.4W | 158 | ? |
| Heater control ill. (1973) | 12V-3.4W | 57 | ? |
| Ignition warning | 12V-1.7W | 161 | 26711-89900 |
| Turn Signal indicator | 12V-1.7W | 161 | 26261-89902 |
| Headlight beam ind. | 12V-1.7W | 161 | 26711-89900 |
| Oil press. warning | 12V-1.7W | 161 | 26711-89900 |
| Brake warning | 12V-1.7W | 161 | 26711-89900 |
| Room light | 12V-10W | n/a | 26736-89902 |
^from USA catalog, all are ICHIKO brand
USA 1972 Owners manual (see page 36 for bulb specifications):
- Exterior single element, one bottom contact
- Rear T/S (turn signal)
- 23 watt (North America) Sylvania 1156 Wagner 1156
- 21 (other countries)
- Exterior dual element, two bottom contacts
- Front park & T/S, Rear Tail & Stop
- 23/8W (North America) Sylvania 1157 Wagner 1157
- 12/5 watt (other countries)
- FUSE, 10-AMP (2 needed) 08941-11000
- FUSE, 15-AMP (4 needed) 08941-11500
- 1972-1973 Seat belt light (on top of dash) Toshiba 12V 10W Type SV8.5 31mm long
- 26945-H4600 (not sure if this lamp only, or whole unit)
- Dome lamp - 10 watt (room lamp) 26736-89902
- Type SV7, ~29 mm long (pictured) seems to fit best, but are usually 3w or 5w
- Parts stores specify the larger unit (see above Wagner 12100, Sylvania DE3175) which is readily available
- Instrument Panel lamp with twist-lock holder (7 used in round dash)
- 26260-89900 Wedge Socket (7 total for round gauge) $3.28 each
- 1.7 watt bulb (ROUND GAUGE) 26261-89902
- 3.4 watt (Square Gauge) Type 158 14V
- NOTE: Type 159 is identical looking, but only 1.0 watt 6.3V
- Exterior Lamp
- Side-marker lamp
- 8 watt (North America, non-flashing)
- Wagner 97 Sylvania 97 (9.32 watt nominal)
- 6 watt (flashing, non-North America)
- License lamp Sylvania 1895 Wagner 1895 (3.78 watt)
- 10 watt (Sedan, except North America)
- 7.5 watt Coupe, Van 26715-89901 Ichikho
- 7.5 watt Sedan USA
- Bailey B29.012.625 (7.5w) or [Toshiba A12V8W 6 7]
- Reverse light - 10 watt
- Side-marker lamp
- Instrument Panel Turn Signal indicator (2 needed)
- (not shown) 26260-H1800 SOCKET-WITH LEAD WIRE
- 26711-89900 1.7 watt (ROUND GAUGE) 3.4 watt (Square Gauge)
