Tail lights, tail lamps, or as Nissan calls them "rear combination lamps", combines the running lights, brake lamps (stop lights) and turn-signal lamps (blinkers). USA lights have no yellow section as it was forbidden by US law in the 1970s.
Sedan
Facelift
1972 Japan-market models had new tail lamps:
Coupe
Coupe tail lights have a silver, light gray, or dark gray surround in the chromed rim.
Custom
Wagon
1000
See main article: B10 Lights
Pickup
Datsun 1200 (Pickup) has three-segment rear lamps:
- Bottom section is clear for backup lights
- Middle section is red for running lights
- Top section is for turn signals: Red for older ones, Yellow or newer models. Aftermarket clear lenses are available.
The lens frames were offered in various styles:
- 1971-1977: were originally silver
- 1978-1989: changed to black
- 1989-up: changed to x?
Export
JDM vs Export
Round reflector section varies in size
輸出用 - Export , small reflector
国内 - Domestic, larger reflector
Aftermarket Ute
Custom
ストップラ ランプ レンズ ウインカー テールレンズ テール レンズ
