63-Series Transmission Part Numbers
From Datsun 1200 Club
Categories: Transmission Modifications | Clutch | Transmission
<-- Back to 63-Series Transmission
FS5W63A -- larger and stronger than the other A-series gearboxes -- were fitted to some B210 Sunny.
Rebuild Kit
Timken Rebuild Kit (includes bearings and synchro baulk rings)
TRNFN350 for FS5W63A
Output Shaft Seal
* TIMKEN 3771 F4W63, F4W63A, F4W63L, F4W71B, R4W71A $4.04
Service Manual
Datsun Model 1976 B210 Series
Chassis And Body
Supplement 1 5-Speed Transmission Type FS5W63A
Assembly
For A-series Engine (FS5W63A)
* 32101-H7320 Transmission Case, 1976-1978 5-speed B210 Coupe
* 32130-N5809 Rear ASSY-EXTENSION, 1976-1978 5-speed B210 Coupe
For L-series Engine (FS5W63A)
* 32101-N6810 Transmission Case, S10 (formerly 32101-N6800)
* 32130-N6809 Rear ASSY-EXTENSION, S10
* 32101-N6810 Transmission Case, 1977-0679 A10 (formerly 32101-N6800)
* 32101-W0411 Transmission Case, 0779-up A10
* 32130-N6809 Rear ASSY-EXTENSION, -0679 A10 USA
* 32130-N9009 Rear ASSY-EXTENSION, -0679 A10 Canada
* 32130-W7100 Rear ASSY-EXTENSION, 0779- A10 USA
B211 JDM
32010-H7510 TRANSMISSION ASSY A14
32010-N7400 TRANSMISSION ASSY L16S
32703-N9016 PINION-SPEEDOMETER 16T L16S
32703-N9018 PINION-SPEEDOMETER 18T A14
32703-N9019 PINION-SPEEDOMETER 19T A14
32707-14600 SLEEVE-SPEEDOMETER
* 32708-18000 WASHER-SPEEDOMETER PINION
* 32709-14600 RING-O
* 32873-14600 PIN-RETAINER SPEEDOMETER
32718-14600 PLATE-LOCK
Case
The case includes the "bell" and contains the front half of the gearset.
Left to right: Front Cover, oil seal, Case, Adapter Plate
174_5c4ba4c9b94c9.pngPost 490431
In the parts catalog the "Case" section covers externally visible parts including the extension housing.
174_5c4ba4e531714.pngPost 490431
S10: 32101-N6810 CASE-TRANSMISSION L20B USA
* superceded 32101-N6800
B210: 32101-H7320 CASE-TRANSMISSION USA
B211: 32101-N6700 CASE ASSY-TRANSMISSION A14S JDM
B211: 32101-N6800 CASE ASSY-TRANSMISSION L16S JDM
PB210: 32101-N9001 CASE-transmission L14 (from '74-9) JDM
* replaced 32101-N9000 (to '74-8)
B211 JDM
30501-K0400 SLEEVE-CLUTCH RELEASE L16S
30501-K0400 SLEEVE-CLUTCH RELEASE A14
30531-B5050 LEVER-WITHDRAWAL L16S
30531-K0550 LEVER-WITHDRAWAL a14
30534-E9000 SPRING-RETAINER WITHDRAWAL LEVER
30537-21010 PIN-BALL WITHDRAWAL LEVER
30542-N9000 COVER-DUST WITHDRAWAL LEVER
32005-21000 SWITCH ASSY-REVERSE LAMP
32113-N2101 SEAL-OIL FRONT COVER
32130-N6809 EXTENSION ASSY-REAR
38322-H7200 BREATHER
24210-89922 CLIP
32133-18000 PIN-DOWEL REAR EXTENSION
32135-28600 COVER-DUST SLEEVE YOKE
32136-U0100 SEAL-OIL REAR EXTENSION
32137-N9000 PLATE-ADAPTER
32121-N9000 RETAINER-BEARING
Front Cover and oil seal
32110 32111-N9005 COVER ASSY-FRONT
32113 32113-N2101 SEAL-OIL FRONT COVER [63A and 63 4-speed]
08120-83062 BOLT (8) [M8 x 30 copper finished?]
174_5c4ba4c9b94c9.pngPost 490431 174_5c4ba4bf74f4e.jpgPost 490431
Release Lever
30542-E9000 $9.48
Newer clutch fork dust cover is slightly different than the A-series part but works
16773_5c5f4a4a250a8.jpgPost 490537 26745.jpgAlbum 26745
1979-1982 S110 "200SX" Z20E, Z22E
1983-1988 S12 "200SX" CA18ET, CA20E, VG30E
1980-1986 720 L20B, SD22, SD25, Z20, Z22, Z24, Z24I
1980-1984 910 "810" L24E, LD28
1986-1992 D21 "Hardbody" KA24E, Z24
1987-1990 Van Z24I
Gearset
18480.jpgAlbum 18480 18481.jpgAlbum 18481
From 1978 B210 parts catalog (Japan Market version)
* 32604-P0100 RING-BAULK (5) FS5W63A 5-speed JDM B210
** Same number listed in USA catalog
B211 JDM
32200-N6700 GEAR ASSY-MAIN DRIVE A14
32200-21100 GEAR ASSY-MAIN DRIVE L16S
32203-N9000 BEARING-MAIN DRIVE
RING-SNAP MAIN GEAR DRIVE
* 32204-08000 SELECT T=1.49-1.55
* 32204-08001 SELECT T=1.55-1.62
* 32204-08002 SELECT T=1.62-1.68
* 32204-08003 SELECT T=1.68-1.74
* 32204-08004 SELECT T=1.74-1.80
* 32204-16500 SELECT T=1.80-1.86
* 32204-16501 SELECT T=1.86-1.92
32205-08002 SPACER-BEARING MAIN DRIVE RETAINER
32210-N7400 GEAR ASSY-COUNTER L16S
32210-N9000 GEAR ASSY-COUNTER A14
32223-N9000 BEARING-COUNTER SHAFT
32220-N9000 GEAR-REVERSE COUNTER 15T
RING-SNAP COUNTER SHAFT
* 32222-N9000 SELECT T=1.65
* 32222-N9001 SELECT T=1.45
* 32222-N9000 SELECT T=1.85
WASHER-THRUST COUNTER SHAFT FRONT
* 32225-N9000 SELECT T=1.350
* 32225-N9001 SELECT T=1.375
* 32225-N9002 SELECT T=1.400
* 32225-N9003 SELECT T=1.425
* 32225-N9004 SELECT T=1.450
* 32225-N9005 SELECT T=1.475
* 32225-N9006 SELECT T=1.500
* 32225-N9007 SELECT T=1.525
* 32225-N9008 SELECT T=1.550
* 32225-N9009 SELECT T=1.575
* 32225-N9010 SELECT T=1.600
* 32225-N9011 SELECT T=1.625
* 32225-N9012 SELECT T=1.650
* 32225-N9013 SELECT T=1.675
* 32225-N9014 SELECT T=1.700
* 32225-N9015 SELECT T=1.725
* 32225-N9016 SELECT T=1.750
* 32225-N9017 SELECT T=1.775
32221-N9000 WASHER-THRUST COUNTER SHAFT REAR
RING-SNAP OVER DRIVE BEARING
* 32228-20100 SELECT T=1.1
* 32228-20101 SELECT T=1.2
* 32228-20102 SELECT T=1.3
* 32228-20103 SELECT T=1.4
32230-N9000 GEAR ASSY-1ST 36T
32234-36900 RING-SNAP SHIFTING INSERT
SHAFT-MAIN
* 32241-N7400 L16S
* 32241-N9000 A14
32354-A7400 NUT-MAIN SHAFT
32720-14600 BALL-STEEL
32720-36900 BALL-STEEL
32245-N9000 GEAR-REVERSE MAIN SHAFT
26746.jpgAlbum 26746
Reverse/Idler, Reverse Gear and 1st Gear are in the extension housing
20677_5c78c57640b33.jpgPost 490701
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=63-Series_Transmission_Part_Numbers"
This page has been accessed 6,097 times. This page was last modified 09:59, 1 March 2019. Content is available under Datsun 1200 Club.
