910 Brakes
From Datsun 1200 Club
Category: Brake Modifications
910 (Bluebird/Maxima/810) Brake Rotors can be modified to bolt to the back of the 1200 hub. The rotor's PCD needs to be modified from 95mm to 87mm.
Usage
USA: 250 mm (same as the smallest S13 size)
EUR: 238 mm
JAP: 250 mm or 238 mm
250 mm
Nissan 40206-W1210 40206-W1260 40206-W1265  40206-W1270
Girling 6019401
Brembo 09.4789.10
* height: 22mm
* center hole: 73 mm
* PCD: 4 on 95 mm, 10.7mm holes
* thickness: 18mm
* weight: 4.13 kg
* also used by EUR C120, JAP C120
238 mm
Nissan 40206-W1010 40206-W1060 40206-W1070
* 238 mm
* height: 22mm
* thickness: 18mm
* also used by JAP C120, EUR C120
Rear Discs
Maxima rear Calipers and Sentra 240mm rotors (N13?) can be modified for use on the H165
Which Maxima is it?
A32 EUR
43206-31U12 5-lug
J30 EUR
43206-88E01 5-lug
43206-88E03
Other Rotor
GC22 rotor on Bluebird Strut/Hub
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=910_Brakes"
This page has been accessed 6,264 times. This page was last modified 08:28, 29 August 2016. Content is available under Datsun 1200 Club.
