Bed
From Datsun 1200 Club
Category: Sunny Truck
Datsun 1200 B120 pickup came with integral cargo well (pickup bed/cargo bin). This bed/tray/bin is once piece with the body. Most dirt bikes fit with about half the tire hanging over the tailgate.
See Also
16464.jpgAlbum 16464
Bikes
From little bikes to big bikes, the 1200 ute has got guts.
See Main Article: B120 Bike Carrier
Hauling
500kg payload
See Main Article: Hauling
Capacity
14128.jpgAlbum 14128
Loading Capacity Label '最大積載量500kg' (Maximum payload 500kg), see Badges
16772.jpgAlbum 16772
B140 Net Load Capacity 591 kg.
GCM 1750 kg
GVM 1349 kg (Standard LDV)
GVM 1360 kg (Champ)
In New Zealand it was marketed as a 1/2 Tonne:
21501.jpgAlbum 21501
Measurements
The Long Body 1200 tray is 295 mm longer than the regular Short Body.
LoadBox 1518 x 1285 x 415
Length Short Bed
* at bottom of tray: 1670 mm; 2060 mm tailgate down
* level with tray top: 1565 mm length
Length Long Bed
* at bottom of tray: 1960 mm
* level with tray top: 1860 mm
Depth:
* 415 mm regular bed
* 420 mm Long bed
Inside Width
* 1285 mm
* Between wheelwells: 980 cm
Bed height from ground
* 795 mm regular bed
* 575 mm long bed
Rope Hooks
The tray hooks are welded on 4 each side. Long body has 5 each side.
23219.jpgAlbum 23219
The tray "lip" is part of the body inner side panel, not part of the quarter panel (outer side panel).
Removing
Shaved tray rails
backofute.jpg 22344.jpgAlbum 22344 7160.jpgAlbum 7160
Your typical de-hookian operation involves:
  1. Cut off the tray lip
    14468.jpgAlbum click to view 14467.jpgAlbum click to view
  2. Weld inner panel to outer panel
    16339.jpgAlbum click to view 16340.jpgAlbum click to view
  3. Cover weld with smooth body putty
    15251.jpgAlbum click to view 20266.jpgAlbum click to view
  4. Re-paint
    14820.jpgAlbum click to view 14236.jpgAlbum click to view
Or you can grind the hooks off, but leave the lip:
2575.jpgAlbum 2575
You can also put new hooks out of site:
20575.jpgAlbum 20575
Sometimes the Rain Gutter is shaved at the same time:
14606.jpgAlbum 14606
Sometimes the Tailgate handles are shaved and gate welded into the body:
15249.jpgAlbum 15249 16005.jpgAlbum 16005
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Bed"
This page has been accessed 16,032 times. This page was last modified 18:32, 9 February 2017. Content is available under Datsun 1200 Club.
