Carburetor Inspection
From Datsun 1200 Club
When your carburetor is worn out, buying a used one is a good option -- if you know what to look for. Follow these inspection guidelines to to weed out bad carburetors.
When buying a used carburetor, look it over carefully for signs of trouble. Then buy only from sellers that will take refunds. Most wrecking yard will refund the price if it turns out to be faulty -- but ask first.
Look for:
* Air cleaner stud threads not damaged
* Screws look new, not over tightened, distorted
* Shafts are tight
* Grease/oil is OK, it will clean up
* No rusty linkage
* Throttle opens fully
Bad - air cleaner stud broke off
24149.jpgAlbum 24149
Screws - should look good, not reefed (overtightened/distorted)
24150.jpgAlbum 24150
Throttle blades should open fully -- not stuck
24151.jpgAlbum 24151
Greasy crud can be OK, if it cleans up. Avoid Rusty crud.
Vacuum diaphragms should hold vacuum -- see Vacuum_Leaks#Use_Your_Finger_Method
2211.jpgAlbum 2211
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Carburetor_Inspection"
This page has been accessed 9,234 times. This page was last modified 22:18, 1 August 2017. Content is available under Datsun 1200 Club.
