Daily Care
From Datsun 1200 Club
Category: Maintenance And Daily Care
<-- back to Owners manual
Daily Care is a section in the owners manual.
Introduction
1972 USA Owners manual (Page 21 ... 25):
Daily Care
Before driving or whenever you call at a gas-station, be sure to check the following items.
  1. Fuel tank
  2. Engine oil
  3. Battery
  4. Radiator coolant
  5. Tire pressure, wear and scars
    Recommended tire pressure: See page 26.
  6. Directional indicators, horn and all lights and switches for proper operation.
  7. Windshield washer fluid level
  8. Leakage and amount of fluid in brake and clutch master cylinders
  9. Clutch and brake operation
  10. Steering wheel play
29381.jpgAlbum 29381
1974 B120 Owner's Manual (Page 19 ... 23)
DAILY CARE
  1. Keep the gas tank filled.
  2. Check the engine oil.
  3. Check the battery.
  4. Check the radiator coolant.
  5. Check tire pressure, wear and scars.
  6. Check directional indicators, horn and all lights and switches for proper operation.
  7. Check the windshield washer fluid level.
  8. Check leakage and amount of fluid in brake and clutch master cylinders.
  9. Check clutch and brake operation.
  10. Check steering wheel play.
Opening the Hood
See also: Hood
1972 USA Owners manual (Page 21 ... 21):
OPENING THE HOOD
Pull the hood lock handle located at the lower area of the instrument panel.
Release safety catch located under the center edge of the hood and raise the hood and set the hood stay.
1974 B120 Owner's Manual (Page 18 ... 18)
OPENING THE HOOD
HOOD LOCK
Be sure to check the hood closed firmly functioning hood lock mechanism. Lubricate hood lock assembly every 9,000 km (6,000 miles).
Coat grease to all functioning parts after wiping off any accumulation of dirt on lock parts. Make certain that the lock and release mechanisms operate smoothly several times.
Fuel Recommendation
1972 USA Owners manual (Page 22 ... 22):
FUEL RECOMMENDATION
The A12, four cylinder, in line, five bearing crankshaft engine will give you top power and high level performance using gasoline above 91 octan [sic] under almost all driving conditions.
If "knocking" occurs with the gasoline you are using, It can be cured by slightly retarding the spark timing or other engine adjustments. If not, switch to a higher grade octane.
29382.jpgAlbum 29382
1974 B120 Owner's Manual (Page 19 ... 19)
FUEL RECOMMENDATION
Your DATSUN is designed to operate on a good quality of gasoline with a minimum octane rating of 88, which is rated by the research method.
Using a fuel with too low an octane rating will result in "spark knock". Continuous or excessive "spark knock" may result in engine damage.
If "spark knock" occurs, change to the next higher grade of fuel or consult your designated NISSAN/DATSUN dealer.
Fuel Filler Lid
Main: Fuel Lid
FUEL FILLER LID
Selection of Right Lubricants
SELECTION OF RIGHT LUBRICANT
The selection of the right lubricant and its correct application does much to increase the life and improve the operation of all the moving parts of the vehicle. The prescribed lubricating intervals in the "Periodical Maintenance and Lubrication Schedule" should be strictly followed, under normal conditions. Severe of [sic] unusual operating conditions are: stop and start city driving, driving in extreme cold or hot temperatures, driving in very dusty areas or in rough roads, driving in rainy day, constant high speed-driving, etc.
The recommended viscosity grade of lubricants of the engine, transmission and rear axle varies with temperature changes. The lubricants provided at the factory are intended for use at temperatures between 32 and 90°F (0 and 32°C).
In the cold season, a low viscosity oil gives better lubrication because it flows more easily. In the hot season, a high viscosity oil is used since oil tends to thin out with higher operating temperature.
Use of oil with SAE numbers shown in the "#Recommended SAE Viscosity Number."
Engine oil capacity
  • Oil pan: 2-7/8 U.S.qts., 2-3/8 Imper.qts. (2.7 ℓ)
  • Oil filter: 1-3/8 U.S.pints., 1 Imper.pint. (0.54 ℓ )
It is normal to add some engine oil between the 3,000 miles (5,000 km) oil changes. The amount added will vary with severity of operation.
The selection of the proper lubricant and its correct application does much to increase the life and improve the operation of all the moving parts of the vehicle. The prescribed lubricating intervals in the "Periodical Maintenance and Lubrication Schedule" should be strictly followed, under normal conditions. Under severe of [sic] unusual operating conditions are: stop and start city driving, driving in extreme cold or hot temperatures, driving in very dusty areas or in rough roads, driving in rainy day, constant high speed-driving, etc.
The recommended viscosity grade of lubricants of the engine, transmission and rear axle varies as the temperature changes. The lubricants filled at the factory are for the condition of 0° to 32°C (32° to 90°F).
In cold season, a low viscosity oil gives better lubrication because it flows more easily. In hot season, a high viscosity oil is used since oil tends to thin out with higher operating temperature.
Use of oils with SAE numbers shown in the "#Recommended SAE Viscosity Number" is recommended.
Engine oil capacity
  • Oil pan: 2.7 liters (2-7/8 U.S.qt, 2-3/8 Imp.qt)
  • Oil filter: 0.54 liter (1-1/8 U.S.pt, 1 Imp.pt)
It is normal to add some engine oil between 3,000 km (2,000 miles) oil changes. The amount added will vary with severity of operation.
Recommended Lubricants
1972 USA Owners manual (Page 23 ... 23):
RECOMMENDED LUBRICANTS
29383.jpgAlbum 29383
1974 B120 Owner's Manual (Page 20 ... 20)
1972 USA Owners manual (Page 24 ... 24):
RECOMMENDED SAE VISCOSITY NUMBER
30454.jpgAlbum 30454
Ambient Temperature Range
1974 B120 Owner's Manual (Page 21 ... 21)
30453.jpgAlbum 30453
Temperature Range Anticipated Before Next Oil Change
Battery
BATTERY
Check the electrolyte level in each battery cell about once a month. If necessary add distilled water to bring the level up approximately 5 mm (0.2 in) above the plates. Do not overfill.
To prevent corrosion and leakage of current keep the top of the battery clean and dry.
Also keep the terminals clean and well covered with petroleum jelly.
During freezing weather
When distilled water has been added, drive the car for a moment to make sure that the added water mixes thoroughly with the battery's electrolyte solution. Other
wise, the water may freeze and damage the battery.
29384.jpgAlbum 29384
1200 Pickup manual uses the word "vehicle" instead of "car"
BATTERY
When distilled water has been added, drive the vehicle for a moment to make sure that the added water mixes thoroughly with the battery's electrolyte solution. Other
Cooling System
Main: Coolant
COOLING SYSTEM
29385.jpgAlbum 29385
1974 B120 Owner's Manual (Page 22 ... 22)
COOLING SYSTEM
Windshield Washer Tank
WINDSHIELD WASHER TANK
Brake and Clutch Master Cylinders
Main: Clutch Master Cylinder (LHD only)
BRAKE AND CLUTCH MASTER CYLINDERS
BRAKE MASTER CYLINDERS (R.H./L.H.) AND CLUTCH MASTER CYLINDER (ONLY L.H. DRIVE VEHICLE)
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Daily_Care"
This page has been accessed 10,054 times. This page was last modified 07:20, 24 July 2025. Content is available under Datsun 1200 Club.
