<-- back to SC14
The supercharged 1978 Datsun 1200 ute was POST sold to Simmo999 July 2008.
* A15 and 60 series overdrive 5-speed. * Toyota SC14 blower & downdraught weber * Pulsar radiator * High pressure water methanol injection * Extractors and stainless exhaust
Good solid performance with a 14.7 second 1/4 mile @ 89mph.
Toyota SC14 supercharger is the most popular blower swap for Datsun 1200s. It comes from the Supra Toyota 1G-GZEᵂ straight-6 engine.
Grunterhunter:
torque like a turbo diesel.You really notice the extra punch down low. ... i had to tow [another car] up a reasonably steep hill (probably 1 in 5 incline)- Half throttle, 3-4 psi of boost at 2000 rpm in 4th and it just chugged its way up, happy as larry
Grunterhunter draw-through setup
POST Grunterhunter: my setup lasted a surprisingly long time with non intercooled drawthrough 10psi and 9.7:1 comp- but it does have a fairly big cam, so compression is all relative. You are shooting youself in the foot putting a shim in an otherwise standard engine for 10psi. decreasing your squish will rob you of lots of kW without much gain from the decreased comp/ extra boost potential.
A Weber 32/36 Carburetor is bolted to the blower
Carbie could also be put in the corner of the engine bay
EGR delete plate
Radiator
Radiator needs to cool 100+ horsepower.
Pulsar radiator keeps it all cool.
Gallery
Air Cleaner
With a standard ramflow air cleaner for DGV carburetor
Or, top it with a PB110 air cleaner (requires hood modification)
blow output tube goes to stock intake manifold
Brackets
Outlet can be placed to the left
Possible outlet for intercooler, though intercooler is not required
