Head gasket
From Datsun 1200 Club
Category: Engine Mechanical
The Datsun 1200 cylinder head gasket fit A12 and A10 engines. Aftermarket gaskets vary in material and size of cooling holes. Aftermarket gaskets may come with oversized bore holes.
22208.jpgAlbum 22208 22067.jpgAlbum 22067
Also See:
* Changing Head Gasket
* Tune-up
Nissan recommends re-torquing the head gasket bolts ever twenty-four months (every two years):
1972 USA Owners manual (Page 34 ... ):
Retighten cylinder head bolts, manifold nuts & carburetor securing nuts.
slight weeping leak — oil is weeping out of the gasket, dirtying the cylinder block below. Solution: replace gasket
10755.jpgAlbum 10755
Thickness
Most A-series head gasket are 1.6 mm thick. Some are 1.2 mm thick. So which brand you buy can make a slight difference.
The A12GX Engine used a thin gasket to achieve its 10:1 compression ratio.
Nismo MLS gasket is 0.5 thickness for improved quench, thus slightly more power.
See also: Quench#Gaskets
Head Set
A Head Set gasket kit includes all you need to change the head:
* Cylinder head gasket
* Valve stem seals
* Rocker cover gasket
* Gasket-manifold to cylinder head
it may include the following:
* thermostat gasket
* intake-to-exhaust manifold gasket (heat riser gasket)
* oil cap packing (gasket)
* fuel pump gaskets
Nissan
11044-H3926 KIT-GASKET,CYLINDER HEAD
11042-H3927 KIT-GASKET,CYLINDER HEAD
aftermarket
* Victor HS3602
* FEL-Pro HS21181PT
* ROL HS32060
Head Locating Dowels
Starting in late 1972, heads are now located by dowels in the out left-side bolt holes
Original A12 head gasket: all bolt holes are same diameter
30626.jpgAlbum 30626
Newer gaskets: outer holes are larger diameter to accommodate the dowels
23188.jpgAlbum 23188
Blown Gasket
Coolant leaking into the oil pan, causing "milkshake" to be visible on the oil cap and dipstick.
8710.jpgAlbum 8710
Double-check by looking at the dipstick
  • Cap milky, dipstick oil clear: This is caused by condensation, not by a bad head gasket
  • Cap milky, dipstick oil milky: oil-water mixture due to bad head gasket
A coolant-system leak test can be performed. However, on an A-series engine, practically the only way this can happen is through the head gasket (gasket failure between coolant hole and oil drain-back hole). On some engines it can have other causes.
Removing the spark plugs: you can see that one plug color differs from the other. There is a problem, but it is not necessarily the head gasket
21050.jpgAlbum 21050
After the head is removed, the final inspection can begin
21052.jpgAlbum 21052
When a head gasket is blown out (partly missing) between cylinders it is obvious, and the engine will run on "two cylinders" (barely run, if at all). Engine compression test will show this as two cylinders reading zero pressure.
15053.jpgAlbum 15053
But head gaskets more often fail in a less obvious manner -- they lift up enough to allow compression to leak past, causing low compression. An Engine compression test will find this.
Sometimes you can see a "trail" were pressure leaked out of cylinder
18407.jpgAlbum 18407
A more rare failure is of the oil or water passage. The engine will still run perfectly, but oil will leak or coolant will be lost. A Cooling System Pressure Test can often pinpoint the diagnosis.
Looks like oil leaked onto the gasket during removal. Not a sign of a bad gasket
21054.jpgAlbum 21054 21053.jpgAlbum 21053
Sometimes one cylinder is perfectly clean. This means that engine coolant leaked into the cylinder and 'steam cleaned' the piston top — and sign that the head gasket has leaked
21051.jpgAlbum 21051 21055.jpgAlbum 21055
21204.jpgAlbum 21204
Turbo Boost/Supercharger
Standard head gasket works fine to at least 15 psi boost. Over 15psi, consider going to a copper head gasket and orings, which requires a special finish and coatings.
Spacer
Spacers between the block and head gasket are useful for racing with Forced Induction. It reduces the compression ratio, but it allows more boost to be applied, which can be tuned for more power. The downside is less power at part throttle, so it is not recommended for a street engine.
5435.jpgAlbum 5435
custom order
21743.jpgAlbum 21743
Revisions
H1000 was the original gasket.
#October 1971 Gasket material change
#H3900 is the revision from May 1972. It made the cylinder openings closer in size to the 73mm bores, in order to reduce emissions. Bonus, it helps HP a tiny bit too.
#H3925 was the late 1972 revision that reduced risk of oil leaks by using an O-ring seal.
H3925
H3925 was the July 1972 revision that reduced risk of oil leaks by using an O-ring seal.
CYLINDER HEAD MODIFICATIONS
Bulletin Number: TS72-77
Date: August 3, 1972
Classification Number: EN72-011
Section: Engine
Models: (K)LB110
Production Change: The modification listed below have been made for better oil sealing
Beginning Engine Serial Number: A12-127535
Beginning Production Date: July, 1972
Note: These number are part of the new number series. See TS72-62 for more information
1. The exhaust valve O-rings and O-ring grooves have been eliminated (See Figure 1)
2. An O-ring has been inserted in the oil hole in the mating surface of the cylihder head with the cylinder block (See Figure 2) The head gasket has also been changed
24735.jpgAlbum 24735
Parts Information
Head gasket kit (gasket & O-ring)
New Part Number: 11044-H3925
Former Part Number: 11044-H3900
Interchangeability Yes
24388.jpgAlbum 24388
H3900
CYLINDER HEAD GASKET, 1972 MODEL
Bulletin Number: TS72-44
Date: May 22, 1972
Classification Number: EN72-007
Section: Engine
Models: A12,L16
Combustion chambers of the 1972 model A12 and L16 engines were redesinged to reduce hydrocarbon emission to a minimum and the configuration of cylinder head gaskets was changed. The opening in the cylinder head gasket at bore location is made smaller in diameter to reduce the quench area to a minimum and thus prevent incomplete combustion of the air-fuel mixture. Because of this change, the correct gasket must be used for replacements on 1972 engines
Beginning Engine Serial Number & Part Number
A12-11044-H3900
L16-203416 11044-N2211
Interchangeability
A12, not interchangeable
L16, 1972 to earlier models, yes, earlier models to 1972, no
October 1971
Bulletin Number: TS71-45
Date: October 1, 1971
Section: Engine
Models: (K)LB110
Production Change: On the A12 engine, the currently used oil-soaked cylinder head gasket has been replaced with a dry gasket of the same type
Beginning Engine Serial Number: A12-485141
Parts Information: The part number has not changed
1971 and earlier Cylinder Head Gasket 11044-H1000
1972 Cylinder Head Gasket 11044-H3900
A12 vs A14 gasket
  • Early A12 uses a dedicated oil passage. Some later gaskets are missing this
  • Early A12 blocks use no locating dowels (small bolt holes)
  • Later engines have the water passage closed to the cylinder. Newer gaskets either have a larger or oval-shaped hole
  • Some aftermarket gaskets have a large bore, which is not optimum for the A12
30639.jpgAlbum 30639
11044-H3925 GASKET-CYLINDER HEAD B110 A12 USA 0671- $57 USD > 11044-H3900
11044-H3901 GASKET-CYLINDER HEAD B210+B310 A12 JAP
11044-H1025 B110 (from '72-5) > 11044-H1000 > 11044-18004
* 11045-H1000 RING "O" (from '72-5)
11044-H1025 B210 from '75-5
11044-H1026
11044-H1027
11044-18004 GASKET-CYLINDER HEAD B10 A10 > 11044-18002 <> 11044-18001 <> 11044-18000
22068.jpgAlbum 22068
Interchange:
A10 PULSAR 1000 BN10 988cc 1978-ON
A10 SUNNY 1000 B10,B20 1000 1966-1970
A12 SUNNY 1200 B110,B210,C20  1171cc 1970-73.3
A12 SUNNY 1200 B210 1973.4-75
A10 CHERRY 1000 E10, F10 988 1970.10-73.9
A12 CHERRY 1200 PE10, F10 1171cc 1972-78
A10 SUNNY CAB C20
11044-18004 GASKET-CYLINDER HEAD A12 superceeded
11044-H1000 GASKET-CYLINDER HEAD A12
11044-H1000 GASKET-cylinder head B110, B210 to '75-4
11044-H1026
11044-H1027
11044-H3900 GASKET-CYLINDER HEAD A12 0671-
fits:
11044-H2300 A12GX, A12T
11044-H2301 [thinner?] A12GX, A12T
11044-H2325 A12GX from '72-6
22066.jpgAlbum 22066
GX
11044-H2325 A12 GX from '72-6 > 11044-H2300
* 11045-H2300 RING "O" (from '72-6)
11044-H2301 A12T B210 [thinner?]
11044-H2301
22066.jpgAlbum 22066 174_61db6436611e3.jpgPost 496422 174_61db6370bcb85.jpgPost 496422
174_61db643f50e30.jpgPost 496422
A1044-H232E
16712.jpgAlbum 16712
GX Metal
22209.jpgAlbum 22209 23188.jpgAlbum 23188 23638.jpgAlbum 23638 23639.jpgAlbum 23639
Nissan Competition
Nissan Competition
Competition198438.jpg* 11044-M0821 COMPETITION HEAD GASKET
Gasket has a bore diameter of 79mm/3.11", an uncrushed thickness of 0.8mm/0.032" and displaces 3.9cc's.
Nismo head gaskets for Nissan A series motor A12,A13,A14,A15 Engine
11044-M0822 t=0.8 79.0 mm bore diameter
11044-M0823 t=0.6 80.0 mm bore
11044-M0822 79mm diameter bore
22065.jpgAlbum 22065
Kameari
Kameari big-bore head gasket
Kameari A12/A14/A15 head gasket
G/K Metal beaded head gasket (stopper type)
79-80.5 bore 0.8 thickness 10-KAME-511-790-080-ST
             1.0 thickness 10-KAME-511-790-100-ST
             1.2 thickness 10-KAME-511-790-120-ST
             1.5 thickness
79-79.5 bore 2.0 thickness
Tomei
Tomei big-bore head gasket
TOMEI A12/A14/A15 head gasket
TOMEI Aカタヘッドガスケット
NISSAN A12/A14/A15 Stainless Metal beaded gasket with rubber coating
Standard upgrade   φ79.0 0.8mm 1345790081 Opposing Bead Type
                         1.0mm 1345790101
Competition-ready  φ79.0 0.8mm 1345790082 Opposing Bead Stopper Type
30638.jpgAlbum 30638
既に生産廃止
シリンダーヘッドガスケット
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Head_gasket"
This page has been accessed 28,130 times. This page was last modified 04:31, 26 September 2025. Content is available under Datsun 1200 Club.
