Trunk
(Redirected from Boot)
Category: Body
Datsun 1200 sedans have a regular trunk (boot) at the rear of the car. Coupes, being fastbacks but not hatchbacks, have a teensy-weensy trunk lid at the back. The sedan trunk is very roomy for a car this size, and can hold about eight grocery bags, or luggage for five people. The lids are secured with a key lock.
3049.jpgAlbum 3049 20398.jpgAlbum 20398
In sedans, the Fuel tank is inside the trunk, next to the rear Seat, hidden behind a finisher panel.
Standard Equipment
The trunk came factory equipped with:
  • Scissor Jack
  • S-shaped Jack Handle
  • Wheel Wrench in black Bag
  • Spare Tyre
For more details, see: Jack
Locks
Main: Locks
Sedan
Boot Lid
13610.jpgAlbum 13610
84300-H1000 ASSY-TRUNK LID SEDAN B110/PB110
84830-H1000 BUMPER-trunk lid (2)
All parts are same B110 & PB110 — lock, lid, hinges, jack equipment, mat, etc. — except for the finisher board.
Bumper
80833-78500 RUBBER-BUMPER (2) SEDAN
28126.jpgAlbum 28126
diameter 14mm (at widest part)
height 16mm (cylindrical portion, not counting the tab)
28125.jpgAlbum 28125
Moulding
Option: trunk lid trim "handle" (cosmetic finisher) is 44cm long
8610.jpgAlbum click to view
Also used on PB110
197106-2x.jpg 27062.jpgAlbum 27062 25551.jpgAlbum 25551
Per the catalog, is not specific to any specific trim
25551.jpgAlbum 25551 25552.jpgAlbum 25552
84820-H1000 HANDLE-TRUNK SEDAN
84821-H1000 WASHER-TRUNK LID HANDLE SEDAN
84832-H1000 SPACER-TRUNK LID SEDAN (*)
08310-50812 SCREW (3)
08915-13510 WASHER (3)
* 1971 catalog shows small piece and specifies 3 spacers
1973 catalog (for same part number) shows one large spacer
27063.jpgAlbum 27063 8610.jpgAlbum 8610
トランク モール
Finishing Panels
The trunk finishing panels are made out of pressboard:
3236.jpgAlbum 3236 3237.jpgAlbum 3237
5295.jpgAlbum 5295
Panel hides the fuel tank and fuel lines
4930.jpgAlbum 4930
84910-H1000 FINISHER-trunk room (head board) <> 84910-H2800
84910-H1900 FINISH-TRUNK ROOM T=2.5 SEDAN USA
84910-H2800 FINISHER-trunk room B110 (from C/#B110-174795), 1972, PB110 S-DX
84910-H2900 FINISHER-trunk room PB110 S-GL,S-GX
H19 VS H10 differs slightly in the region of the fuel filler hose cutout.
Hinges
17796.jpgAlbum 17796
84520-H1001 HINGE-TRUNK LID RH SEDAN
84521-H1001 HINGE-TRUNK LID LH SEDAN
29906.jpgAlbum 29906 29907.jpgAlbum 29907
Coupe
Coupe has a small trunk lid.
14161.jpgAlbum 14161 7034.jpgAlbum 7034
84300-H1800 ASSY-TRUNK LID COUPE B110/PB110
29904.jpgAlbum 29904 29905.jpgAlbum 29905 23470.jpgAlbum 23470
558.gifAlbum 558
Coupe boot lid has a stylish ridge down the centre
21414.jpgAlbum 21414
Of course, you can always fill the boot with speakers
7388.jpgAlbum 7388
Fitting
The 1200 coupe has interior plastic covers inside -- lots 'o plastic. There is plastic on the bottom side of the trunk lid too.
174_57932af0f2961.jpgPost 480061 23469.jpgAlbum 23469
Without the finisher panels
Trunk Lid Finish panel
84911-H1800 FINISH-TRUNK LID T=1.5
84905-H1800 STOPPER-TRIM TRUNK FLOOR
23358.jpgAlbum 23358 23359.jpgAlbum 23359 23357.jpgAlbum 23357
Rear Floor
  • 08510-51612 SCREW-TAPPING M5 FIX TRIM (16)
  • 08963-20540 NUT-SPRING TYPE A M5 FIX TRIM (16)
  • 08915-43510 WASHER-PLAIN M5 FIX TRIM (16)
  • 84902-H2500 TRIM-TRUNK FLOOR CENTER
  • 84902-H7100 TRIM-TRUNK FLOOR CENTER (BLUE,LB-211
  • 84902-H7101 TRIM-TRUNK FLOOR CENTER (BEIGE,LH-20
  • 84902-H7102 TRIM-TRUNK FLOOR CENTER (BLACK,LG-13
  • 84902-H1800 TRIM-TRUNK FLOOR CENTER
Rear Side
  • 01553-00291 CLIP-TRIM (14)
  • 66919-H1099 CLIP-TRIM (15)
  • 84921-H1800 FINISH-TRUNK SIDE RH T=1.5
  • 84921-H1900 FINISH-TRUNK SIDE RH T=2
  • 84921-H2500 FINISH-TRUNK SIDE RH T=1,5
  • 84922-H1800 FINISH-TRUNK SIDE LH T=1.5
  • 84922-H2500 FINISH-TRUNK SIDE LH T=1.5
23364.jpgAlbum 23364 23365.jpgAlbum 23365 23363.jpgAlbum 23363
Rear
  • 01553-00291 CLAMP (24)
  • 84931-H1800 FINISH-TRUNK REAR T=2
  • 84931-H1801 FINISH-TRUNK REAR T=2
  • 84931-H2501 FINISH-TRUNK REAR T=2
23360.jpgAlbum 23360 23361.jpgAlbum 23361 23362.jpgAlbum 23362
Floor trim panels are fastened by the typical B110 sheet screws (B210 changed to bolts/machine screws).
Plastic Panel Fasteners
  • 01553-00291 CLAMP/CLIP
    • superseded 66919-H1001 CLIP-TRIM
23356.jpgAlbum 23356
76983-68400 LOCK-MALE
76982-68400 ASSY-LOCK FEMALE
08410-41210 SCREW-TAPPING
08915-43410 WASHER-PLAIN
08915-13410 WASHER-LOCK
84932-H1800 MASK-REAR LAMP T=2
84932-H2500 MASK-REAR LAMP T=2
84941-H1800 COVER-TRUNK LID HINGE
84939-H1800 WELT-TRUNK FINISH
Carpet
17794.jpgAlbum 17794 17795.jpgAlbum 17795 17796.jpgAlbum 17796 2879.jpgAlbum 2879 2884.jpgAlbum 2884
Floor Fitting
  • 32021-35000 PLUG-INSPECTION HOLE 55D USA
  • 74891-H2500 ASSY-COVER INSPECTION HOLE
  • 08510-61212 SCREW (6)
23366.jpgAlbum 23366 23367.jpgAlbum 23367
Truck
See also: Jack
Weatherstrip
84810-H1001 WEATHERSTRIP-TRUNK LID Sedan $53.73 USD
* superseded 84810-H1800 WEAHERSTRIP-TRUNK LID Coupe
378 mm long - Sedan
Boot (trunk) seal is same material as 510. Possibly 510 part will fit with trimming for length.
84806-A4600 Weatherstrip 510 $60.75 USD
510 Trunk Weather Strip 84810-21001
Trunk Opener
B210 had an option of electric trunk opener. Possibly could be retrofitted to 1200?
FRP
1200 boot lid, 4.5kg, $220 AUD
13888.jpgAlbum 13888 13688.jpgAlbum 13688 13687.jpgAlbum 13687 13889.jpgAlbum 13889 13890.jpgAlbum 13890
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Trunk"
This page has been accessed 29,087 times. This page was last modified 21:19, 30 May 2025. Content is available under Datsun 1200 Club.
