Fuse Box
(Redirected from Fuse)
In addition to the main fuse wire (Fusible Link) in the engine compartment, there is a main fuse box under the dashboard.
1972 USA Owners manual (Page 35 ... ):
If a fuse needs to be replaced, refer to the specifications listed on the fuse box cover.
23310.jpgAlbum 23310
Fuses
B110 uses the standard cylindrical fuses used by all cars until around 1980. The numbers are:
Nissan 25461-89901 or 08941-11000 FUSE (10A)
Nissan 25415-89900 or 08941-11500 FUSE (15A)
AGC Type (All Glass, C length 1.25 inch), 1/4" diameter (approximately 6mm diameter x 30mm long). SFE20 type is the same.
IG: Ignition Switch Circuit
> only HOT when key is in IGN position
* 'W' 15 AMP Wiper, Washer, Heater
* 'M' 10 AMP Meter, Reverse Lights, Alternator Regulator
Battery/Alternator Circuit
> always HOT
* 'L' 15 AMP Head Lamp
* 'PT' 10 AMP Park lights, Tail lights
* 'C' 15 AMP Radio, Clock, Cigarette lighter, Room lamp
* 'H' 15 AMP Horn, Stop lights, Hazard lights
There are also two empty holes in the fuse box to hold two spare fuses.
23313.jpgAlbum 23313 23312.jpgAlbum 23312
Location
It is located under the dash above the driver's right knee. It is bolted to a bracket on the bottom of the dash frame:
LHD
23311.jpgAlbum 23311 23278.jpgAlbum 23278
Late Model
23319.jpgAlbum 23319 23318.jpgAlbum 23318
Variations
#1 Buy at BProjects
15A 10A (with HEAD LAMP fuse marking)
15A 15A
10A 15A
23312.jpgAlbum 23312 Original type
#2
(2nd source - up to '71-Mar)
___ no HEAD LAMP fuse
15A 15A
10A 15A
25765.jpgAlbum 25765 GL,GX type
#3 (620 type: headlamp changed to 20A)
20A 10A (if used in a 1200, change to 15A HEAD LAMP fuse)
15A 15A
10A 15A
25767.jpgAlbum 25767 620 type
Late Ute
Utes from 1982 feature rectangular fuses. Also eliminates the plug-in connectors on the back of the fuse box, which was a problem spot in older 1200s (now the harness wires go directly to the individual fuses, whereas formerly they ended at large spade connectors).
23308.jpgAlbum 23308 23320.jpgAlbum 23320
8110-8910 Variation 1
8910-     Variation 2
The "ENGINE CONTROL" fuse was also used by B310 and other 1980s Datsuns. It is the main Ignition-switched feed for the engine harness. Feeds the vacuum cut, fuel cut, and auto-choke relay.
Australia
26850.jpgAlbum 26850 26851.jpgAlbum 26851 26852.jpgAlbum 26852
B140
B140 1400 Bakkie used all ten fuses, unlike Japan or Australia
Unknown year fuse box
28233.jpgAlbum 28233
15A-15A-20A-20A-20A-10A-10A-10A-10A-10A
1995-2008
15A-10A-10A-10A-15A-10A-10A-15A-15A-15A
28234.jpgAlbum 28234 28235.jpgAlbum 28235 28236.jpgAlbum 28236
1982-1989
8110-8910 Variation 1 24311-G1900
24311-G1900.jpg 27517.jpgAlbum 27517
IGNITION イグニッション
 10A COIL イグニッション コイル
 10A ENGINE CONTROL インジン コントロール
 10A METER REVERSE メーター バックランプ
ACCESSORY アクセサリー
 15A RADIO HEATER WIPER ラジオ ヒーター ウイパー
 15A LIGHTER シガ ライター
BATTERY バッテリー
 10A FLASHER フラッシャー
 10A TAILLAMP ROOMLAMP テールランプ ルームランプ
 15A HORN STOPLAMP ホーン ストップランプ
 15A HEADLAMP ヘッドランプ
指定した容量以外ノヒューズは入れないで下さい。
Please do not use other than specific capacity fuse.
G1900
1990-1994
95W type (late square fuse type)
24311-95W00 COVER,FUSE BLOCK [approximately 120 x 30 mm]
25772.jpgAlbum 25772
IGNITION
 10A Ignition Coil
 10A Engine Control
 10A Meter BackLamp
ACCESSORY
 15A Radio Heater Wipers
 15A Cigar Lighter
BATTERY
 10A Flasher
 10A TailLamp RoomLamp
 15A Horn StopLamp
 15A HeadLamp
Fuse Puller --> ヒューズ抜きし -->
指定した容量以外のヒューズは入れないで下さい。
22119.jpgAlbum 22119
Troubleshooting
19667.jpgAlbum 19667
The instrument panel wiring harness has individual connectors to the Fuse Box:
23314.jpgAlbum 23314 23315.jpgAlbum 23315
Battery Feed
BATTERY FEED powers L, PT, C and H fuses
15A L Fuse:
* Light Switch (head lamp circuit)
10A PT Fuse:
* Light Switch (park & tail light circuits)
15A C Fuse:
* Cigarette Lighter
* Radio
* Clock
* Room Lamp
15A H Fuse:
* Horn
* Stop Lamps (brake lights)
* Flashers (turn signals)
Ignition Feed
IGNITION FEED powers M and W fuses
10A M Fuse:
* Voltage Regulator
* Instrument Panel Gauge Regulator
* Brake Lamp
* Oil Pressure Lamp
* Charge Lamp
* Reverse Lamp
* Hazards
15A W Fuse:
* Wiper
* Washer
* Heater
Fusible Link
The Fusible Link ("Main Fuse") connects to the POS battery terminal about six inches from the battery. The fusible link is a special length of wiring that will melt if its rating is exceeded and is there to stop the electrics if the car is drawing too much power, like an open short circuit.
Cleaning
If your fuse box gets HOT or starts melting (but the fuse does not blow), then remove the fuse box and CLEAN it. Soak it in vinegar for 10 minutes.
Or if you are getting electrical equipment not working, clean the fuse box.
Why? Dirty connections cause undue resistance, eventually leading to overheating and partial melting:
28858.jpgAlbum 28858
The reason that fuse lead is getting hot is because of resistance. This is pretty common with old-styled glass fuse boxes. You get resistance at either the fuse itself, or the connection between the fuse and the terminal — along with whatever other resistance is present in the wiring. The corrosion is at the fuse box connections, which is why it gets hot, and why it melts.
  1. Disconnect the battery NEG terminal
  2. Remove all the wires from the fuse box (take a photo first, or write down carefully which wire goes where). Mark each wire with a piece of tape.
  3. Take the Fuse Box in the house and soak it. Fill a small bowl with distilled white vinegar from the grocery store. Soak for 10 minutes.
  4. Rinse with water with a little Baking Soda mixed in -- this will nuetralize the acid from the vinegar. Then rinse with plain water
  5. Dry thoroughly, or let dry overnight
  6. Put a little dielectric grease (a LITTLE not a LOT) on each copper terminal (front and back of fuse box). This will help prevent moisture corrosion
B110
B110: 6-FUSE BOX -- Buy at BProjects
25410-H1000 BLOCK-FUSE
B5415-H1000 COVER-FUSE BLOCK
23316.jpgAlbum 23316 25768.jpgAlbum 25768 25769.jpgAlbum 25769 25770.jpgAlbum 25770 25771.jpgAlbum 25771
25410-H1100 ASS'Y-BLOCK, fuse (2 系統)(up to '71-Mar) GL,GX [no HEAD LAMP fuse]
B5415-H1100 COVER-fuse block (2 系統)(up to '71-Mar) GL,GX [no HEAD LAMP marking]
NILES FB206N-1 set
FB206N-1a.jpg FB206N-1b.jpgFB206N-1c.jpg 16900.jpgAlbum 16900 16901.jpgAlbum 16901
25410-B5102 BLOCK-FUSE
08510-51212 SCREW, fixing fuse box (2)
08915-13510 WASHER-SPRING, fixing fuse box (2)
#25461-89901/08941-11000 FUSE (10A)
#25415-89900/08941-11500 FUSE (15A)
620
USA Catalog
#25410-H1000 -0476 < 25410-B5102
 25410-B8000 0974-0476
 25410-B8001 0576-0776 [radio fused moved to IG side]
 25410-B8002 0876-0877
 25410-B8060 0878-
JAPAN 1972 Catalog C-234
25419-B5000 BRACKET-fuse block
25410-B5000 FUSE BLOCK ASS'Y
25411-B5000 COVER-fuse block
25415-89900 15A (5) [4 fuses + 1 extra]
25461-89901 10A (3) [3 fuses + 1 extra]
JAPAN 1972 Catalog C-410
25419-B5000 BRACKET-FUSE BLOCK
FUSE BLOCK ASS'Y
* 25410-B5001    N-7604
* 25410-B5002 7605-7605
* 25410-B5003 7606-7708
* 25410-B5004 7709-
* 25410-J0100 7809-
25411-B5000 COVER-FUSE BLOCK
25410-B5102 with 20A head lamp fuse
25410-B5102.thumb.jpg.d9f8c5976d8269be8fba9b22c9208127.jpg 14924.jpgAlbum 14924 23309.jpgAlbum 23309
* Original Manufacturer: NILES brand No. FB 206N
* Fits B110 and 620. A 15A headlamp fuse should be fitted
* 25410-H6200 ASSY-BLOCK FUSE -0974
** 25411-H6200 COVER-FUSE BLOCK -0974
* 25410-H7200 ASSY-BLOCK FUSE (YAZAKI) 1074-
** 25411-H7200 COVER-FUSE BLOCK (YAZAKI) 1074-
* 25410-H7205 ASSY-BLOCK FUSE (SUMITOMO) 0476-
** 25411-H7205 COVER-FUSE BLOCK (SUMITOMO) 0476-
B310
B310: 8-FUSE BOX
08941-12000 20A FUSE
* 25410-W5801 USA BLOCK ASSY-FUSE
  25411-W5801 USA COVER-FUSE BLOCK
* 25410-H9400 JDM BLOCK ASSY-FUSE
  24511-H9400 JDM COVER-FUSE BLOCK
* 25410-W5001 JDM BLOCK ASSY-FUSE YAZAKI
* 24511-W5001 JDM COVER-FUSE BLOCK YAZAKI
22457.jpgAlbum click to view 22458.jpgAlbum click to view
1200 Truck
B120: 6-FUSE BOX
* 25410-G1600 BLOCK ASSY-FUSE -7709
* 25410-G1601 BLOCK ASSY-FUSE 7710-7801
* 25410-G1660 BLOCK ASSY-FUSE 7802-8109
B120: 10-FUSE BOX w/Rectangular fuses
* 24310-G1900 BLOCK ASSY-FUSE 8110-8910
* 24311-G1900 COVER-FUSE BLOCK 8110-8910
23323.jpgAlbum 23323 25028.jpgAlbum 25028 25029.jpgAlbum 25029 24311-G1900.jpg 24013-G1900.jpg 24013-G1900_closeup.jpg
* 24310-95W00 BLOCK ASSY-FUSE 8910-
* 24311-95W00 COVER-FUSE BLOCK 8910-
25461-89901
AGC fuse 10A
AGC type 10A glass fuse 1.25 inch long Voltage Rating: 32V AC/DC
29818.jpgAlbum 29818
25415-89900
AGC fuse 15A
AGC type (glass tube, 1/4 x 1-1/4 inch) Voltage Rating: 32V AC/DC RockAuto $0.50
29819.jpgAlbum 29819
History
B10: 4 fuses
22460.jpgAlbum 22460
B110: 6 fuses
B210: 8 fuses
22459.jpgAlbum 22459
B310: 8 fuses
23321.jpgAlbum 23321
B11: Rectangular 16 fuses
23306.jpgAlbum 23306
B120 1982: Rectangular 10 fuses
23317.jpgAlbum 23317
Aftermarket Fuse Box
4193.gifAlbum 4193
4891.jpgAlbum 4891
ヒューズ ボックス 箱のヒューズ (フューズ ボックス)
サニトラヒューズボックス
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Fuse_Box"
This page has been accessed 112,153 times. This page was last modified 01:13, 4 December 2025. Content is available under Datsun 1200 Club.
