Intake Manifold
(Redirected from Inlet manifold)
Categories: Engine Mechanical | Manifold
Datsun 1200 was equipped with a round-port inlet manifold. USA got one with accessories fitings, while Japan, Canada and other countries got a plain intake manifold. For other A-series engines, manifolds differ by country and year.
Connects To
Intake Manifold bolts to
* Exhaust Manifold (except detached types)
* Cylinder Head
These bolt to the Intake Manifold
* Carburetor
* Air Cleaner brackets
* PCV valve
* Throttle Opener solenoid
Gasket Bolts
Yoke washers
26299.jpgAlbum 26299
08911-10810 NUT CYLINDER HEAD TO MANIFOLD (9)
08915-13810 WASHER-LOCK (5) for upper studs
14037-32200 YOKE-MANIFOLD (4) [large washers]
The "yoke" is a special washer with non-parallel faces. It is a smaller version of the Crank Pulley washer.
M8 studs & nuts.
174_5cb10c8973d9d.jpgPost 491160
Yoke Washers are only used on the bottom row of studs
174_5cb10ce1874f0.jpgPost 491160
#8 All nine studs use the same M8 nuts
#9 top five studs use the M8 lock-washers
#10 bottom four studs use Yoke only (no lock washer)
174_5cb1121d4cf01.pngPost 491161
Late model BOLT PATTERN
08911-20810 NUT CYLINDER HEAD TO MANIFOLD (11)
#14002F Top outside plain washers 14037-E3000
#14002E 14037-32200 YOKE-MANIFOLD (4)
174_5cb11f6c3ba01.pngPost 491163
Datsun 1200
Datsun 1200 was equpped with a round-port, dry, original bolt-pattern, inlet manifold. It looks like the Datsun 1000 manifold but it slanted 2 degrees different.
24972.jpgAlbum 24972
24971.jpgAlbum 24971
Plain type: only fittings are for PCV and one vacuum port (seen here with a plug)
21212.jpgAlbum 21212 21213.jpgAlbum 21213 21214.jpgAlbum 21214
Intake and exhaust manifold are bolted together (with Heat Riser in between)
7892.jpgAlbum 7892
A12 GX Engine
1200 GX models use a twin-carburetor intake manifold.
Datsun 1200 SSS
Datsun 1200 SSS was fitted with a New-Zealand built manifold and twin Dellorto carburetors.
Will not suit an A14 or A15 as those engines have oval inlet ports. These suit SSS motors with round inlet ports.
6260.jpgAlbum 6260 5468.jpgAlbum 5468
The inlet manifolds were Kiwi cast by Dennis Marwood to get them to match the head ports it is necessary to drill the mounting holes oversize to lift the manifold upwards to locate it better.
As of 2002, Autoquip Marketing in Auckland was still selling the manifolds.
Fitment with Exhaust Manifold
A12 intake and exhaust manifolds are a matched set -- they bolt together.
Fitment With Extractors
When using a tubular exhaust header (extractors) you can unbolt the intake from the exhaust manifold. Then fit shorter bolts to hold the Heat Riser block-off plate on. The A12 intake manifold comes with a block-off plate standard. This will fit over at least some big-tube header/extractors.
23090.jpgAlbum 23090
Most USA manifolds came with extra fittings, while Japan, Canada and other countries got a plain manifold.
14003-H3900 with bolt holes for accessories
21216.jpgAlbum 21216
14003-H3901 MANIFOLD-INTAKE A12,AUTO 0771-
14003-H3900 MANIFOLD-INTAKE A12,MANUAL 0771-
14003-H1901 MANIFOLD-INTAKE A12,CALIFORNIA 0671-0771
14003-H1900 MANIFOLD-INTAKE A12 EXHAUST -0571
14003-H1000 MANIFOLD-INTAKE A12 CRANK [Canada]
14003-H1000
21215.jpgAlbum 21215 21217.jpgAlbum 21217
INTAKE GASKET
14035-K7700 GASKET-MANIFOLD TO CYLINDER HEAD
14035-18000 GASKET-MANIFOLD TO CYLINDER HEAD
OTHER
14005-18001 GASKET-INTAKE TO EXHAUT MANIFOLD
* 08216-62210 STUD FIXING CARBURETOR 4
* 08110-63210 BOLT INTAKE TO EXHAUT MANIFOLD 2
* 01111-00032 BOLT
* 08915-13610 WASHER-LOCK INTAKE TO EXHAUT MANIFOLD 3
* 08911-10810 NUT CYLINDER HEAD TO MANIFOLD 9
* 08915-13810 WASHER-LOCK 5
  • 14037-32200 YOKE-MANIFOLD 4
Gasket
* Datsun B110 single-carb
22050.jpgAlbum 22050
For other A-series manifold gaskets, see:
Main: 14035
A-SERIES GASKET TYPES
* Round Port, No water ports, Original bolt pattern
* Round Port, No water ports, New bolt pattern
* Round Port, Water Ports,    New bolt pattern
* Large Oval Port, Wet Intake
* Small oval port, Siamese ports, No water ports
* Oval Port, No Water Ports
* Oval Port, Water Ports
* Medium Oval Port, EFI Head
* Medium Oval Port, non-EFI
Manifold Selection
When selecting an intake manifold for your A-series engine, keep these fitment factors in mind:
* Port shape (round, regular oval, large oval)
* Bolt Pattern (new style vs old style)
* Water Ports for dry head vs wet head
* Attached exhaust manifold vs non-attached
Port Shape
All Datsun 1200 came with round port cylinder head (except: Datsun 1200 GX, which came with Large Oval ports). Most A14/A15 came with regular-size oval ports. Other A-series engines came with small oval port heads.
Oval Port Comparo (Extra Large, Regular, Water Port, Small Oval)
15739.jpgAlbum 15739
Bolt Pattern
New bolt-pattern VS original A10/A12 bolt-pattern. The new pattern started with the A12GX Engine, but starting with the A Engine Redesign the A12 was converted to the new pattern. All A13/A14/A15 use the new style.
Early A12 (through 1973) bolt pattern
982_.jpgAlbum click to view
1974 bolt pattern
Water Ports
See Main Article: Water Ports
Detached Manifold
Non-attaching exhaust manifold
21689.jpgAlbum 21689
If fitting a detached Exhaust Manifold, the bottom of the intake will hit the exhaust manifold. In this case you can either 1) source a different, more compatible intake or 2) grind the bottom for clearance and weld the opening shut.
24263.jpgAlbum 24263
Types
180
Datsun B10 non-Coupe engine used a standard heat riser to keep the bottom of the intake manifold warm.
14000-18000 MANIFOLD ASSY to E/# A10-200838
14003-18000 MANIFOLD-intake
14003-18001 "" from Engine # A10-200839
174_5cfd8b60a6f63.jpgPost 491640 174_5cfd8b6c019d5.jpgPost 491640
257
Datsun B10 Coupe engine used a dual-outlet exhaust manifold.
14000-25700 manifold assembly (intake & exhaust)
14003-18000 intake manifold [same as early non-Coupe]
14004-25700 exhaust manifold [dual outlet with 3-studs]
22131.jpgAlbum 22131
H19
H19 casting
25598.jpgAlbum 25598 25599.jpgAlbum 25599 25600.jpgAlbum 25600
B210 Early
From the Nov 1976 JDM catalog
*Single Carb
* Gasket 14035-18000
14003-H1900 M/T w/o Mastervac
14003-H5101 A/T, M/T with Mastervac
*Twin Carb (A12T)
* Gasket 14035-H2300
14003-H5731 A12T
14003-H5732 A12T from '75-3 ^H5731
A13 USA (1974)
28766.jpgAlbum 28766
B210 Late
From the B210 Japanese Domestic Model parts catalog (Jul 1978)
1975 VB210 manifold (Showa 50) with Throttle Opener
A12
14003-H5101 V
A12S
14003-H7400 S,K
A14
14003-H7200 V
14003-H7860 V
A14T
14003-M2450 A14T
F10
2nd generation Nissan Cherry.
Canada 1977 manifold A14
23746.jpgAlbum 23746
Canada 1978 manifold A14
23747.jpgAlbum 23747
B120
  • 14003-H1000 MANIFOLD-intake 1971-1974 [old bolt pattern, D-shaped heater gasket]
  • 14003-H5111 MANIFOLD-INTAKE 7510-7803 [old bolt pattern, triangular heater gasket]
  • 14003-H8110 MANIFOLD-INTAKE 7804-7907
  • 14003-G2561 MANIFOLD-INTAKE 7908-8109 [new bolt pattern, D-shaped heater gasket]
  • 14003-G2600 MANIFOLD-INTAKE 8110-8910
  • 14001-95W00 MANIFOLD-INTAKE 8910- [late-model water-heated carb]
Late Sunny Truck
1989-up B122 manifold: Round-port, wet style, new bolt-pattern, with extended-length carb flange for DFC306 feedback carburetor
7887.jpgAlbum 7887
21271.jpgAlbum 21271
18698.jpgAlbum 18698 18699.jpgAlbum 18699 18697.jpgAlbum 18697
19111.jpgAlbum 19111 19113.jpgAlbum 19113 19114.jpgAlbum 19114
174_5c107bc3cc30c.jpgPost 490142 174_5c107bdcbf8ed.jpgPost 490142 174_5c107c1a3d809.jpgPost 490142 174_5c107c878a709.jpgPost 490142 174_5c107c9849f4f.jpgPost 490142
New-bolt pattern (like an A14):
21288.jpgAlbum 21288
B140
B140 bakkie A14 uses a divorce intake manifold
GT000 intake manifold and G1099 exhaust manifold
31364.jpgAlbum 31364 31365.jpgAlbum 31365
B310
Australia
Found in Australia on A15 engine:
* new bolt pattern
* divorced type (note water outlet at front)
* emissions sensor near front
* brake booster tap
* accessory bolt bosses
* old-style (side mounted) Air Cleaner bosses
24710.jpgAlbum click to view
Gasket 14035
* Van: dry port
* Sedan, Coupe: wet port
14035-18000 round dry port -7910 (A12 Van old bolt pattern) <> 14035-18010
14035-H7200 oval dry port  -7910 (A14 Van) <> 14035-H7210
14035-H7400 round dry port 7910- (A12/A14 Van new bolt pattern) <> 14035-H7410
14035-H8501 round wet port (A12S/A13)
14035-H8901 oval wet port (A14 except Van + A15)
14035-H9201 oval wet port notched for EFI
14003-H8551 > 14003-H8550 (A12A -7909)
* A12A 7910-8010
* A13  8011-
A13 with H86 exhaust (A13/A15) 3-bolt
14003-H8950 A14 -7909
14003-W7550 A14 7910-8010
A14
174_56b1e963ce25c.jpgPost 476088 174_56b1e9234ee34.jpgPost 476088 174_56b1e95889c47.jpgPost 476088
North America
USA A14/A15 FEDERAL (except California)
14003-H9500 MANIFOLD-INTAKE FED 0880- 0 14003-H9950 [1981-1982 small oval]
21218.jpgAlbum 21218
14003-H9950 MANIFOLD-INTAKE FED -0780 2 14003-H9900
* 14003-H9900 MANIFOLD-INTAKE FED 0879- 0 14003-H9100
14003-H9100 MANIFOLD-INTAKE FED (EXC KFU) 0878-0779 0 14003-H7200
14885.jpgAlbum 14885 17233.jpgAlbum 17233
14003-H7202 MANIFOLD-INTAKE FED (EXC KFU) replaced 14003-H7200
14003-H7200 MANIFOLD-INTAKE FED (EXC KFU)
FED KFU (A14 round port)
wet & dry types
19876.jpgAlbum 19876
14003-H7400 MANIFOLD-INTAKE FED(KFU) -0778
14810.jpgAlbum 14810
14003-H9160 MANIFOLD-INTAKE FED(KFU) replaced 14003-H7400
19797.jpgAlbum 19797
USA CALIFORNIA A14/A15
14003-H9160 MANIFOLD-INTAKE CAL A14 replaced 14003-H7400
14003-H7400 MANIFOLD-INTAKE CAL A14 -0778
14003-H9550 MANIFOLD-INTAKE CAL 0678-0779
14003-H9950 MANIFOLD-INTAKE CAL -0780 superceeded 14003-H9900
* 14003-H9900 MANIFOLD-INTAKE CAL 0879- replaced 14003-H9160
CANADA A14/A15
14003-H7400 MANIFOLD-INTAKE A14 CAN -0778
14003-H9160 MANIFOLD-INTAKE CAN 0879-
Vanette
Dry Manifold
C120 A12+A14.(V,T) 14003-G2561 7906-8106 JAP
C120 A12 7810- LHD, 7810-7907 JAP
14003-H8110 Looks like USA B110
C120 A14
14003-H7861 7810-7906
14003-W8600 7907-8105
Water Heated Manifold
C120 JAP 14003-W7550 8006- > 14003-W7500
C120 7901-8706 A15 LHD
* 14003-H8850 > 14003-H8805
* water heated manifold (old style carburetor)
Water Heated Carburetor
G51 manifold - water heated carburetor. Very similar to the A12 manifold 14001-95W00 except for port shape
C22 JAP A15 14003-G5150 > 14003-G5100
26297.jpgAlbum 26297 26298.jpgAlbum 26298 26294.jpgAlbum 26294 26295.jpgAlbum 26295 26296.jpgAlbum 26296
C22 A15 14003-G5250 8605-9304 water heated carburetor, EUR w/EGR, GEN LHD w/EGR welch plug
C22 A15S with Hitachi DCZ306 carburetor & air cleaner attached
N10
Datsun Cherry EUR
A10 14003-M3700 7808-8107
* looks like B10 manifold
A12 [14003-M3700] 7808-8107
    14003-M5510 7808-8107 SWE
A14 14003-M8900 8008-8107
* dry manifold
LDV
Late 1400 bakkie manifold appear to be same as late Sunny Truck.
26023.jpgAlbum 26023
Or maybe not, notice the thick water-passage section
Aftermarket Manifold
Webers, Dellortoes, Solex and more!
See Main Article: Aftermarket intake manifold
Custom
See also: EFI Manifold
turbo log manifold
28226.jpgAlbum 28226
Tunnel Ram manifolds
1739.jpgAlbum 1739 1165.JPGAlbum 1165
CUSTOM MANIFOLDS
Steel manifold is difficult to make. You need to form steel to ovals to round to tapered out. When used with a turbocharger, Steel won't break and would be ported to your cylinder head.
  • "Mammi Motors" on the Peninsula in Victoria (40 mins from Melbourne).
    Ph: (03) 5977 7973
    • Steel manifold for maybe $250 for Weber 40s or 45s. ** They also do nice head work for around $300 which includes porting and 1600 exhaust valves
2365.jpgAlbum 2365
EFI
For EFI manifolds, see EFI Manifold
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Intake_Manifold"
This page has been accessed 200,830 times. This page was last modified 04:31, 28 November 2025. Content is available under Datsun 1200 Club.
