There is no page titled ":56-series_transmission". You can create this page.
For more information about searching Datsun 1200 Club, see Searching Datsun 1200 Club.
Showing below up to 20 results starting with #1.
View (previous 20) (next 20) (20 | 50 | 100 | 250 | 500).
No page title matches
Page text matches
- Clutch (17656 bytes)
- 63-Series Transmission (11903 bytes)
- Wide gearbox crossmember (2711 bytes)
9: * [[56-Series_Transmission#56_5-speed_swap_Notes]] - 56-Series Transmission Parts (16131 bytes)
53: * [[Synchros#56-Series_Transmission|varies by year, see list]]
143: 95W dual mount 8910- (See [[56-Series_Transmission#1990s]]) - Transmission Overview (6766 bytes)
1: All Datsun 1200s were fitted with a [[56-Series_Transmission]]. Most Datsun 1200s come with a 4-speed floor sh...
24: {{SeeMainArticle|56-Series_Transmission#Identification|1680}}
149: See main article: [[56-Series_Transmission_Parts#Output_Shaft_Seal|Output Shaft Seal]] - L-series Engine Swap (21327 bytes)
- Gearbox Mount (12312 bytes)
377: * Putting F5C56A into 4-speed cars: [[56-Series_Transmission#56_5-speed_swap_Notes]] - Transmission Identification (1680 bytes)
1: ... were fitted with a 3-speed, 4-speed or 5-speed [[56-Series_Transmission]]. Other transmissions that will fit the Datsun 1...
26: * [[56-Series_Transmission]] - 6-speed (5672 bytes)
- 1984 Nissan Competition Catalog (13558 bytes)
112: ** [[56-Series_Transmission#Option_1_Middle-Close_Ratio|4-speed Option 1 (mid...
113: ** [[56-Series_Transmission#Option_2_Ultra-Close_Ratio|4-speed Option 2 (ultr...
114: ** [[56-Series_Transmission#Gears|5-speed F5C56A]]
115: *** [[56-Series_Transmission#56 5-speed swap Notes|5-speed mounting parts]] - Release Bearing (12926 bytes)
129: B120: Transmission front [[56-Series_Transmission#Case|case]] differs, but how? - 71 Swap (2717 bytes)
- 720 (107 bytes)
- F5C56 (8907 bytes)
39: [[56-Series_Transmission#Clutch_Cable_Hole|clutch hole]]: B210 angular | B...
46: {{See|56-Series_Transmission#Identification}}
127: {{Main|56-Series_Transmission#5-speed_Ratios}}
130: {{Main|56-Series_Transmission_Parts#F5C56}} - Synchros (14695 bytes)
130: {{See|56-Series_Transmission_Parts#Synchros}}
324: * 4-speed [[56-Series_Transmission|F4W56A]] early
356: * [[56-Series_Transmission#Late_Model_56A|Late 56A 4-speed]] 4 used - Speedometer Cable (2845 bytes)
58: All [[56-Series_Transmission|56-series 4-speed or 5-speed]] use the same cable... - Neutral Switch (2059 bytes)
- Top Switch (3572 bytes)
- Transmission Interchange (9537 bytes)
66: ...ively. For a list of the minor differences, see [[56-Series_Transmission#Ute]].
103: * [[56-Series_Transmission#56_5-speed_swap_Notes|56-series 5-speed Swap Note...
132: * 56 5-speed. See [[56-Series_Transmission#56_5-speed_swap_Notes|56 5-speed swap Notes]] - There's more future in a DATSUN (11071 bytes)
