Search results
For query "60-series_transmission"
There is no page titled ":60-series_transmission". You can create this page.
For more information about searching Datsun 1200 Club, see Searching Datsun 1200 Club.
Showing below up to 20 results starting with #1.
View (previous 20) (next 20) (20 | 50 | 100 | 250 | 500).
No page title matches
Page text matches
  1. Clutch (17656 bytes)
  2. 63-Series Transmission (11903 bytes)
  3. Wide gearbox crossmember (2711 bytes)
    10: * [[60-Series_Transmission#Rear_Crossmember]]
  4. 56-Series Transmission Parts (16131 bytes)
  5. Transmission Overview (6766 bytes)
  6. L-series Engine Swap (21299 bytes)
  7. Gearbox Mount (12312 bytes)
    12: * [[60-Series_Transmission#Rear_Crossmember|60-Series Transmission Swap Note...
    117: Also see [[60-Series_Transmission#Using_B310_Mount|60-series swap notes]]
    378: * Putting 60-series transmission into 1200: [[60-Series_Transmission#Swap_Notes]]
  8. Transmission Identification (1680 bytes)
  9. 6-speed (5672 bytes)
  10. 1984 Nissan Competition Catalog (13558 bytes)
  11. Release Bearing (12926 bytes)
  12. 71 Swap (2717 bytes)
  13. 720 (107 bytes)
  14. F5C56 (8907 bytes)
  15. Synchros (14695 bytes)
    325: * 4-speed [[60-Series_Transmission|F4W60L]] A14/A15 gearbox
    352: * 5-speed [[60-Series_Transmission|FS5W60L]] 5 used
    354: * 4-speed [[60-Series_Transmission|F4W60L]] 4 used
  16. Speedometer Cable (2845 bytes)
  17. Neutral Switch (2059 bytes)
  18. Top Switch (3572 bytes)
  19. Transmission Interchange (9537 bytes)
    95: ...or shift (FS) by swapping the rear housing. See [[60-Series_Transmission#Vanette_Transmission]]
    104: * [[60-Series_Transmission#60a_5-speed_swap_Notes|60-series 5-speed Swap Not...
    133: * 60-series. See [[60-Series_Transmission#Rear_Crossmember|60 Crossmember]]
  20. There's more future in a DATSUN (11086 bytes)
    93: MPG with [[60-Series_Transmission|60A 5-speed]] brown [[Transmission_Gear_Control#B...
Search in namespaces :
List redirects   Search for
