There is no page titled ":Inside". You can create this page.
For more information about searching Datsun 1200 Club, see Searching Datsun 1200 Club.
Showing below up to 20 results starting with #1.
View (previous 20) (next 20) (20 | 50 | 100 | 250 | 500).
No page title matches
Page text matches
- Magazine Articles (24327 bytes)
48: * Hot4s 11 1993 {{cover|26542}} (inside cover) 1972 Datsun 1200 Coupe 'AGR012' 6-pages - Heater (11009 bytes)
123: The heater hoses are 1/2 inch inside diameter hose. However, the original Nissan hoses...
208: Inside diameter: 13mm
236: # Remove heater from inside car, & plug the two holes in the firewall - Strut Insert Part Numbers (10856 bytes)
150: ...NI Sport 8641-1048, 42.30 mm dia. (too big to fit inside 45 mm strut)
170: * diameter 38.30 mm (will fit inside 45 mm tube)
266: * Inside Diameter: about 38mm (~1.5 inch) - Rear Axle Swaps (24555 bytes)
321: ..., and comes with 10" drum brakes so they will fit inside 14" wheels. - Emission Controls (28449 bytes)
307: ...acuum-controlled diaphragm motor controls a valve inside the snout and makes this system easy to recognize...
418: ...out of the air, and oil fumes from causing sludge inside the engine. It is recommended to keep this for al... - Weber 32/36 Carburetor (22579 bytes)
90: ...company}} licensed the DGV design from [[Weber]]. Inside the carb it actually says "Weber", but outside th...
146: ...]] (you can connect it to the air cleaner — inside the filter portion) - Part Numbers Index (8259 bytes)
122: [[Roof Part Numbers|Roof]] PANEL, SUNVISOR & INSIDE BACK MIRROR - Gilmer drive (4896 bytes)
59: ...ngle recess so that the gilmer pully can sit just inside the origional crank pulley on the engine.. $70 - Alternator Wiring (4842 bytes)
77: ...e "L" terminal of the external regulator. A relay inside the [[Voltage Regulator]] turns the dash lamp on/...
85: ...sh lamp on and off, using a transistorized switch inside the alternator. - Lamp Wiring (8404 bytes)
164: ... BOLT, the right-side rear bumper hold-down bolt (inside the car). - B-210 Electronic Distributor Swap (12611 bytes)
25: ...ntrol unit somewhere. For reliabilty it should be inside the cabin for protection from dampness and vibrat...
84: ..., the 'black box' for the B210 distributor mounts inside the car on the right kick panel. So it may be imp...
86: ...ly necessary to use, but is handy to connect the "inside" wiring with the "outside" wiring. - Installing Distributor (2628 bytes)
33: ...ints just beginning to open, or Electronic: teeth inside distributor lined up perfectly - 63-Series Transmission (11903 bytes)
197: ...ssmember mounting brackets have been removed from inside the tunnel. This custom crossmember bolts to the ... - Engine Trouble Diagnosis (4655 bytes)
22: inside distributer cap. -dry out ... - 60-Series Transmission (16379 bytes)
301: ... [{{Post|462910}} Ziggy did]. You can add a cover inside the passenger compartment. - Wide gearbox crossmember (2711 bytes)
22: ...ssmember mounting brackets have been removed from inside the tunnel. The new custom crossmember bolts to t... - Engine Troubleshooting Overview (17895 bytes)
46: ... to ensure that it is dry and clean. Examine both inside and outside of the cap for cracks or tracking, pa... - Wheels (16877 bytes)
19: ...-brake wheels are 13" but have 4mm extra diameter inside, possibly for clearance of the large brakes. Thes...
91: ...ter line). This offset perfectly centers the tire inside the wheel well.
110: ... tyre contact patch is outside SAI, '-' where its inside the SAI.
155: ...n the [[tires]] -- the fronts will probably scrub inside the guards
157: ...tle on the front. More positive offset bring them inside, but then you risk hitting the struts - Tires (14923 bytes)
114: ...tuck up under the rear fender (it will have to go inside the fender well arch). That is the height of a st... - VB110 (5815 bytes)
20: * rail inside rear window
