Search results
For query "Search.YJ"
There is no page titled ":Search.YJ". You can create this page.
For more information about searching Datsun 1200 Club, see Searching Datsun 1200 Club.
Showing below up to 20 results starting with #1.
View (previous 20) (next 20) (20 | 50 | 100 | 250 | 500).
No page title matches
Page text matches
  1. FAQ (6725 bytes)
    99: NOTE: Be sure to use the search button to see if your info already is in the ency...
  2. Datsun 1200 encyclopedia (3415 bytes)
    5: <font size=3 color=red>FAST SEARCH box</font> IS LEFT - at the left of this page. Sc...
    64: ... in the Club Wiki. To find them all, use the FAST SEARCH box on the LEFT SIDE of every page.
  3. History of Datsun 1200 (16941 bytes)
    6: First B110 off the line, January 1970 {{search|%E6%97%A5%E7%94%A3%E3%82%B5%E3%83%8B%E3%83%BC2%E4...
  4. Magazine Articles (24401 bytes)
    161: ..."background-color:LightBlue;">Web Search:</span>{{search|%E3%83%A2%E3%83%BC%E3%82%BF%E3%83%BC%E3%83%95%E3%...
    184: {{search|%E3%82%AA%E3%83%BC%E3%83%AB%E3%83%89%E3%82%BF%E3%...
    205: * Retro Car - just about every issue: search [http://auctions.yahoo.co.jp Yahoo Auctions Japan...
    209: * {{search|Lightning%E3%83%8B%E3%83%83%E3%83%9D%E3%83%B3%E6%...
  5. Heater (11725 bytes)
    158: {{searchPart|27021-H1000}} HOSE-WATER [to outlet, front of...
    162: {{searchPart|27075-H1000}} CONNECTOR-WATER OUTLET [lower r...
    163: {{searchPart|27070-H1000}} CONNECTOR-WATER INLET [rear of ...
    164: {{searchPart|27020-G1900}} 27020-H1000 HOSE-WATER [from in...
    165: {{searchPart|X2160-30503}} HOSE-WATER [from cock to core] ...
  6. Rear Axle Swaps (24650 bytes)
    251: Order a custom-width 9" housing and axles from {{search|Currie+9-inch|Currie}}, with leaf spring pads in ...
    321: Canada or USA {{search|Ranger+8.8|Ford Ranger 8.8}} can be narrowed at h...
  7. Puerto Rico (4691 bytes)
    3: {{search.me|Puerto+Rico|Puerto Rico}}
    16: [http://google.com/search?q=delirium+racing+datsun&tbm=isch Delirium Racing...
    21: search [http://www.youtube.com/results?search_query=Puerto+Rico+Datsun YouTube: Puerto Rico Dat...
    23: ...ickest Datsun 1200 - Men in Black 7.055 @ 194mph}}search {{images|%22Men+In+Black%22+Datsun|Men in Black}}...
  8. Ignition Timing (9164 bytes)
    104: Older style (analog) Dwell-Tachometers {{search|dwell+meter|are inexpensive $20 up}}
  9. Fuel pump pressure test (3334 bytes)
    20: ...buy one (about $25 at [http://www.sears.com/shc/s/search_10153_12605?vName=Tools&cName=Auto+%26+Mechanics+...
    24: {{search|fuel+pump+test+gauge|fuel pump test gauge}}
  10. Choke Operation and Adjustment (6774 bytes)
    117: search {{search|Nissan+210+choke|Datsun/Nissan 1200/B210/210 chok...
    134: {{search|%E3%83%80%E3%83%83%E3%83%88%E3%82%B5%E3%83%B3%20%...
  11. Weber 32/36 Carburetor (22613 bytes)
    6: The Weber {{search.me|DGV}} series is a 2-barrel carburetor from the...
    125: Go to the library and get this book: {{search|Holley+5200+Handbook+Mike+Urich|"Holley Carbureto...
    281: ...url/index=books&field-keywords=weber%20carburetor&search-type=ss&bq=1/103-2991333-4284651 Amazon.com]&#972...
    287: * {{search|weber+32%2F36|Google search for Weber 32/36}}
    313: {{search|Weber+K8624+Nissan|Weber K8624 Nissan}}
  12. Parts Sources (15979 bytes)
    3: Use the '''Search box''' (below, bottom of this page) to find '''sp...
    135: ...rency=&submit=+Search+ eBay Australia Datsun 1200 search]
    137: ...er=d&srchdesc=y&BasicSearch= eBay USA Datsun 1200 search]
    140: ...com Classifieds Forum]. Use the search feature -- search for older posts -- and if the post doesn't say th...
    142: For easier searching use:
  13. Radio (17232 bytes)
    1: ... included [[Clarion]], [[Hitachi]], Philips and {{search|Ferris+Bros.+Pty.+Ltd.|Ferris}}.
    431: Many {{search|vintage+shaft+style+car+radio|classic '''Shaft-st...
    433: For example: {{search|Sanyo+FT-C2|Sanyo FT-C2}} auto-reverse cassette s...
    436: ... There brands included Jensen, RCA and Acoustic Research. Audiovox was renamed Voxx in 2012.
    447: * {{search|car+stereo+shaft+Amazon|$45 Amazon.com}}
  14. Gilmer drive (4901 bytes)
    66: ...26cid%3D71&ref=datsun1200.com%2Fmodules%2Fnews%2F search]
  15. Clutch (17014 bytes)
    6: {{search|Nissan+B210+clutch|Nissan B210 Clutch Kit}}
    11: * {{search|Oreilly+Auto+Parts+1980+Nissan+210+clutch+set|O'R...
    121: [http://www.oreillyauto.com/site/c/search/Clutch+Set/01351/C0015.oap?keyword=clutch&year=19...
    187: ...362251273780&subsection=clutchselector&searchStr=csearchStr3&cstep1=step1&cstep2=step2&cstep3=step3&carmak...
    427: This is why a {{search|scattershield|scattershield}} or blanket is requi...
  16. Yahoo Auctions Japan (4625 bytes)
    6: Example searches:
    7: * [http://auctions.yahoo.co.jp/search/search?p=%E3%82%B5%E3%83%8B%E3%83%BC%E3%80%80%E3%82%AF%E...
    8: * [http://auctions.yahoo.co.jp/search/search?p=%A5%B5%A5%CB%A1%BC+B110&alocale=0jp&acc=jp &#12...
    9: * [http://auctions.yahoo.co.jp/search/search?p=%A5%B5%A5%CB%A1%BC%A5%C8%A5%E9%A5%C3%A5%AF&aloc...
    10: * [http://auctions.yahoo.co.jp/search/search?p=%A5%B5%A5%CB%A1%BC%A5%C8%A5%E9%A5%C3%A5%AF&aloc...
  17. Fuel Injection (19606 bytes)
    206: ...s its firing signal from the coil....(as far as researched similar to camira delco unit)
    311: ...ion]] can be used with or without fuel injection. Search the main forum for more information. Texans prefe...
    368: ...t-pressure, and are called [http://www.google.com/search?q=return-less+fuel+injection return-less fuel inj...
  18. Ignition Switch (12669 bytes)
    133: {{searchPart|48750-H1900}} ELECTRICAL IGNITION SWITCH ASSE...
    144: {{searchPart|48750-E7705}} late 1971, 1972-1973 USA
    155: * {{search|Standard+Motor+Products+US-120|Standard Motor Pro...
    156: * {{search|ACDelco+E1406|ACDelco E1406}}
    158: ...hange Numbers: Nissan 48750-E7005, 48750-E7705, {{search|Subaru+783131010|Subaru 783131010}}
  19. 200SX EFI (13119 bytes)
    81: [http://google.com/search?q=wix+33022+filter search]
    207: "Bye Bye Carbs" by {{search|Kelvin%20Dietz%20Datsun|Kelvin Dietz}} from [http...
  20. Nissan B140 (13604 bytes)
    219: ...rom Nissan South Africa, Ship to USA or AU or NZ. Search by part number.
Search in namespaces :
List redirects   Search for
