There is no page titled ":Search.YJx". You can create this page.
For more information about searching Datsun 1200 Club, see Searching Datsun 1200 Club.
Showing below up to 20 results starting with #1.
View (previous 20) (next 20) (20 | 50 | 100 | 250 | 500).
No page title matches
Page text matches
- FAQ (6725 bytes)
99: NOTE: Be sure to use the search button to see if your info already is in the ency... - Datsun 1200 encyclopedia (3415 bytes)
5: <font size=3 color=red>FAST SEARCH box</font> IS LEFT - at the left of this page. Sc...
64: ... in the Club Wiki. To find them all, use the FAST SEARCH box on the LEFT SIDE of every page. - History of Datsun 1200 (16941 bytes)
6: First B110 off the line, January 1970 {{search|%E6%97%A5%E7%94%A3%E3%82%B5%E3%83%8B%E3%83%BC2%E4... - Magazine Articles (24401 bytes)
161: ..."background-color:LightBlue;">Web Search:</span>{{search|%E3%83%A2%E3%83%BC%E3%82%BF%E3%83%BC%E3%83%95%E3%...
184: {{search|%E3%82%AA%E3%83%BC%E3%83%AB%E3%83%89%E3%82%BF%E3%...
205: * Retro Car - just about every issue: search [http://auctions.yahoo.co.jp Yahoo Auctions Japan...
209: * {{search|Lightning%E3%83%8B%E3%83%83%E3%83%9D%E3%83%B3%E6%... - Heater (11725 bytes)
158: {{searchPart|27021-H1000}} HOSE-WATER [to outlet, front of...
162: {{searchPart|27075-H1000}} CONNECTOR-WATER OUTLET [lower r...
163: {{searchPart|27070-H1000}} CONNECTOR-WATER INLET [rear of ...
164: {{searchPart|27020-G1900}} 27020-H1000 HOSE-WATER [from in...
165: {{searchPart|X2160-30503}} HOSE-WATER [from cock to core] ... - Rear Axle Swaps (24650 bytes)
251: Order a custom-width 9" housing and axles from {{search|Currie+9-inch|Currie}}, with leaf spring pads in ...
321: Canada or USA {{search|Ranger+8.8|Ford Ranger 8.8}} can be narrowed at h... - Puerto Rico (4691 bytes)
3: {{search.me|Puerto+Rico|Puerto Rico}}
16: [http://google.com/search?q=delirium+racing+datsun&tbm=isch Delirium Racing...
21: search [http://www.youtube.com/results?search_query=Puerto+Rico+Datsun YouTube: Puerto Rico Dat...
23: ...ickest Datsun 1200 - Men in Black 7.055 @ 194mph}}search {{images|%22Men+In+Black%22+Datsun|Men in Black}}... - Ignition Timing (9164 bytes)
104: Older style (analog) Dwell-Tachometers {{search|dwell+meter|are inexpensive $20 up}} - Fuel pump pressure test (3334 bytes)
20: ...buy one (about $25 at [http://www.sears.com/shc/s/search_10153_12605?vName=Tools&cName=Auto+%26+Mechanics+...
24: {{search|fuel+pump+test+gauge|fuel pump test gauge}} - Choke Operation and Adjustment (6774 bytes)
117: search {{search|Nissan+210+choke|Datsun/Nissan 1200/B210/210 chok...
134: {{search|%E3%83%80%E3%83%83%E3%83%88%E3%82%B5%E3%83%B3%20%... - Weber 32/36 Carburetor (22613 bytes)
6: The Weber {{search.me|DGV}} series is a 2-barrel carburetor from the...
125: Go to the library and get this book: {{search|Holley+5200+Handbook+Mike+Urich|"Holley Carbureto...
281: ...url/index=books&field-keywords=weber%20carburetor&search-type=ss&bq=1/103-2991333-4284651 Amazon.com]ό...
287: * {{search|weber+32%2F36|Google search for Weber 32/36}}
313: {{search|Weber+K8624+Nissan|Weber K8624 Nissan}} - Parts Sources (15979 bytes)
3: Use the '''Search box''' (below, bottom of this page) to find '''sp...
135: ...rency=&submit=+Search+ eBay Australia Datsun 1200 search]
137: ...er=d&srchdesc=y&BasicSearch= eBay USA Datsun 1200 search]
140: ...com Classifieds Forum]. Use the search feature -- search for older posts -- and if the post doesn't say th...
142: For easier searching use: - Radio (17232 bytes)
1: ... included [[Clarion]], [[Hitachi]], Philips and {{search|Ferris+Bros.+Pty.+Ltd.|Ferris}}.
431: Many {{search|vintage+shaft+style+car+radio|classic '''Shaft-st...
433: For example: {{search|Sanyo+FT-C2|Sanyo FT-C2}} auto-reverse cassette s...
436: ... There brands included Jensen, RCA and Acoustic Research. Audiovox was renamed Voxx in 2012.
447: * {{search|car+stereo+shaft+Amazon|$45 Amazon.com}} - Gilmer drive (4901 bytes)
66: ...26cid%3D71&ref=datsun1200.com%2Fmodules%2Fnews%2F search] - Clutch (17014 bytes)
6: {{search|Nissan+B210+clutch|Nissan B210 Clutch Kit}}
11: * {{search|Oreilly+Auto+Parts+1980+Nissan+210+clutch+set|O'R...
121: [http://www.oreillyauto.com/site/c/search/Clutch+Set/01351/C0015.oap?keyword=clutch&year=19...
187: ...362251273780&subsection=clutchselector&searchStr=csearchStr3&cstep1=step1&cstep2=step2&cstep3=step3&carmak...
427: This is why a {{search|scattershield|scattershield}} or blanket is requi... - Yahoo Auctions Japan (4625 bytes)
6: Example searches:
7: * [http://auctions.yahoo.co.jp/search/search?p=%E3%82%B5%E3%83%8B%E3%83%BC%E3%80%80%E3%82%AF%E...
8: * [http://auctions.yahoo.co.jp/search/search?p=%A5%B5%A5%CB%A1%BC+B110&alocale=0jp&acc=jp ...
9: * [http://auctions.yahoo.co.jp/search/search?p=%A5%B5%A5%CB%A1%BC%A5%C8%A5%E9%A5%C3%A5%AF&aloc...
10: * [http://auctions.yahoo.co.jp/search/search?p=%A5%B5%A5%CB%A1%BC%A5%C8%A5%E9%A5%C3%A5%AF&aloc... - Fuel Injection (19606 bytes)
206: ...s its firing signal from the coil....(as far as researched similar to camira delco unit)
311: ...ion]] can be used with or without fuel injection. Search the main forum for more information. Texans prefe...
368: ...t-pressure, and are called [http://www.google.com/search?q=return-less+fuel+injection return-less fuel inj... - Ignition Switch (12669 bytes)
133: {{searchPart|48750-H1900}} ELECTRICAL IGNITION SWITCH ASSE...
144: {{searchPart|48750-E7705}} late 1971, 1972-1973 USA
155: * {{search|Standard+Motor+Products+US-120|Standard Motor Pro...
156: * {{search|ACDelco+E1406|ACDelco E1406}}
158: ...hange Numbers: Nissan 48750-E7005, 48750-E7705, {{search|Subaru+783131010|Subaru 783131010}} - 200SX EFI (13119 bytes)
81: [http://google.com/search?q=wix+33022+filter search]
207: "Bye Bye Carbs" by {{search|Kelvin%20Dietz%20Datsun|Kelvin Dietz}} from [http... - Nissan B140 (13604 bytes)
219: ...rom Nissan South Africa, Ship to USA or AU or NZ. Search by part number.
