Search results
For query "Sidedraft"
There is no page titled ":Sidedraft". You can create this page.
For more information about searching Datsun 1200 Club, see Searching Datsun 1200 Club.
Showing below up to 20 results starting with #1.
View (previous 20) (next 20) (20 | 50 | 100 | 250 | 500).
Article title matches
  1. Engine Bay Photo Index - Sidedraft Carb (2455 bytes)
    1: ...itachi Twin Carb]]. Following are single and dual sidedraft systems on A-series engine.
    3: = Single Sidedraft =
    10: = Dual Sidedraft =
  2. Sidedraft Air Filters (1991 bytes)
    1: .... This or no screen provides the fullest "awesome sidedraft sound", but at the expense of increased engine we...
    11: ...ne wear, using no filter or air horn allows [[LHD Sidedrafts]].
    16: Air horns provides the fullest "awesome sidedraft sound" and also a performance boost (the length c...
Page text matches
  1. Carburetor Overview (3188 bytes)
    3: ...yles|Datsun 1200 GX models]] used twin Hitachi 38 sidedraft carburetors with a manual choke system.
  2. Weber 32/36 Carburetor (22613 bytes)
    333: = Sidedraft =
  3. Fuel Injection (19606 bytes)
    114: * Weber DCOE single sidedraft manifold
    115: * Weber DCOE dual sidedraft manifold
    130: ...abody A14 Kit M-030] ($295 USD) Rowland DCOE twin-sidedraft manifold for oval-port A-series engine
    138: * Your own Weber single-sidedraft manifold (~$100 used)
    266: Got a [[Weber DCOE carburetor]] sidedraft manifold? '''Design your own system'''.
  4. Choosing A Carburetor (14914 bytes)
    7: = Which is better? Sidedraft or downdraft? =
    10: With most inline engines sidedrafts are better because the air/fuel mixture goes mor...
    12: ...e, and good for high-end power. Though few if any sidedraft manifolds use long runners, but are instead desig...
    17: Think about [[Fuel Injection]], which can use the sidedraft carburetor manifold or factory Datsun parts. It's...
    32: ...e, and good for high-end power. Though few if any sidedraft manifolds use long runners, but are instead desig...
  5. Aftermarket intake manifold (7008 bytes)
    1: ...arket inlet manifold to fit SUs, Webers and other sidedrafts, as well as alternative manifolds for the stock ...
    6: * Hitachi sidedrafts can use SU manifolds, but there are two-bolt dia...
    151: Dual-sidedraft manifold for A12GX(?) oval ports by SK (now [[OER...
  6. PB110 (13462 bytes)
    41: Excellent GX Brochure - Notice the engine (sidedraft carbs), fancy seats, and the same-as-B110 dashboa...
  7. Weber DCOE carburetor (9502 bytes)
    1: Weber DCOE sidedraft carburetor. The traditional racing carburetor.
    56: {{Sidedraft}}
  8. Engine buildup (10548 bytes)
    82: * Sidedraft inlet manifold
    83: * Twin sidedraft carburetors (see [[Choosing A Carburetor]])
  9. Weber (504 bytes)
    8: [[Weber DCOE carburetor]] (the famous sidedraft)
  10. Hitachi Twin Carb (12238 bytes)
    1: ...s, or it may be about the (non-Datsun) British SU sidedrafts.
    59: ...air of left- and right- hand '''Hitachi HJE38W''' sidedraft carbs. These are the true "dome-top" Hitachis, al...
    147: ... you can use SU, Zenith-Stromberg (ZS) or Hitachi sidedrafts, but note that the linkage, hose locations and a...
  11. Brake Upgrades (9218 bytes)
    147: ...is sometimes done to LHD 1200s so we can fit dual sidedraft carbs. It is legal in USA (very few states have a...
  12. L-series Engine Swap (21299 bytes)
    465: * The bonnet will close over sidedraft carburetors (inluding twin Hitachi carburetors)
  13. Air Cleaner (11281 bytes)
    198: ...ulsar#N13]] Remote filter, or could modify to fit sidedrafts.
    251: = Sidedraft Air Cleaner =
    252: {{SeeMainArticle!|Sidedraft_Air_Filters}}
    255: {{SeeMainArticle!|Sidedraft_Air_Filters#No_Filter}}
  14. Throttle Cable (4501 bytes)
    119: = Sidedraft Cable =
  15. Topgear A12 Turbo (4211 bytes)
    24: Carburetor was a Hitachi sidedraft at first (genuine factory Nissan carburetor of th...
  16. Mikuni PHH (11166 bytes)
    1: ...retors are a licensed version of the famous Solex sidedraft carburetor. They may be marked Mikuni, Solex or b...
    6: ...r DCOE and a Solex. They are the "set and forget" sidedrafts. Mikuni North America is the primary jet supplie...
    21: {{Sidedraft}}
  17. Nissan A Engine (12516 bytes)
    61: ... and A12T in the Datsun Cherry. With twin Hitachi sidedraft carburetors, a longer duration camshaft and 10:1 ...
  18. 1200GXman (6537 bytes)
    24: .... Personally I would say they are after the Weber sidedraft the best carb you can fit to your Datsun engine. ...
  19. Carburetor Sizing (6961 bytes)
    61: == Single Sidedraft ==
    64: A typical single-sidedraft setup has a single barrel feeding two cylinders, ...
  20. A12 Engine (4781 bytes)
    54: ... and A12T in the Datsun Cherry. With twin Hitachi sidedraft carburetors, a longer duration camshaft and 10:1 ...
Search in namespaces :
List redirects   Search for
