Search results
For query "Unibody"
There is no page titled ":Unibody". You can create this page.
For more information about searching Datsun 1200 Club, see Searching Datsun 1200 Club.
Showing below up to 20 results starting with #1.
View (previous 20) (next 20) (20 | 50 | 100 | 250 | 500).
No page title matches
Page text matches
  1. Wiring (8463 bytes)
    63: ...ker wire, grounding the battery and engine to the unibody in a better way (use a thick wire and good connec...
  2. Trayback Utes (2462 bytes)
    1: ... versions of the Ute. This is done by cutting the unibody and replacing the rear half with a subframe or a ...
  3. B120 (16124 bytes)
    154: ... avoiding the 25% tax), but with the 1200 being a unibody, that was not feasible. However, a more likely re...
    250: ...yata Publica. Only the Sunny and the Publica were unibody vehicles.
  4. Model names (18990 bytes)
    321: ...(Terrano/QX4), a non-truck-based model which used unibody suspension. It is slightly larger than the D22/WD...
  5. ADR (14718 bytes)
    163: ...k or rear-engine), or "significant" change to the unibody. This is how large engines like the SR20DET are a...
  6. Body (8371 bytes)
    1: The Datsun 1200 has a [[wikipedia:Unibody|unibody]] design made out of high-strength steel. It does...
  7. Trim (9361 bytes)
    206: * Nissan Unibody All Steel Construction
  8. Battery Relocation (3891 bytes)
    28: ...tained. Run a 12-gauge wire from POS cable to the unibody (see [[Wiring]]).
  9. Bluebird (7816 bytes)
    68: 410 - The first unibody Datsun. Previous series used body-on-frame constr...
  10. 320 (12289 bytes)
    162: ...ll-frame chassis. So, the N(L)320 is not a {{wiki|unibody}} like the [[B120|B120 Datsun 1200 Pickup]].
  11. Monroney Sticker (2761 bytes)
    72: Nissan {{wiki|Unibody}} All Steel Construction
  12. Fairlady (6321 bytes)
    26: ...dsters and featured advanced technology including unibody chassis and Independent Rear Suspension. For 1970...
  13. Every Day in the Week (16574 bytes)
    49: ...nt disc brakes, road-hugging suspension and rigid unibody construction combine to create a potent safety pa...
    65: ...r an optional automatic with three speeds. Welded unibody construction is light, rigid, quiet. Space-maker
    83: ...Sedans include the functional good looks of rigid unibody construction. A highly efficient overhead cam eng...
    103: ...e open utility, center-enter convenience. Stylish unibody construction combines lightness with passenger pr...
  14. Sunny Truck Competitors (4216 bytes)
    1: ...yata Publica. Only the Sunny and the Publica were unibody vehicles.
  15. 4-door sedan (914 bytes)
    7: ...0 miles per gallon! Reclining front bucket seats, unibody construction — all the 1200 Series basics f...
  16. 410 (4549 bytes)
    3: Datsun 410 — The first unibody Datsun (previous series used body-on-frame constr...
  17. A Gallery of Datsun Originals (1842 bytes)
    34: ...0 miles per gallon! Reclining front bucket seats, unibody construction — all the 1200 Series basics f...
  18. They're really something (9029 bytes)
    75: '''Body and Interior''' All steel unibody construction. Tinted safety glass
    96: ...t of little extras — all wrapped in a steel unibody for solid protection.
  19. 1971 Sunny 1200 GX (3876 bytes)
    53: * unibody construction
  20. Economy is not our only mission (2790 bytes)
    16: ... stripes. All wrapped in an all-steel, all-welded unibody. It's Datsun, dedicated &mdash; <span style='font...
    31: ... stripes. All wrapped in an all-steel, all-welded unibody. It's Datsun, dedicated &mdash; <span style='font...
Search in namespaces :
List redirects   Search for
