Search results
For query "Vent"
There is no page titled ":Vent". You can create this page.
For more information about searching Datsun 1200 Club, see Searching Datsun 1200 Club.
Showing below up to 20 results starting with #1.
View (previous 20) (next 20) (20 | 50 | 100 | 250 | 500).
No page title matches
Page text matches
  1. Emission Controls (28459 bytes)
    130: '''Positive Crankcase Ventilation (PCV)''' was the very first of the emissio...
    136: ... the original 1200 gas cap, which has no pressure vent (only an air inlet (vacuum relief) valve, which i...
    158: ...m advance when the throttle is closed, thereby preventing emissions spike. After 1-2 seconds the vacuum ...
    180: ...retarded" spark timing reduces performance, to prevent cold-engine driving problems this system is bypas...
    185: ...e Throttle Opener mounted on the carburetor to prevent the throttle from closing completely while the ca...
  2. Weber 32/36 Carburetor (22613 bytes)
    1: ...a:Carburetor|carburetor]]. It runs on the smaller venturi for better economy and throttle response until...
    42: Venturis: different sizes
    75: They are available in different {{wiki|venturi}} sizes:
    76: * 235 CFM: 23/27 - 23mm primary venturi (1979-82 Fords)
    77: * 270 CFM: 26/27 - 26mm primary venturi
  3. Cowl Top Grille (5339 bytes)
    1: ...just below the windshield. Their purpose is to prevent debris from entering the air intakes for the pass...
    11: ...oupe "scoop" vents are different to the STD metal vent covers -- they are flat, not raised 5mm like the ...
    149: Tops removed and vents blocked
  4. Fuel Injection (19606 bytes)
    4: Because Injection does not require a restricting venturi like a carburetor, the performance can be bett...
    69: ...ting venturi (though some factory EFI still use a venturi)
    75: With injection, a venturi is not needed. The venturi in a carb is a restriction that somewhat limit...
    364: Fuel tanks from EFI cars are baffled to prevent pickup starvation on curves. Older cars don't hav...
    366: ...used as a return line, but then you would need to vent the tank somehow. Some guys empty the tank, and w...
  5. A12T Carburetor Part Numbers (1677 bytes)
    30: = Vent Hose System =
    35: 19 16955-H5701 TUBE-inner vent
    36: 20 16955-H5700 TUBE-inner vent (180l)
    37: 21 14913-A5500 TUBE-inner vent (150l)
    39: 22 14912-A5502 TUBE-inner vent (255l)
  6. PB210 (12135 bytes)
    42: * unique C pillar vent on Coupe
  7. SR engine swap (17113 bytes)
    102: * rocker cover vent straight-back
    106: * rocker cover vent on back sides
    139: ... 9812- ラィーノ back+side vents
  8. Fume Control (11421 bytes)
    3: = Fuel Tank Venting =
    4: ...tank. The tanks does not vent, except through the vent line.
    6: ...p is to prevent any siphoning effect. Later 1200s vented all the way to the engine compartment (EVAPO mo...
    8: ...e is blocked. Normal breathing occurs through the vent line.
    10: ...evised (suction relief) [[Fuel Cap]] (neither are vented types)
  9. Glass (11593 bytes)
    3: = Ventilation =
    4: ...Manual|07|07|opening of the windows: door window, ventilator glass, and Quarter Window}}
    17: ...ecause it is hinged and opens, it supplies strong ventilation to the car in motion. These were very comm...
    20: * 80244-H1001 GLASS-door ventilator (R.H.) 2 std
    21: * 80244-H1101 GLASS-door ventilator (R.H.) 2 DX, 2 GL [tinted]
  10. South Africa 1400 Brochure (12141 bytes)
    139: Door vent windows / Deursyvenstertjies • •
  11. Hitachi Twin Carb (12238 bytes)
    1: ...i|Hitachi]] [[wikipedia:Variable venturi|variable venturi]] carburetors which are very similar to S.U. {...
    197: ... Competition ([[Nissan Competition]]) sold a open-vented, non-IMS, system. From the 1984 [[Nissan Compet...
    221: Supplied with simple vent tubes (production A12T vents the carburetors to the air cleaner)
  12. EGI (26751 bytes)
    268: = Block Ventilation (PCV) =
    269: ...ottle body. The bottom of the block is positively vented as usual by the [[PCV]] valve.
    284: Early EGI engines - rocker cover with rear vent (early A14E)
    287: Late EGI engines - rocker cover with front vent (from October 1979, A14E & A15E)
  13. Air conditioning (15044 bytes)
    23: ... the parts from a B210 or B310. Only the interior vent setup is needed specific to the 1200.
    86: PB110 with triple-vent unit (knobs below vents)
    331: [[Category:Heating And Ventilation Systems]]{{End}}
  14. Rear Disc Brakes (7561 bytes)
    72: * Vent Solid
  15. Fuel tank (8026 bytes)
    36: For preventing abnormal fuel temperature rise, the fuel retur...
    38: ... suit different engine operating requirements, preventing the possibility of fuel heated flowing through...
    40: Thus the return line prevents {{wiki|vapor lock}} (engine stalling and engine ...
    42: = Venting =
    43: ...d back down towards the ground. The loop is to prevent a siphoning effect.
  16. Ventilation (4511 bytes)
    1: The fresh-air ventilation system of Datsun 1200 allows for fresh air...
    11: Ventilation for models originally equipped with No Hea...
    14: = Ventilation Flow =
    21: Inlet: In the Datsun 1200 passenger compartment ventilation system, air is drawn from:
    23: # ventilator (quarter window) on the front door.
  17. Rocker cover (9297 bytes)
    12: * Do not use sealer. Clean & flat will prevent leaks.
    46: H84 A14T Nissan right-angle vent
    70: Nissan cover, front vent
    76: * rear vent (early A14E)
    77: * front vent (late A14E + A15E)
  18. Fuel Cap (6727 bytes)
    1: ... no fumes out. This fuel tank cap is not pressure vented.
    4: ...elief. Pressure from the tank is relieved via the vent line.
    10: ...d to vent to the atmosphere, but only through the vent system. Australia utes from the 1980s are EVAPO, ...
    16: ... atmosphere. See [[Fuel Tank]] for details on the venting.
    48: Venting takes place with a vent line from the tank to the engine compartment, whe...
  19. Vacuum Hose Routing (7108 bytes)
    31: ...t. Since these fuel tanks are sealed, it needs to vent somewhere.
    36: 1. Fuel tank vent line (connection by itself)
  20. Carbon Canister (6509 bytes)
    5: ...nt hose. In the case of EVAPO models, the tank is vented in the engine compartment through a steel '''Ev...
    7: ... valve is used (located near the fuel tank) to prevent backflow into the fuel tank.
    28: ...anister, via the Evaporative Fuel Line (fuel tank vent line), as seen in this diagram:
    37: # Vent line, to the fuel tank, which also includes the '...
    43: ...gh the cap), so vapor will exit via the fuel tank vent line.
Search in namespaces :
List redirects   Search for
