Search results
For query "Ventilator"
There is no page titled ":Ventilator". You can create this page.
For more information about searching Datsun 1200 Club, see Searching Datsun 1200 Club.
Showing below 18 results starting with #1.
View (previous 20) (next 20) (20 | 50 | 100 | 250 | 500).
No page title matches
Page text matches
  1. Part Numbers Index (8259 bytes)
    94: [[Heater Part Numbers|Room Heater & Ventilator]]
    130: ...oor Part Numbers|Front Door]] PANEL, GLASS & DOOR VENTILATOR
  2. Glass (10394 bytes)
    4: ...Manual|07|07|opening of the windows: door window, ventilator glass, and Quarter Window}}
    17: The wing window is officially named the '''Door Ventilator'''. It is often called the '''{{wiki|quarter glas...
    20: * 80244-H1001 GLASS-door ventilator (R.H.) 2 std
    21: * 80244-H1101 GLASS-door ventilator (R.H.) 2 DX, 2 GL [tinted]
    22: * 80244-H8000 GLASS-door ventilator (R.H.) Coupe
  3. Rubber parts (4400 bytes)
    67: [[Glass#Rubber_Seals|Door Ventilator]] (quarter glass)
  4. Ventilation (4446 bytes)
    23: # ventilator (quarter window) on the front door.
  5. Driving Safety and Comfort (1151 bytes)
    35: = Windows, Ventilator =
    37: * [[Ventilation|Ventilator]]
  6. Raw List 2 (24619 bytes)
    746: 66502-H1000 ASSY-PLATE, AIR VENTILATOR
    747: 66511-H1000 ASSY-LID, AIR VENTILATOR
    748: 66504-18001 SPRING-AIR VENTILATOR R.H.
    749: 66505-18001 SPRING-AIR VENTILATOR L.H.
    750: 66507-18000 PIN-AIR VENTILATOR
  7. Raw List 5 (36106 bytes)
    263: 80270-H1001 ASSY-FRAME DOOR VENTILATOR RH
    264: 80271-H1001 ASSY-FRAME DOOR VENTILATOR LH
    265: 80244-H1001 GLASS-DOOR VENTILATOR RH TEMR T=4.0MM
    266: 80244-H1101 GLASS-DOOR VENTILATOR RH TINTED & TEM
    267: 80245-H1101 GLASS-DOOR VENTILATOR LH TINTED & TEM
  8. Raw List 6 (32661 bytes)
    349: 80270-H1800 ASSY-FRAME DOOR VENTILATOR RH
    350: 80271-H1800 ASSY-FRAME DOOR VENTILATOR LH
    351: 80244-H1800 GLASS-DOOR VENTILATOR RH (ANTI-SUN T=
    352: 80245-H1800 GLASS-DOOR VENTILATOR LH (ANTI-SUN T=
    353: 80250-H1800 ASSY-CHANNEL VENTILATOR GLASS RH
  9. Ash Tray (3373 bytes)
    1: ...tray in the center of the [[dashboard]] below the ventilator controls. Rear passenger ash trays were an [[Opti...
  10. Heater Part Numbers (4063 bytes)
    99: == Air Ventilator ==
    101: 1 66502-H1000 ASSY-PLATE, AIR VENTILATOR
    102: 2 66511-H1000 ASSY-LID, AIR VENTILATOR
    103: 3 66504-18001 SPRING-AIR VENTILATOR R.H.
    104: 4 66505-18001 SPRING-AIR VENTILATOR L.H.
  11. Cowl (3631 bytes)
    31: ...rge oval hole in the center is for the heater (or ventilator). The cowl vents are located at the base of the w...
  12. Front Door Part Numbers (9892 bytes)
    15: 80270-H1001 ASS'Y-FRAME, door ventilator (R.H.)
    16: 80271-H1001 ASS'Y-FRAME, door ventilator (L.H.)
    17: 4 80244-H1001 GLASS-door ventilator (R.H.) 4S, 4ST
    18: 80244-H1101 GLASS-door ventilator (R.H.) 4D,4DT,4GT,4DA,4GA,4GX
    19: 80245-H1001 GLASS-door ventilator (L.H.) 4S, 4ST
  13. Instruction Manual (12428 bytes)
    242: Door ventilator Open, Close
    243: page 27 Ventilator
  14. Gold Coupe (4259 bytes)
    92: * auto ventilator
  15. Brown PB210 (4095 bytes)
    345: side ventilator
  16. B210 Part Numbers Index (13311 bytes)
    305: Ventilator
  17. The car next to me looks small (3951 bytes)
    24: ...econd to none. Everything is doubled|★ Auto ventilator allows free ventilation even when stopped}}
  18. Yes Sunny Shizuoka (2061 bytes)
    31: <br>&#9679;Innovative forced ventilator
Search in namespaces :
List redirects   Search for
