Main : Members : 1200rallycar a15ett latest mods
[<   Previous  10  11  12  13  14  15  16  Next   >]
a15ett latest mods
a15ett latest modsPopular
Submitter1200rallycarMore Photos from 1200rallycar   Last Update2005/11/11 8:30    Tell a friendTell a friend
Hits2841  Comments6    0.00 (0 votes)0.00 (0 votes)
hey fellas, just done a few things, have a look
-new BOV, much louder high pitched noise
-new alloy radiator with room for two thermos, just squeezes in for both height and width
- new air filter with a bit of a heat shield from turbo outlet pipes which may later become a cold air box
1200rallycar
Posted: 2005/11/11 8:32  Updated: 2005/11/11 8:32
 Re: a15ett latest mods
not sure what the radiator is actually, was given it
just started my career as i scored myself an engineering job..... which means lots of cash coming my way to do the exhaust and injectors soon!!!!
blofly
Posted: 2005/11/11 9:00  Updated: 2005/11/11 9:00
the whole engine bay looks like a whole lot of fun, what brake booster are you using and how did you go about the existing brake lines? did you bend them a bit or just make new ones?
1200rallycar
Posted: 2005/11/11 9:10  Updated: 2005/11/11 9:10
used a sunny booster, just bending the lines a bit, i dont think you need a booster until you go to 4 wheel discs personally (i have 4 spot front calipers on vented discs and bluebird discs on rear)
1200rallycar
Posted: 2005/11/11 9:14  Updated: 2005/11/11 9:14
something for those planning a turbo setup...
as my intercooler to inlet manifold pipe runs behind the radiator it heats up somewhat (can feel it's cool at the intercooler exit but hot to the touch up closer to radiator) after going for a drive
i'm thinking of using a heat wrap over it to hold heat out... but in hindsight if i could have run it somewhere else i would have
same with the air filter... it is too close to the turbo outlet pipes which get very hot (hence heat shield, but even the shield gets very hot still and so does the filter itself)
hotrod88
Posted: 2005/11/11 13:12  Updated: 2005/11/11 13:12
Did you have to cut the hole out bigger in the core support to allow more air flow to the bigger radiator?
1200rallycar
Posted: 2005/11/12 4:00  Updated: 2005/11/12 4:00
well... i'd already cut some metal out for the intercooler, so yeah i have done, i could cut some more (not much really) for a bit more airflow, but that would be last resort, i just placed the thermo fans so they would pull as much free air as possible
