Fuel Starvation
From Melbourne, Aus
I have put an L18 in a 1200 coupe running Jag SU's.
Took it out to calder park yesterday for its first run.
It was suffering from fuel starvation.
When you held the revs above 5K you could see the fuel in the filter slowly dropping until there wasn't any left.
I changed the filter but this did not help.
Has anybody experienced this problem and if so, do they know of any remedy?
Posted on: 2003/2/6 10:50
Re: Fuel Starvation
From sydney australia
what size fuel line are you using,maybe you need to go up a size,not to forget the outlet at the tank,it's tiny as well.or maybe the filter is collapsing internally.
Posted on: 2003/2/6 10:57
Re: Fuel Starvation
From Sydney, Australia
In the "old days", my brothers L20B (2.4) had twin 48DCOE webers. And he had to run a High Volume Low Pressure Aftermarket fuel pump (less than 10PSI) and a low pressure fuel pressure regulator set to about 5PSI.
Chris
Posted on: 2003/2/6 11:04
Re: Fuel Starvation
From Melbourne, Australia
to need 5psi (without turb) is pretty high but i though mechanical fuel pumps could make that
Posted on: 2003/2/7 8:21
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: Fuel Starvation
1200rallycar that is true they can make that much! but you missed the one key factor in dattodudes writing. " High Volume"
Posted on: 2003/2/7 12:46
Re: Fuel Starvation
From canberra australia
can have 100,00000 psi but with out volume what u gunna do with it? anyways i recon try a electrick pump from a wreckers or somethin and see if that fixes it.. but maybe your mechanical pump is just plain ####ed.. thay normaly put out lots of volume and should keep up
Posted on: 2003/2/7 14:37
i dont drink beer i drink BEERS
Re: Fuel Starvation
some model bluebirds came with an electric fuel pump,(a facet one i think),give that a try.should be the right volume & psi for webers.
Posted on: 2003/2/8 22:38
