ca18det dropping resistor.
hey,
another one ya's.
is there a direct replacement for the dropping resistor from nissan or is there another different one i can wire in???
cheers
Posted on: 2009/12/21 10:05
Re: ca18det dropping resistor.
From Sydney, Australia
Pretty much there are only two impedence values of injectors. One uses a dropping resistor, and the other doesn't. You could look at any other car engine bay (at the wrecking yard) and trace the injector loom to see if it has a dropping resistor similar looking to the Nissan one. You will see the CA18det one has 4 resistors.
You could pull it apart and get replacements from an electrical supplier.
Posted on: 2009/12/21 11:58
I could pull it apart if I had one :) I need one. Anyone know a part number replacent?
Posted on: 2009/12/21 12:02
They are a JECs part with a Nissan connector.
The term "Dropping Resistor" is the term of interest.
See: http://zilvia.net/f/archive-faqs/1330 ... e-injectors-approved.html
I have one at my parents, but I wouldn't be able to put it in the post until after XMAS.
Cheers.
Posted on: 2009/12/21 12:13
so correct me if i am wrong, cause the ca uses 370cc injectors which are low impedance, i have to wire in 4, apprx 6-7ohm resistors in series parallel with the injectors??
i think i know what i am talkin about lol..
anyone done the conversion?
Posted on: 2009/12/22 4:00
From Mandurah, Western Australia
Have you got thi spage in the manual showing how it wired?
jpg  caresistor.JPG (30.10 KB)
2484_4b3049ffdd5bb.jpg 508X433 px
Posted on: 2009/12/22 4:25
yep, all wired up now. you just suplly 12v to one side of all resistors and all outputs on the other to the injectors :)
Posted on: 2009/12/22 5:47
From Christchurch NZ
Hmmmm.
I had always been led to beleive that the CA18De's used a resistor, and the DET's did not. This was told to me by a mate who has done lots of CA18det wiring loom conversions/ECU remapping.
Posted on: 2009/12/26 19:32
Forced Induction!
Your mate must have been drunk. All wiring diags clearly show the dropping resistors are a det only part. Plus I've personally done a DE to DET upgrade back when I turned 25... 12 years ago
Posted on: 2009/12/26 23:26
From hastings,vic
de no resistors, det with resistors
Posted on: 2009/12/27 0:49
taking up room at home
hzj75 cruzer tray(for sale)
and allways changing
