thoughts on oils
From Gold Coast
hi everyone , what engine oil do you use or find is the best.
Posted on: 2007/9/13 13:56
z18-microtech-frontmount-t3/t4
-external gate-screamer pipe-
Re: thoughts on oils
From Albuquerque NM, USA
I have always used Castrol. Seems to work well with Datsuns. I even think it is the recommended oil (at least in Chilton manual).
btw the weight I use is 20w50. There is my 2 cents worth.
Kelmo
Posted on: 2007/9/13 14:06
From South Africa, Bloemfontein
I agree. Nothing wrong with Castrol.
What I normally look for is if the oil is turbo approved. If it is, then it is more than good enough for all my NA cars that I have.
Turbos put alot of stress on oil.
I use Engen 15W 40. It is a mineral oil that we get here in South Africa and apparently the licencing is as follows:
Engen is owned by Mobil and Mobil is owned by Pertronas.
Engen is turbo approved and also suited for multivalve engines.
Posted on: 2007/9/13 14:38
1977 Datsun 1200GX
From Gold Coast
yeh ,im using penrite hpr30 which is 20w-60
Posted on: 2007/9/13 14:45
From Flinders View, QLD
This may sound cheap but I just throw in what ever is on special at the time in 20w50 weight. 90% of the time its castrol any way.
My engine has evolved into a SELF SERVICING unit buy adjusting its own clearances in the rear main seal and dumping the excess oil onto my garage floor. So it gets topped up with fresh oil regually. I would fix the problem but thats evolution for ya
Posted on: 2007/9/13 23:15
Just trying to put the bloody puzzel back together
From Adelaide. SA
I always use castrol in my CA but RPM performance centre just did a test on some NULON friction modified products on a chassis dyno, same day, same car, same ramp speed etc and it actually made more power! It is a little more expensive but it does seem to do the trick.
Cheers. Adam.
Posted on: 2007/9/14 1:08
It's not for the money and its not for the applause!
"Live life, follow your dreams",
Peter Brock
From Canberra
penrite sin15 in the gze
Posted on: 2007/9/14 1:33
From Coondle, WA Australia
When I had the old tired A10 in daisy, i used a shell oil, called 'older engine' engine oil. Its comes in a red bottle. Its supposed to have addivitves to help tired engines last that bit longer. It wasnt any more expensive than standard stuff.
Otherwise, i have always been a penrite fan, jst cause I suppose.
Posted on: 2007/9/14 6:47
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
From Newscastle, Australia
just use any new oil for a stock A series whatever is cheapest. the key is frequesnt changes.
In the race car I use the cheapest fully synthetic brand.
Posted on: 2007/9/14 7:08
Dont die wondering.....
From Bris Ozzztraileeaarr
10w30 oil they r lite an rev fast u don,t want a heavy oil oil like 20w-50 unless itr,s a bit flogged out!! then go the the thicker oil. I find the lighter oil oil fine an it helps MPG!! Read cheaper 2 run!! but everybody has there fave!! In my 350 HQ I ran pennzoil streetmachine oil @ 20-50 it loved it, big heavy always overreved no stress showed on the bearings ever!! so try a few an make yr own choice!! enjoy!!
Posted on: 2007/9/14 14:00
