A15 or CA18det
Quite a regular
From Sydney
Cant decide wether to rebuild my A15 and work it or just put in a ca18det. Need help guys and gals?
Whats the max kw i can get out of my a15 and is it worth it? Reliable? Cheaper to just get a ca18det?
any helps appreciated, cheers.
Posted on: 2008/11/13 1:55
Re: A15 or CA18det
From sydney
You wont get much change from 10 grand by the time you finish the CA conversion.
Posted on: 2008/11/13 2:10
Re: A15 or CA18det
From Geelong, Vic
the most power you can get out of an a15...that will costs lots and lots of money and you will be able to build a decent CA and get it in the car for that kinda money
better question might be whats the typical power you get from an A15 without going too overboard
andy, im expecting change from $1000 to finish the CA18de+t ....but thats starting with an L series in there already
Posted on: 2008/11/13 2:16
Re: A15 or CA18det
From Nyngan, nsw Australia
i second that!!!
Posted on: 2008/11/13 2:19
living is good,.....
Re: A15 or CA18det
From perth airport
a fully worked a15 isnt gonna be quicker than a STOCK ca18det
but i hate ca18's so i would say sr20det
Posted on: 2008/11/13 3:33
perth airport parking
Datsun 1200 ute A14
Re: A15 or CA18det
From Sydney, Australia
Yes.
A15 pros :
- no fabrication
- you can use club registration if it's only used for club activity. Saving ~$1000/yr
- no wiring
- no cooling
- no big brakes
CA18det pros:
- smoother to drive
- more torque
- better fuel in city economy
- less maintenance
- you get a 5 speed
- big learning experience.
Basically a CA18 is a learning experience. An a15 is a quick fix that allows you to stay on the road with a 1 day install.
I learned a lot about engines, welding, cooling, suspension, wiring etc etc in my CA18 install. I've also taught a lot of other people as a result of the hard/stressful days of learning things the hard way.
Posted on: 2008/11/13 3:55
Re: A15 or CA18det
From Geelong, Vic
with a decent a15 your probably going to have to do some kinda brake upgrade and will probably want to upgrade the cooling system aswell
but totally agree with the CA being a learning experience, after you do it you actually know how stuff works....which is quite handy if your modding cars
Posted on: 2008/11/13 4:39
Re: A15 or CA18det
From Melbourne Vic
CA... there is nothing like having the performance of expensive sports cars in the shell of a datsun and you'll learn lots. i know thats a simple answer but you asked a simple question
Posted on: 2008/11/13 4:50
CA18DET 1200 lagwagon retired
LAG510 - SR20DET 1600 sedan
1000 wagon daily - A series magic
Re: A15 or CA18det
From Melbourne, Australia
you want learning experience?.... turbo the a15
Posted on: 2008/11/13 6:24
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: A15 or CA18det
From Geelong, Vic
even more learning experience?.....turbo and efi the a15
Posted on: 2008/11/13 11:44
