CA18 Auto wiring integration ... anyone?
From MOOROODUC. Victoria
Ever thought that you would take the easy way but it ended up the hard way?
Ever thought that you could do something easily but the more you did the more things that had to be done? (knock-on effect)
let me say at the outset that I am gonna finish this as an auto CA18 conversion
BUT..... I have been studying the S13 workshop manual for the electrical hookup of the auto box and it is leading me down a path that may not be well trodden.
1. Has Anyone done this before - CA18 + Auto from Silvia into 1200 Ute?
2. Do I need to use the Silvia ELECTRIC speedo and tacho and warning lights?
3. All these sensors! - fluid temp sensor, revolution sensor, speed sensor, kickdown switch, Soliniods for the shifter selector
Ok I need some plugs that fit the plugs on the auto and shifter, maybe a speedo, (how far do i go?) if no-one has them i will go try the wreckers.
Any experience on this would be appreciated. if not i will document my journey in my build thread
Posted on: 2011/3/30 4:38
Re: CA18 Auto wiring integration ... anyone?
From Melbourne, Australia
Was your donk already mated to the auto when you got it or have you got your CA and then sourced the auto separately?
If they came together it should be pretty straight forward. All the sensors you mention are all very important. Especially coolant temp, cam, speed sensor etc as they all control the fuel delivery and spark timing.
You can use either the dash out of the Silvia or you can get electrical replacement gauges (Autometer, etc). With a coupe dash (3 round dials) you can pretty much just plonk a 3 3/8" gauge straight in the hole. Some people like to mount them from behind for a more factory look.
If it all gets too hard there are a few places around that will do a full wiring loom for you to match the recipient vehicle.
Good luck!
Posted on: 2011/3/30 5:54
Current Fleet-
1996 R33 GT-R Skyline
1996 Falcon XH XR6 Ute
1977 Datsun 1200 Ute A14 (Fergus)
2012 VW Passat TDI Wagon
From penrith,sydney,aus
pretty sure the only wiring you need for the auto is the wiring that tells the ecu if
its in park or reverse so it will start
and in reverse so the reversing lights come on
my ca18det auto 1200 sedan only had this and its all it needed
as for sensors you need the main ones but no sensors for the auto box
you definetly dont need the silvia dash
Posted on: 2011/3/30 6:50
2 door 1200 sedan project l20b stroker
Thanks for that Shaun however,
How do you get your speedo working if not using the Silvia speedo ? and I agree I don't need the whole silvia dash but maybe as Shoota suggested the gauges into my existing '81 round dash setup might work.
Shoota, I got them separately so I don't have the loom in the middle
From what I can research I have the 'Auto Harness' the 'E.F.I. Harness' and the 'Engine Room harness No.2' as well as the shifter with its plugs.
It looks like I need at least some of the number 1 'Engine Room Harness' and some of the 'Main Harness' (at least the plugs for the AT computer and maybe the combination gauges).
I DO have all the Looms from an EXA - that will be my next avenue - chop chop
Posted on: 2011/3/31 1:33
as for the speedo i had the standard 1200 speedo cable in mine, mine was a bluebird auto, but even now i run the standard cable behind my ca manual box in my wagon
Posted on: 2011/3/31 6:51
From Geelong, Vic
you really shouldnt have got an S13 auto, as they are fully electronic. you should have, and probably should still go with a bluebird auto like shaun has.
as they are fully hydraulic and they need no wiring to go to them for the engine to run properly or the auto to shift properly. and then you just run a manual CA ecu
you might be able to get an older style speedo sender and put it in where the electronic sender is, then just use your standard speedo cable or a slighty longer one, 120y, 200b etc
but then you might need the speed sensor for it to shift properly
all of the inputs and outputs from the auto to its control unit should be kept, any that dont go to the auto computer or the ecu you probably wont need
Posted on: 2011/3/31 11:51
Ah, the joy of 20/20 hindsight ....
It's no time to back out now, into the valley of frustration I go
Posted on: 2011/4/1 22:17
Not too shy to talk
From Rockhampton Qld
Doing the same thing, have doctored wiring diagram if it's any help.
Posted on: 2011/4/4 12:32
From Geelong, Vic
what do you mean no time to go back now...sell your auto and get a bluebird one, not really that hard to do. easier than trying to find all the rest of the stuff that you need to run the s13 auto
Posted on: 2011/4/4 12:50
From hastings,vic
sould be easy
if u can read a wiring diagram
will have a look tomorrow
Posted on: 2011/4/4 15:25
taking up room at home
hzj75 cruzer tray(for sale)
and allways changing
