what power have people got with A14's and A15's
From Adelaide, Australia
im having problems deciding what i wanna do with my datto1000 ute. i will NOT be putting anything else in it but an A14 because thats all im allowed. What sort of HP have people been getting with A14's/A15's? What have u done to achieve this? what parts can i use where and from what? i have a budget of $2500-$3000, i can build this engine myself but please someone tell me what i can do please. the car will not be tubbed out so there is such a thing as too much HP.
can people not tell me to stick in an SR or CA ect.. cause anyone can get good hp from them
Posted on: 2005/6/27 11:13
Re: what power have people got with A14's and A15's
Is there any reason that you will not consider a 1200 engine? [they fit the 1000 engine mounts, A14's don't] Why are you allowed nothing larger than an A14?
With the light rear of a 1000 ute, & 195 tyres [thats about the practical limit] you will be able to scare yourself quite sh1*less with a 'built' 1200 or A14 engine anyway. Something like about 80hp at the rear wheels will be achieveable at a quite reasonable cost.
With that, it will run quite nicely. I'm sure thats about what i will be geting from the 1200 engine in my 1000.
Posted on: 2005/6/27 11:21
Love your Datsun.
Treat it well.
years ago had an A14 in a 1000 2door. had around 85-90hp at the wheels. this was with big cam, double valve springs, 1600/510 recut exhaust valves, ported polished A12gx head, flat top pistons gx cast exhaust manifold 2.25" free flowing exhaust. this was all fed by twin su's, which were eventually swapped for a pair of 40mm dellorto carbs. went harder and smoother with the dellortos but never got it onto a dyno.
and i can back up what dodgeman said ..... plenty of times i nearly had to rush home for a change of undies was a great power to weight and with a decent set of brakes to stop it, it was definitely one of the most fun cars i've owned
Posted on: 2005/6/27 11:44
From Perth
Not as much as we wanted but we haven't tuned it yet and dropped down to 10:1 comp due to fuel availability
Posted on: 2005/6/27 12:30
From Central Vic
A15 crank tough righted with 7/16unf caps srew flywheel bolts
A15 rods linished and shoot penned
Cosworth blanks machineded for 88m bore 12.5:1 comp
slightly more oil preshure
Alloy fount pull under driven
alloy flywheel
datrally head max size valves stainlees comp style
alloy spacers between rockers to stop them walking of the valves spacers under posts for rub angle
mild race style cam profile
45mm twin webers dat rally manifold
stepped 4-1 headers
2 1/4 exhaust
160hp at flywheel aprox 7500
130ftlbs
Posted on: 2005/6/28 0:56
From Perth Austarlia
dattoman, if you reckon your webpage is slow loading...get a new internet provider..I hope you have yet to get broadband...Using broadband it seems to load fine..
and its not that crap.
Posted on: 2005/6/29 12:52
Im running a fully built A14, flat top pistons 10.2:1,highly modified head and inlet manifold. Im using a single webber from a 2lt escort, extractors and 2.5" high flow exhaust. Although not yet dyno'd, my 1200 ute with locked diff can match my mates 13b j port rx4! The A14 is also running 80hp nitrous oxcide, but havent yet had a race.
Posted on: 2005/6/29 13:17
From Millgrove Vic OZ
Neil,
So whats wrong with 73 Kw's at the treads?
Posted on: 2005/6/29 15:09
Cheers Feral
From Perth
Its OK Errol...... I just wanted 100hp......wahhhahhaa
Still got to do some tuning as you can see by the AFR.
Basically I just want to get into the car and have some fun driving it.
Big cars tend to hunt me down on the straights though.... more HP is always nice for then.
Oh and I am on broadband... and probably need to change my sig
Neil
Posted on: 2005/6/29 15:52
From Adelaide, South Australia
Hey Tuff1200 with all the mods on your engine why do you still use a 32/36 weber ?
Posted on: 2005/6/29 16:08
"Anyone who has never made a mistake has never tried anything new"
Albert Einstein
Put stupid oversized photo here>>
