how to combat axel trample
From sutho shire, NSW, AUS
Any ideas about how to get around this foe without going down the tramp-rod route.
thanks
Elliott
Posted on: 2005/6/30 5:52
Re: how to combat axel trample
From penrith,sydney,aus
apparently the bloke who owns pedders in penrith and his brother have made and sell a set of leaf springs that are 2 inches lower than standard and they also stop axles tramp
he sells them at pedders for around 350 a set i think
go talk to him great bloke cant stop him talking after you tell him you own a 1200
Posted on: 2005/6/30 6:08
Put the A10 back in? Sorry I just couldn't resist.
Posted on: 2005/6/30 6:22
From Brisbane, Australia
first of all, check the condition of your shocks...
then take out your lowering blocks :P
otherwise fit a reversed half leaf on top of the front half of the spring pack. I used a cut off 120Y main leaf.
Posted on: 2005/6/30 6:52
From sutho shire
um only thing that will fix axel tramp properly is a set of CAL TRACS
Posted on: 2005/6/30 10:08
*1200 ute ca18det (CYA-18T)
256 rwhp at 14psi wanting more power
Team New skool
From Newscastle, Australia
Nope the springs I got from John Taylor were perfect for solving axle tramp..well worth the money spent. Dont even need to consider tramp rods.
CA18DET_MAN would also attest to that these springs working well with 206rwkw and no tramp...
Posted on: 2005/6/30 11:53
Dont die wondering.....
From Mudgee NSW Australia
No tramp for me with JT rear springs 5000rpm 20psi 2nd gear launches but wheelspin still a bit of a problem migth have to run some more boost
Posted on: 2005/6/30 12:05
If In doubt run more BOOST
From penrith
im gettin tramp bad the other day the wheels came off the ground got a hell of a jolt! my left shock ir rooted tho. more info on these leafs?
Posted on: 2005/6/30 14:47
From sydney
Ring Pedders at Penrith thats were they sell them.
Posted on: 2005/6/30 22:14
yep 47312444 there are 30 years of development in these things
Posted on: 2005/7/1 2:42
(1) 2 3 »
