1200 Engine...Some cheap & effective mods..?
From Lismore, NSW
Hey guys i am after some engine mods to do to my datsun 1200, anything just so it goes a lil harder and doesnt cost #### loads..Thanx
Any recommendations?
Posted on: 2006/3/2 23:53
Re: 1200 Engine...Some cheap & effective mods..?
From Newscastle, Australia
yep just stick NOS on it
if you blow it up then just get another one for $20...
Posted on: 2006/3/2 23:54
Dont die wondering.....
From Adelaide, Australia
yes. seriously throw out the A12 and buy a A14 or A15. the money spent getting the 1200cc mtr to get the same power as a 1400 will cost u more than buying a A14 or A15mtr. then maybe just extractors and carby and manifold replacment such as a webber or small holley.
Posted on: 2006/3/3 0:09
From Tamworth, NSW
read the tech section an search first. It really depends how much power you want long term an how much money you want to spend long term.
Posted on: 2006/3/3 0:20
Not too shy to talk
From Guatemala, Central America.
Try Headers, or a better ignition. , you can find a lot of information at the tech section, you can also download the competition suspension manual and the Datsun competition parts manual, they can give you a lot of ideas to modify your 1200, good luck.
Posted on: 2006/3/3 2:46
From Alabama, U.S.A.
Really just depends on what you want your DATSUN to do.( more detail)
Posted on: 2006/3/3 3:33
From Lismore, NSW
I dont want to do an engine conversion as im still in year 11 dont have the income each week, i just want it to have a lil more grunt about it, anything to improve the power a lil better...
How much wld a full rebuild cost..? or is it not worth it..
Thinking just keep saving to i have heaps of money then do a ca18det or sumtin along those lines..??????????????????
Posted on: 2006/3/3 5:00
From sydney
Rig up your carby to make the secondary throat come on mechanically, so it cuts in earlier.
Get some extractors and a bigger exhaust.
Posted on: 2006/3/3 7:35
From WA
my 1200 sedan was a stock as a rock A12 and 4spd manual with TRX 15in rims, stanza brakes / girlock calipers up front and 240Z finned drums out back.
the only 2 mods i did was rig up the secondaries to pump with the primaries with a bit of coathanger wire and make a cold airfeed.
i used to pass modded excels coming into CAT corner at barbagallo and used to take corners valve bouncing in third.
you don't need to do much to an A series to get them to get up and boogie.
Posted on: 2006/3/3 8:26
From Launceston, Tasmania
Bolt on a weber 32/36 carby found off Escorts and 4cyl cortina's, a bigger exhaust system right through, including extractors and maybe some head work like a port'n'polish, shaved head and bigger valves.
Also improving your spark through your iginiton system is also a great way of gaining some more power.
Posted on: 2006/3/3 10:42
