« 1 (2) 3 4 »
Re: hayabusa engines...
From south australia
now they look like some serios fun.I think i might go build one. i have to spare vf750 motors lying around it just gave me an idea.It wont be quite as quick as these ones though
Posted on: 2006/3/30 11:15
From Newscastle, Australia
Yeah cool but i would want a Busa powered smart car on a race track, it would be uncontrollable around corners with the short wheelbase and the amount of power.
Posted on: 2006/3/30 11:17
Dont die wondering.....
but still woulnt it be fun
Posted on: 2006/3/30 11:27
From Sydney Australia
Yeah sorry about the 400kg thing, I got that off this site who owned a busa set up for the drags with a whole lota extra stuff on it that pumped out 500hp.
And if I were to do it the car would be about 600kg. (KB10)
From the research that I have done there are a few of ways of doing it.
1) You could put the engine in the back like the minis
2) You could use the inbuilt clutch and gearbox off the busa, mount it north/south and weld one side of a universal joint connecting to the drive shaft onto where the front sprocket usually is. The trouble with this is that you would have no reverse. The aussie racing cars have some kind of mechanism in the diff...
3) You could not use the gears and clutch off the busa engine, but instead mount the shaft straight into the normal car clutch/gearbox, giving you reverse.
Its probably crazy and will never happen, but it would be one sweet as car. I think I might stick to my a14
Posted on: 2006/3/30 13:13
From Melbourne Vic
ian, i reckon that is a wicked idea!
600kg kb10 minus cast iron block engine minus diff... not a whole lot of weight left.
definately mount it at the rear and run a chain and sprocket kind of setup to a new custom axle.
rediculously light, high revving and powerfull. in a kb10. now THATS different!
Posted on: 2006/3/31 0:41
CA18DET 1200 lagwagon retired
LAG510 - SR20DET 1600 sedan
1000 wagon daily - A series magic
From gold coast QLD australia
Hayabusa V8..327hp and i think it only weighs 95kg. now that would be great in a datto.only problem there about $10000 aech plus gear box.Open in new window
Posted on: 2006/3/31 3:12
GO RACING,GO HARD OR GO HOME!!
SLY OLD FOX..................
A better comparison of the size of the motor(95kg)Open in new window
Posted on: 2006/3/31 5:21
From Stray-ya
Vixen- have you got a link to that V8 page? I don't see how you could do it using the busa block & head. In that pic they are running one side backwards
..... ok, that could probably be engineered, but when you have offset the two blocks by half a cylinder to allow for the custom V8 crank, there wouldn't be any room left for main bearings
About 10 years ago there was a honda (?) shallow angle V4 that someone used 2 of end to end to get a 2L V8 but this one has got me stumped.
Posted on: 2006/3/31 6:52
Imagine if you turboed it! It would be one mean KB10 with one of those. I wonder how hard it would be to get rid of the busa gearbox and engine and just connect it straight to the datto 4spd. I think some research will need to be conducted.
Posted on: 2006/3/31 7:07
From sydney
I think its a custom casting.
http://thekneeslider.com/archives/2005/02/09/hayabusa-v8-engine/
Posted on: 2006/3/31 7:29
« 1 (2) 3 4 »
