French A series but takes 50psi
This is the renault 5 gt 1.4 litre pushrod engine which has a lesser head than the A series nissan with little valves and lil round ports non crossflow but capable of 430hp with 50psi!!!! As commonly tuned in England.
Can the A series benefit from such sleeves? or will it weaken it?
http://cgi.ebay.co.uk/Renault-5-GT-Turbo-engine-no-tappet-or-knocking-noise_W0QQitemZ4633030375QQcategoryZ10410QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
http://cgi.ebay.co.uk/Renault-5-GT-Turbo-Cylinder-Head_W0QQitemZ4631876547QQcategoryZ10410QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Posted on: 2006/4/20 3:17
Re: French A series but takes 50psi
Quite a regular
From Mira Loma Ca. USA
It would defintely weaken the block!
That I believe is refered to as a "wet" sleeve,
and the A-block was not designed to be sleeved like that. I had to sleeve a block once, but nothing as thick as those!! the coolant runs in those gaps, whereas the A-block has passages.
Posted on: 2006/4/20 4:48
1965 Datsun Fairlady 1500-A14 powered!
5 Speed All GX parts with twin Dellorto 40's
10:1 compression. 1976 B210 stock smogger with "dogleg" 5 speed and a ton of suspension work (coilovers, camber plates, etc. etc. etc.)
From sydney
As a matter of interest, what is the maximum amount of boost you could put through a purpose built A series, whilst still retaining some longevity?
Posted on: 2006/4/20 5:15
From Sydney, Australia
longevity is beheld in the angle of the right ankle.
Posted on: 2006/4/20 5:28
From Tamworth, NSW
I would be interested to know the ultimate psi of a built a12 also. here is a similar thread
Thread link
Posted on: 2006/4/20 8:31
Project coupe:
Just drive it
From Christchurch NZ
I believe it's more an issue of what is the maximum number of dollars that someone is prepared to spend on an Aseries.
With ALL the clever gear, I'd say 20+ psi.
Posted on: 2006/4/20 10:06
Forced Induction!
I think the A series could handle a wet sleeve conversion. The legendary Honda H22 is usually converted to a wet sleeve and its an alloy block which handles ridiculous boost. Once you have good seating on billet sleeves the head seals the lot specially with stronger head bolts (somewhere on this forum I saw someone using the stronger bolts). The problem is finding someone to do an accurate job of CNCing the block for the stronger sleeves.
Smaller 75mm bores will make 1431cc but will help with thicker billet sleeves which is necessary for 40-50psi.
Billet Stainless sleeves will cause problems to the rings but coating the rings will help with them disappearing.
One other thing is that the 82mm stroke is not an issue with revs. The H22 has a 90mm stroke and revs to 9k with boost and the F20/22 rev to 9k with 86mm stroke.
With boost 82mm should be fine on the A series for 7.5k easily
Posted on: 2006/4/20 12:49
Nissan sold dry sleeves for the 1200 ...
Posted on: 2006/4/21 17:39
bump
bringing this thread back up,
Would it be possible to get 80mm bore using offset wet sleeves?
Also a modded e16 crank (90mm stroke) for around 1800cc?
Where is Feral when we need him
Posted on: 2007/10/22 6:17
