Torque settings needed
Have an a15 out of a vanette in my sunny!
Dont have a manual to give me torque settings.
Need ACCURATE torque specs for;
HEAD BOLTS &
ROCKER ARM SHAFT BOLTS
Posted on: 2006/5/9 9:47
Re: Torque settings needed
From Sydney, Australia
A10 to A12 - Factory Manual
Head Bolts -> 32.5 - 36 or 39.8 ft-lb (higher rated torque was hand drawn into factory manual by Nissan Mechanic)
note: centre-distributor side head bolt is different to the others in A10/A12.
Rocker Arm Shaft Bolts -> 14.5 - 18.1 ft-lb
note: should be done outwardly, starting at the centre bracket.
Chris
Posted on: 2006/5/9 10:25
Are these torque settings the same for an A15 motor???
All head bolts on the A15 look the same! Can anyone confirm this?
Posted on: 2006/5/9 10:55
We know the oil galleries from the top of the head to sump is different between the A12 and A15. I can't remember the difference as I've never owned an A15, and never needed to do anything except do oil changes for the A14 engines that I've had..
VANETTE
Vanette C120 1983 Repair Manual
A12 & A15 petrol engines
Inc SM3EC120GO & SM5RC12SAO
SM3EC12OGO ........................... $99.00
Nomad/Vanette 1986 C22
Repair Manual - includes A15, Z20S &
Z24S petrol engines
(LD28 diesel requires the LD engine
supplement)
SM6EWC22GO........................... $99.00
Nomad C22 1987 Repair Manual
A15S, Z20S, Z24S & LD20 engines
(LD20 refer to SM4ELD20GO)
SM7EWC22GO......................... $275.00
Prices in Australian Dollars
http://www.bevenyoung.com.au/
You could always buy a handbook if you are so insistant on getting it 100% right.
Posted on: 2006/5/9 11:10
From Canberra
one of the head bolts should have a hole in it, or be thinner in the shaft, something like that, its one of the middle ones... sparkplug side? and goes into a oil gallery.
just something I noticed when finally putting the head back on my a14.
I was going to start a thread asking for valvetrain bolt torques... now I dont have to.
Posted on: 2006/5/9 11:42
Considering that the car will sold next week, I really do not want to spend extra money, hence trying to get some specs of this website. Buyer is getting the car at a good price meaning that Im loosing enough money!
In terms of one of the head bolts being different, I will analyse it tomorrow! Im pretty sure they are all the same!
Posted on: 2006/5/9 13:31
From SE Melbourne
Most likely has "T" on the head, whereas the rest of the head bolts like have "13" on the top of the head.
Here's some torque settings
TORQUE WRENCH SETTINGS
Cylinder head bolts . . . . . . . . . . . . . . . . . . . . . . . . . 74 Nm
Connecting rod nuts . . . . . . . . . . . . . . . . . . . . . . . . 37 Nm
Flywheel bolts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 88 Nm
Main bearing cap bolts . . . . . . . . . . . . . . . . . . . . . . 59 Nm
Camshaft sprocket ......................... 47 Nm
Camshaft locating plate . . . . . . . . . . . . . . . . . . . . . . 8 Nm
Sump bolts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6 Nm
Oil strainer bolts ........................... 14 Nm
Crankshaft pulley bolt . . . . . . . . . . . . . . . . . . . . . 196 Nm
Timing chain cover bolts . . . . . . . . . . . . . . . . . . . . . 7 Nm
Rocker pedestal bolts . . . . . . . . . . . . . . . . . . . . . . . 25 Nm
Valve rocker adjusting nut . . . . . . . . . . . . . . . . . . . 22 Nm
Sumpplug . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 29 Nm
Posted on: 2006/5/9 13:32
Mildman, Datsunless
Quite a regular
From Mira Loma Ca. USA
A14-15 head bolts have a "13" on the top. not sure about A12s , one of them is "recessed" ,that is the center one.
Posted on: 2006/5/9 18:15
1965 Datsun Fairlady 1500-A14 powered!
5 Speed All GX parts with twin Dellorto 40's
10:1 compression. 1976 B210 stock smogger with "dogleg" 5 speed and a ton of suspension work (coilovers, camber plates, etc. etc. etc.)
From The garage, NZ
hey mildman. Are those tourque settings for a15?? or all ? or a12 ?
cheers
Posted on: 2006/5/9 21:41
A15 head has a 12 on top of the head bolts (well mine does anyway)!
Same, are those torque settings for an a15??
Posted on: 2006/5/9 23:19
