A14/A15 Clutch diameter?
From Adelaide, SA
Hey peoples, can someone tell me the diameter of an A15 (or A14 if they're different) clutch disk?
I know an A12 is approx 180mm...
Cheers,
TC
Posted on: 2006/9/9 5:34
Re: A14/A15 Clutch diameter?
From Christchurch NZ
They are the same.
Posted on: 2006/9/9 7:53
Forced Induction!
From Perth
A10 is 160mm
A12/14/15 are all 180mm
Mine runs a Toyota clutch 200mm
Posted on: 2006/9/9 11:49
From Adelaide, SA
Bump! (I forgot about this post).
Thanks guys. Hey Dattoman - I just tried a Toyota 200mm on my A12 pressure plate and it fouls on the mounting flanges.
Did you shave your clutch plate down or what?
Cheers,
Terry
Posted on: 2006/9/14 2:56
From Brisbane, Australia
Mounting Flanges??? Dowels??
You have to get the flywheel re-dowelled.
edit:
You can't just change the clutch plate, you need a matched pressure plate as well. . .
Posted on: 2006/9/14 5:39
From Adelaide, SA
Nope, not the dowels , the base of the pressure plate where it mounts to the flywheel.
The whole pressure plate is not big enough in diameter to clear the Toyota Clutch plate.
I guess my real question is what do the Toyota 5 speed boys use for a pressure plate?
Posted on: 2006/9/14 6:44
From Canberra
I think they mean get the flywheel redrilled and use the toyota pressure plate?
Posted on: 2006/9/14 6:47
From Adelaide, SA
Ah - all makes sense now...
Bloody Toyotas - why couldn't they have made the clutch 20mm smaller!?!?!?
Cheers!
Posted on: 2006/9/14 6:54
From Central Vic
I got a sprinter pressure plate and clutch then had the fly wheel machined to take both
the result is the presure plate is the same diameter as the fly wheel -looks huge mounted up
but i havnt had any slip problem
Posted on: 2006/9/15 5:28
to buy or not to buy???? OK
This is the reason I have five coupes
I have had,my A series flywheel remachined to accept a 200mm L series P/plate. It does fit.
Posted on: 2006/9/15 9:17
Forced Induction!
