efi ignition setup
From campbelltown (sydney) australia
hey guys am just thinking bout ignition for my turbo a15 and have had some thoughts and wonder what others used. i know i could just use my elec dizzy but i wanna be able to have full control over my timing through the computer. i am wodering if u are able to use (becuase the rest of my sensors are ca18det) a ca18det crank angle sensor and drive it off the dizzy shaft or something like that? or wht is the best wayi was told to use a hall effect sonsor but cant find enough info to do it any help from ppl who have actually successfully done this dont wanna hear maybes or think so's cheers guys
Posted on: 2006/9/18 12:56
* caution, sunglasses must be worn to view my ca18det *
Re: efi ignition setup
From South Africa
I am using the std "Oldsckool" points ignition in conjunction with an aftrmarker EFI system that can do Fuel and ignition.
this particular EFI can be triggered ether by Hall, Magnetic, or CCT-breaking.... (IE. points). and it is working well for me. I guess the only down side to using points is when the engine gets to those screeming 8.5K Rpm ranges and above... it might get bounced.
The points, in my case only gives the ECU a trigger pulse and from there, timing is calculated by the ECU and then passed to a TP100 ignitor, which is responsable for the hard work. the points will theoretically last for ever..
Posted on: 2006/9/18 20:50
The rubbing block on the points will still wear as it rubs on the rotating cam & it will still retard the timing over time in the same way as points always do.
While the contact faces will not burn in the same way as before due to the lower current flow, points will still need periodic gap adjustment, followed by a timing check to ensure that the computer really does see a true TDC.
This is the real acvantage of electronic ignition in this application.
Posted on: 2006/9/18 21:38
Love your Datsun.
Treat it well.
From Brisbane, Australia
people commonly use modified Bluebird SII electronic dissies to provide the signal to an aftermarket ECU. people are already using these dissies on their A series, so it shouldn't pose too many problems.
Posted on: 2006/9/19 1:55
From Brisbane
Yeah thats right Harry I use a modified S2 bluey (hall effect dizzy) on my Aseries, they are a good bosch unit. Heaps of spark too.
Posted on: 2006/9/19 2:04
OLD SkOOL POWeR!!! [color=CC0000]"with the sound & smell of twin 40s at full throttle!!!" [/
From Melbourne, Australia
for mine i used a stock a-series electronic dizzy, i welded up the mechanical advance and disconnected the vacuum advance also, then because i was using a camira computer i put the dizzy module off the camira onto the a-series dizzy (just cut the wires off the old one and connected the wires to the camira one)
works beautifully
of course thats what that computer was looking for though (the dizzy module not a crank sensor)
Posted on: 2006/9/19 4:49
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Newscastle, Australia
RC Ive heard the Delco Camira ECU is actually programmable. This bit of news came from Jeff Taylor. However I dont know how to reprogram them. Anyone out there with that knowledge?
Posted on: 2006/9/19 5:02
Dont die wondering.....
http://www.kalmaker.com.au/
I believe you have to have your delco chipped for on the fly tuning. And the software is very expensive for DIY people.
Another option is megasquirt. A DIY ecu with free software and really great support :)
That 12 second 1200 in finland was running it. And i dare say its got the features and power of some of the more expensive ecus.
Posted on: 2006/9/19 7:06
you can buy all the stuff and tune it yourself, or a limited number of workshops have the gear to do it.
i get mine done at a workshop
Posted on: 2006/9/19 7:11
1200 Coupe Rallycar
so in syaing all that, does anyone think its possible to just use my electronic dizzy off an import a15 to drive the ignition side of the computer and then drive coils or something from there?
Posted on: 2006/9/19 12:22
