« 1 2 3 (4)
Re: fastest gone in 1200
From Adelaide, SA
just past 90 mph which i suppose is around 140ish kmh. forth gear screaming not something you should do often in a stock A12
Posted on: 2006/10/31 12:02
From Adelaide, Australia
Ive had that coupe off the clock Shmity! It loves it, ive had it near taking off coming down the freeway.
Posted on: 2006/10/31 12:36
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From Las Vegas USA
178Km / 110 mph at Willow Springs Raceway........it's down hill and a 1/2 mile run from turn 6 to 9. Normally my car will never see more than an actual 95 MPH at most tracks.
Tom
Posted on: 2006/10/31 16:33
From Sid-knee
Did the speedo limit in the XXXSEX before the CA conversion (with the 1200 engine i can't give away!) which is probably 160km/hr (100 mph) and i did 7000 revs in 5th after the CA conversion (with a silvia dash cluster that didn't work other than the tacho and temp gauge - what else do you need?) and a silvia box and R31 LSD.
Obviously both on 'private' roads.
(As an aside i once got over-taken by a Triumph Daytona on 1 wheel while i was doing 170km/hr out near Muswelbrook on a Coal & Allied road!)
Posted on: 2006/10/31 17:04
Quite a regular
160km/h most of the way in a stock, leaky, 1200 4 speed sunny.
on one of those 'gotta get home' missions at 3 in the morning. many straightish roads, many RPM
Posted on: 2006/11/2 12:53
From gold coast
180ks n cruiseing.....hot a15 plus a dellow gearbox conversion= a fast ute!
Posted on: 2007/9/12 4:15
From Canberra
DemonFreeman wrote:
is it bad to be sitting on 110-120 in a 4 speed 1200 at high revs for a while for highway use???
In my old stocker 120Y I used to sit on 140 on the highway, used to have to stop every 1/2 hour when the motor boiled and let it cool down a bit
My new stocker 120Y (auto) is uncomfortable with anything over 90, but will top 120 if need be
Posted on: 2007/9/12 4:46
From Canberra
Mine will sit in between 140 & 150 happily for awhile. It won't crack 150 though!!
Posted on: 2007/9/12 5:02
From north brissy
200+ in my ca ute, get it to about 180 on the drag strip
Posted on: 2007/9/12 7:16
« 1 2 3 (4)
