« 1 (2) 3 4 5 »
Re: Yellow Terra Rolla Rockers SUCK...
From Bunbury Western Australia
have you checked the valve clearances while the motor is hot?
Posted on: 2006/11/1 8:22
Two things that drive me nuts.....a dry road under a grey sky and a wet road under a blue sky, because no matter what, it's either too soon or too late to drive the way I want
From Perth
My cam with the 1.65 rockers gives 509 thou lift at the valve
Posted on: 2006/11/1 8:35
From Newscastle, Australia
yes John Taylor said that he would go back to standard rockers again in the A series same problem youre having give Jeff Taylor a call on +61 2 96238826 and see what he has to say....
Posted on: 2006/11/1 8:57
Dont die wondering.....
From Perth
yes, I will give jeff a call. The lift i gave was valve lift. the cam spec sheet said .295" cam lift.
It is a very loud noise it makes and the engine just hit a wall and will not rev.
Posted on: 2006/11/1 9:50
From Christchurch NZ
I say again if you don't want your rockers, sell them to me, CHEAP!!!!!!
I wish.
Posted on: 2006/11/2 8:40
Forced Induction!
Re: Yellow Terra Rolla Rockers ROCK...
Dodgeman wrote:
& how much lift do you have at the cam?
Yeah, I thought as much, but I did ask for lift at the cam & I went by your response.
I had always thought that an absolute minimum valve to piston clearance of .060" was required with .080" or larger prefered, depending on how much it revs.
Next time you have nothing to do, pull some plugs in the darkness of your garage & have a look at the pistons with a small diameter torch [flashlight] & try to see if there is any evidence of valve contact with the pistons, or even the bore if you are running big valves.
This is the only possible thing that I can think of that would make the noise that you mention.
EDIT. No, it's not the only possible thing, I just gotta learn to think more.
Posted on: 2006/11/2 9:35
Love your Datsun.
Treat it well.
From Adelaide, Australia
Probably a silly question, but could the rockers be hitting the rocker cover?
Posted on: 2006/11/2 9:36
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From Perth Austarlia
If the valves are hiing the pistons...wouldn't you end up with bent valves???
and if you did....wouldn't a simple compression test confirm this???especially if you know that the rest of the engine is not worn out.
Posted on: 2006/11/2 15:44
From Brisbane, Australia
at Rally Aus I though well one thing I have change this year was to put on Yellow Terra roller rockers with Crow crome-molly push rods. So I change it all back to standard rockers and push rods, problem gone. set the limiter to 8200rpm no problems.
the rockers are the 1.54 ones. when i built the engine i checked and i had .040" clearance at full lift.
did you use the standard rockers when you built the engine with that .040" clearance, and then change to the 1.55 ratio yella terras later?
if so, going from the standard 1.44 ratio to the 1.55 rocker ratio with .295" lift at lobe, means you have increased lift at valve by .029" and only have .011" static clearance left!
what was that .040" clearance to? piston to valve, spring retainer to guide (or guide seal), or clearance before spring bind?
if clearance is not the issue, it may well just be a valve spring problem. they may not be able to cope with the extra lift and those rpm. how old are they?
Posted on: 2006/11/2 22:50
Is it possible that with the extra lift the valves are floating into the bottom of any valve releifs in the cylinder wall?
Posted on: 2006/11/2 23:12
Forced Induction!
« 1 (2) 3 4 5 »
