Pit road engine same as mine, what is it?
From Adelaide, SA
pitroad
this shows a picture of an engine that looks exactly the same as mine did when i picked it up from the importer. it came with the same wierd intake thing over the carby and same rubber cover over the distributor cap. I had a good look at the intake thingy and i found that it would be very useful in blow through turbocharging in place of making your own carby hat as it has a rubber seal over the carby. not to mention the fact its a factory nissan part.... if anyone knows anything, any info would be appreciated.
Posted on: 2003/1/28 6:18
Re: Pit road engine same as mine, what is it?
From Sydney
Post a pic of this engine if you can ?
Cheers
Posted on: 2003/1/28 7:04
From Sydney, Australia
A15改1607cc製作
Translates to A15 (something) 1607cc (production)
This is from the link to that page. I'm not able to explain the funky intake filter box.
If you do a google search on A15 nissan, the engines were used in all kinds of industrial applications.
Posted on: 2003/1/28 7:26
From sydney australia
just an engine out of a c22 vanette,that light blue hat connects to a remote air cleaner in the inner guard of the van.
Posted on: 2003/1/28 10:42
From Christchurch, New Zealand
Did you notice that the page adress mentions A17, probably insignificant, but I wonder?
Posted on: 2003/1/28 10:54
From Brisbane
An A17 no way! i never heard of one, that would be wicked if there were one?
Posted on: 2003/1/28 11:06
OLD SkOOL POWeR!!! [color=CC0000]"with the sound & smell of twin 40s at full throttle!!!" [/
I wondered about that. Good one B310GX.
I've not ever gone down the A15 route. I was going to, but the CA's were about the same price. And I used to get better economy out of the CA18DE than I got from the A14....When driven normally...
Chris.
Posted on: 2003/1/28 12:19
From Melbourne, Australia
if you delete the last bit of the address you go to a page of links and the link says a-17 engine to
but that block looks normal size and i dont like chances of getting an a-15 out to 1.7 ltr
Posted on: 2003/1/28 12:42
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From auckland, new Zealand
i think that A15's are stable when bored out to about 1607/1608cc's but dont quote me on it.
Posted on: 2003/1/28 22:53
maybe they have a longer stroke crank,the japanese seem to do that for everything these days,& thats the only way to get bigger than 1608 from an a15.maybe they bore it to blaizes,then use cylinder liners for bigger pistons,but there isnt that much room between no's 2 & 3 cylinders.
Posted on: 2003/1/29 8:42
