« 1 2 (3) 4 5 6 ... 28 »
Re: 1/4 mile time log.
From Inner west nsw CAMDEN
CAR:120y 2dr sedan
MOTOR:1200
GEAR BOX:standard 4 spd
CLUTCH:exedy HD organic
DIFF:standard pull out centre
TURBO/SUPER CHARGER/CARBY:32/36 weber, with td04l baby turbo 10psi
EXHAST:3"
WHEEL/TYRE package:12" 165/65/12
60 foot time:2.428
1/4 mile time:16.093
MPH/KPH:89.4mph
tyre spin is an issue drop clutch at 6000 with original motor time for new motor not available yet
Posted on: 2007/1/19 10:03
FAT 120Y SR20de-NOS
What speed are you doing at M kmh???
Bet my bonnet scoop is bigger than YOURS!
Do wheelie bars suit a street car?
From Mudgee NSW Australia
This 1/4 mile time was around 7 years ago when I first built it. It was regoed and fully legal driven too and from the track (old eastern creek wed night street meet)
CAR: 1200 coupe
MOTOR:Ca18det
GEAR BOX: MR30 skyline (stumpy)
CLUTCH:Daiken brass button sprung center
DIFF:Mitsibishi scorpoin 4.6:1
TURBO: GT25 290hp model
EXHAST:3" to diff then 2.5"
WHEEL/TYRE package: 14x6 with 205/60/14 hankooks
60 foot time: 1.74
1/4 mile time: 12.0
MPH/KPH:113mph
Posted on: 2007/1/19 11:46
If In doubt run more BOOST
From Christchurch NZ
CAR: 1200 sedan
MOTOR: A15 (Bored to 1526cc's)
Induction: S/C 14 32/36 weber drawthrough running 7psi
GEAR BOX: dogleg 60 5spd
CLUTCH: Standard LD20.
DIFF: H150 spring loaded locker.
EXHAST: 2" with two resonators only
WHEEL/TYRE: 13x6 tridents, with cheap nasty 205/60/13's
60 foot: 2.417
1/4 mile:14.6
MPH: 92.4
This was only my first outing with this set up. I know I'll be faster next time!
Posted on: 2007/1/19 21:00
Forced Induction!
CAR: VB10 1000 wagon
MOTOR: A15
GEARBOX: FORD 4 SPEED
CLUTCH: SOLID SAW BLADE PLATE DUEL DIAPHRAM
DIFF: 3.89:1 120y BW LOCKED
TURBO: GARRET TO3 (HIGH FLOW BASED ON RB30)
EXHAUST: 2.5 INCH DUMPED AT DIFF
WHEEL/TYRE: 13/7 REBELS 205/65
60 FOOT: ?
1/4 MILE: 12.7 SEC
MPH/KPH: 102 MPH?
Posted on: 2007/1/20 11:04
From brisbane
Wow! There's some pretty impressive times here.
CAR: 1200 ute
MOTOR: CA18DET
GEARBOX: CA18DET manual
CLUTCH: Jim Berry 2125lbs upgrade
DIFF: R31 LSD
TURBO: standard T25
EXHAUST: 3" mandrel
WHEEL/TYRE: 175/60R14
60 FOOT: 2.1
1/4 MILE: 13.9
MPH/KPH: 102 MPH
The only runs I have had were with my old motor that was down on compression. By the looks of the times in the posts before mine I need to get back to Willowbank and punch out some numbers! I now have a GTi-R T28, better tune and wider rubber so hopefully I can improve my best time by quite a bit.
Well done to everyone.
Matty
Posted on: 2007/1/21 1:47
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
From sacramento california
1995 talon turbo allwheel drive
78 hp to each wheel. 322 to the flywheel.
15 psi boost.
0-60 in 4.7sec
0-100 in 8.9 sec
1/4 mile in 12.66 sec
my datto is dead right now so i thought i would post my other car.
Posted on: 2007/1/29 1:15
friends dont let friends drive stock!!!!
From Wagga Wagga
CAR: 120y 2dr sedan
MOTOR: 1200
GEAR BOX: standard 4 spd
CLUTCH: stock
DIFF: stock
TURBO/SUPER CHARGER/CARBY: unknown it's old now one knows what it is I've have also got force fuel injection.
EXHAST: no exhaust straight from the engine
WHEEL/TYRE package: stock 12
Posted on: 2007/1/29 2:13
1980 Datsun 1200 Ute (WIP)
A15 Engine
5 Speed Sunny
H165 Diff
From Geelong, Vic
CAR: ke20 corolla
MOTOR: 3TC celica engine
GEAR BOX: T50
CLUTCH: stock
DIFF: stock
TURBO/SUPER CHARGER/CARBY: twin solex 40s
EXHAUST: 2.5 inch with hotdog dumped before the diff
WHEEL/TYRE package: 215-60-13 old dodgy tyres, spun through 1st and most of 2nd
60 foot time: ???
1/4 mile time: 15.9
MPH/KPH: ???
havnt raced the datto as its too slow at the moment so though id post my brothers daily instead
haha burke a lot, you think a stock 120y would run a 17, keep dreaming
edit: haha coz i laughed at your time you made it faster
Posted on: 2007/1/31 1:00
You have to take into consideration that his tyres are very BOLD. I wonder if they are also italic? italic looks more aerodynamic so would explain the fast time
Posted on: 2007/1/31 1:25
From Wagga Wagga
it's the bold tyers are what make every thing all jumbled and did you take in that I live on a farm witch makes things all ####ed up even more.
Posted on: 2007/1/31 4:10
A15 Engine
5 Speed Sunny
H165 Diff
