gemini radiator
From Melbourne, Australia
g'day
im putting in my newly aquired gemini radiator
any suggestions on hoses that will fit?
it looks as though i need to cut the mounting edge on the passenger side and move the radiator over that way to get the bottom hose around the alternator
doing this means there is a sharp turn to get the top hose to work
just after mounting suggestions or recommend hoses to use off what car
cheers,
Michael
p.s. im also wondering if any gemini's had a shroud or if any one has found a shroud off something that might work? or do you all use thermo fans when using a gemini radiator?, and do you guys cut the front of the car to mount the radiator and allow more airflow?
Posted on: 2003/2/19 12:34
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: gemini radiator
From Sydney, Australia
Oh man..Not Gemini parts!! anything else please!
I understand though, that Australian's are stupid people, and we've supported the Gemini much more than the Datsuns. Especially in the spares availabilty. I can't believe the parts you can still get for the gemini.
If I was you, I'd try and make the radiator fit neatly. If that means cutting out the radiator opening, and inserting some metal to fill in the gaps, then you should do it. But maybe you should find the toughest and most readily available radiator unit before chopping up your front panel.
Chris
Posted on: 2003/2/19 12:41
Re: gemini radiator
im not allowed to chop the front for rally!!!
i was just wondering if thats what everyone else did cause it would mount really flush and easy and you would get serious amounts of air flow if you could, IM JEALOUS
Posted on: 2003/2/19 12:43
1200 Coupe Rallycar
Re: gemini radiator
i know its sad
ive had alpha radiator
now going to gemini
but worst of all, with the alpha radiator i had a HYUNDAI EXCEL top hose, that was shamefull, let me tell you the id sticker came off that hose very quick
Posted on: 2003/2/19 12:45
1200 Coupe Rallycar
Re: gemini radiator
From Brisbane
yeah i want a bigger radiator!! what do i get ??? all the wreckers reckon nuthing will go on the datto cause the are munted different and they a e like platsic nad crap like that
i wanna big radiator i am willing to cut some body but which radiator??????????
Posted on: 2003/2/19 14:05
OLD SkOOL POWeR!!! [color=CC0000]"with the sound & smell of twin 40s at full throttle!!!" [/
Re: gemini radiator
From Canberra, Australia
I got a gemini radiator.
I have the alternator up the top though, so I had no probs with the hose hitting it.
All I did was use square bits of pipe as spacersand drilled four holes in the front of the car. then put bolts (with washers) through the hole and then through the square pipe spacers and then through the radiator bracket.
Top hose fit easy, bottom hose had to be persuaded a little. I was gonna get another one eventually but I am lazy. Had the same hoses for about 5 years now.
Umm yeah, it looks pretty dodgey, but it works. Be careful about how close you mount it to the fan. My engine wasn't bolted in tightly enough and it moved foreward into the radiator a few times under braking. All fixed now though.
Umm yeah. Hope that kinda helps.
I can take some pictures if you need them...
Oh yeah, if you want a bigger gemini radiator then get one off a gemini that had A/C. Those ones are bigger...
Posted on: 2003/2/20 3:25
Re: gemini radiator
From Warwick, QLD
I got a cut down VL radiator, it takes up most of the front but I got it for $50 from the radiator people, the I only had to change one hose, keeps the motor REAL cool. To mount it I just had to drill 2 hols on the bottom as it had spikes opn the bottom then I just used L shaped mounting brackets.
Cheers
Damo
PS Pics of my car will be up when I get a new paint job and rust cut out.
Posted on: 2003/2/20 3:35
Drive It Like You Stole It
Every Car Has 500hp In The Wet
Team NEW SKOOL
Re: gemini radiator
From Kyabram vic, aust,
I had a colt radiator, they look very similar to the 1200 one but they are a bit bigger and they are 3 core.....
Posted on: 2003/2/20 10:58
Re: gemini radiator
From Mudgee NSW Australia
I had a 3 row high performance core fitted to my standard tanks when i had the A series in my coupe it never got hot even in burnout competitions 7000+rpm for a few minutes. Just looked like a standard radiator just fatter i found the standard engine fan was good too it made a bit more power with just a thermo fan but didnt keep as cool.
cheers Andrew
Posted on: 2003/2/20 11:08
Re: gemini radiator
PIcs of my dodgey radiator mounts:
*gemini radiator mounts*
Posted on: 2003/2/22 17:04
