« 1 ... 6 7 8 (9) 10 11 12 ... 21 »
Re: A-Series Manifold Templates for Autocad - Come n get 'em
From Freo
hukkay shaggit, I'm in, and up for the pickup at Neils BBQ dat party...
Rally1200 I:2 E:2
Dattoman_1000 I:2 E: 2
dattodevil I: 1
pager I: 1 E: 1
Beattie I: 2 (1 steel braced, oval & 1 alloy braced, oval)
Cable_tie I: 3 alloy 2 Mild E: 5 (all Oval)
LAGWAGON: I: 1 E: 1
boofhead: I: 1alloy 1steel E: 2 (oval ports)
Grunterhunter I: 2 E: 1
Tnpshow I: 1(MS) E: 1
ang94541 I: 1alloy oval, 1steel oval E:3 rally1200 style
Ianey I: 1 alloy 1 steel E: 1
Sidedraught 2x mild steel exhaust
kue1000 I:1Alloy E:1 steel - oval
1200Rallycar I: 1 alloy 1 steel (oval ports) E: 2 steel
Wombat Racing 1 ovalport inlet, 2 exhaust
Teretonga I: 2 alloy (oval ports) E: 2 steel
Dundee1000 1 alloy oval, 1 Steel exhaust.
Posted on: 2007/5/9 1:37
From South Africa, Bloemfontein
OK guys.
Need some advice. I can get mine made for free. Altough to make it complete I will still need the template of the flange for the webers to bolt to.
I just have some questions with regard to the intake manifold:
1. I measured my spare SU intake manifold's thickness of the part that bolts to the cylinder head. It is 15mm thick. The aluminium I can get is only 8mm thick. Will it still be up to the job?
2. I do not know what grade the aluminium is that they are going to use. MUST it be 5083 or can 6061 also be used for this job.Will contact the guy tomorrow to find out what aluminium he will use.
Thanks.
Posted on: 2007/5/9 3:53
1977 Datsun 1200GX
From Adelaide, SA
8mm should be fine performance wise. The reason we went with 10 is because the exhaust was too and this makes the 2 surfaces even when bolted up.
I have dimensions for a DCOE. I will do this tonight when I get home.
I will also Update all the files as DXFs.
Stay tuned!
Posted on: 2007/5/9 10:26
From Adelaide, SA
Bump...
Ok DCOE pattern is done - get it HERE
On second thoughts I'll leave the dxfs of the other flanges until I can verify the designs on the weekend...
Posted on: 2007/5/9 22:54
You are our Datsun hero!!!!!
Posted on: 2007/5/10 17:46
1977 Datsun 1200GX
From perf
ok they could come in handy 1 day! have added my name at the bottom. how do we go about paying and how much?
Rally1200 I:2 E:2
dattodevil I: 1
pager I: 1 E: 1
LAGWAGON: I: 1 E: 1
picko: 2 exhaust, 2 intake
cheers
Posted on: 2007/5/10 19:59
From Christchurch NZ
What about doin the oval intake ports for a GX head? The GX heads have bigger ports than the A14/A15 ovals do.
Posted on: 2007/5/10 20:38
Forced Induction!
From Perth
Die grinder
This is getting fun isn't it
Posted on: 2007/5/10 21:55
I PM'ed TnPshow about the same question because my GX cylinder head is still standard non-ported. He replied that the oval templates are drawn for a stock GX cylinder head. PM him just to make sure.
Posted on: 2007/5/10 22:25
1977 Datsun 1200GX
will the weber flanges be available as part of the group buy laser cutting ???
Posted on: 2007/5/10 22:42
